Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Shirt sleeve caught under agitator on ge model glwn2800d
2 Suggested Answers
  • 2468 Answers
SOURCE: Shirt caught under agitator how do I get agitator
you need to pry the softener dispenser cup off the top of the agitator,then you need a 7/16"socket with an extension to remove the nut located down inside there,then lift the agitator straight upward
Posted on Mar 23, 2011
Clothing gets caught under the agitator wings like sleeves on shirts, strings on clothing ie hooded sweatshirts.
This is something that happens with most top-load washing machines. As long as the agitator has wings, stuff will get under them. That is one reason that front-load machines are becoming more popular.
May 10, 2015 | Crosley Washing Machines
Item caught under agitator
The top of the washer pulls up. IT may be hard to do. This will expose the whole drum so that you can see around it. If you need to remove the agitator, there is a cap on the top of the center, take it off and you should see a nut and some lock washers, Remove the nut and lift the agitator out.
Dec 19, 2013 | GE Washing Machines
My GE Spacemaker wslp1100 top loader is draining very slow causing error code dr. I took black drainage hose off and it seems to be clean. Filters are clean inside washer. I want to know if a coin could be...
You don't reveal full model number. It's not likely that a coin is blocking the water. The pump (part of the motor assembly) may be partially blocked inside or a garment (sock, u-shirt, etc.) may be blocking the water inlet to the pump. It's too early to remove the agitator.
Nov 22, 2013 | GE Spacemaker WSLP1100D Top Load Washer
Trim on blanket caught between agitator and drum. How do you remove agitator on this model?
The agitator simply lifts off the shaft. Grab it and pull upward with a little force, and it'll pop free. Under the agitator you'll find a plastic drive coupler that has a single bolt through the top. Remove this bolt and remove the drive coupler. Whatever got wrapped around it you'll find underneath and should easily come out now.
Aug 16, 2013 | GE GTWN5250DWW Top Load Washers
Shirt caught under agitator how do I get agitator out to unwind shirt
Mar 23, 2011 | Frigidaire Gallery GLWS1339EC Top Load...
How to remove the agitator to remove a shirt that is caught
according to GE if you have a model made after 1999 you need to have a GE technician remove the agitator as it requires a special tool. :(
Dec 17, 2010 | GE Washing Machines
Can't get the fabric softner cap off
Don't feel foolish as im sure your not the only one this has happened to. to remove the agitator cap you must lift it off, apply slight twisting to it while your doing this. soap can gum it up so you may have to use a straight screwdriver to assist you. once you have done this, there should be EITHER a set screw for an allen key on the SIDE of the agitator OR a 3/8 hex screw in the center or the agitator. there is a spring under this screw so remove both and the agitator should lift staight up. use an old belt underneath the base of the agitator for better results. i hope this has answered your question.
Thanks
Aug 08, 2009 | GE WJRR4170E Top Load Washer
Shirt caught in the agitator
The top of the agitator should unscrew then pull off.
Feb 21, 2009 | GE Spacemaker Washer and Dryer Electric...
WM won't spin after sleeve got caught in door
I had this happen. The drive belt had come off. Just take off the bottom panel from the back and reattach the belt.
Jan 27, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Drawstring tangled under agitator on an older GE washing machine.
You should be able to unscrew the top cap of the agitator ( may be left hand thread ) and lift off the agitator once the cap is off... They sometimes stick so you may have to muscle it to remove that cap..once lifted off..you should be able to untangle the string that is caught..
Sep 21, 2008 | GE WBSR3140DW Top Load Washer
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
