Question about Amrex Ms322 Low-volt Ac Muscle Stimulator
Amrex Ms322 won't pulsate
Unit turns on but won't pulsate or any of the other options as well.
What bottle brush do you use to clean a Waterpik SWI 615 Sinusense Water Pulsator?
Any bottle brush will do if it fits into the unit to do the job. If the bristles are polyester or another kind of plastic it will not absorb bacteria. Wash and rinse the brush well after use and don't use it for anything else.
Jul 27, 2013 | Waterpik SWI 615 Sinusense Water Pulsator...
Monitor won't turn on I have connected everything properly and still no signal
I didn't see whether the power strip where you have all devices plugged in was turned on. Plus, you only showed one side of the monitor. There should be an indicator light on the monitor which indicates that electricity is running through the unit. Lastly, did you read the owner's manual before putting this unit together? Check all options and let me know what happens.
Mar 06, 2013 | Computers & Internet
JVC UX-1000 Won't Turn On - Power LED pulsates
I have the same problem for my Hifi from JVC, can't find any answers. Did you manage to fix the problem?
Mar 03, 2013 | Audio Players & Recorders
My 1997 Hyundai sonata, won't fire. I have
check your crank shaft sensor behind the harmonic balincer
Feb 01, 2013 | Cars & Trucks
Self cleaning oven won't start
Hi bstetson328 - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self clean option, if it does not turn on then the temperature had tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC and I would suggest contacting a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Changed rotors and pads on volvo s80 2001 but strong pulsating continues when braking
Abs control valve it's a big unit under hood with all the brake lines going to it then out of it to calipers. It has wire harness connector un plug it and try brakes aware that abs won't work but brakes will operate be careful until this is verified if pulsing stops that control valve has a problem. My advice is to never buy another Volvo I won't I had one
Apr 02, 2012 | Volvo S80 Cars & Trucks
I recently put new front brake pads and had rotors turned on the front end of my 2003 tundra sr5,after a month of driving i'm getting the pulsation when braking back which is why i made this repai
HI if you have pulsation after a month you must replace the rotors
they are too thin and the heat is warping them faster then before you
had them turned
note you replace brake pads and rotors
good luck
Feb 20, 2012 | 2003 Toyota Tundra
Where are the fuses in the harman kardon 3380 receiver, I had a lightning strike which I think knocked out my receiver thru my outdoor speakers, it will not turn on, could it be a fuse and if yes, where is...
Hello Randy,
There are two options here: first, the power button is amber but unit still won't go. In this case try a 'factory reset' as per manual. If this won't work, it seems that the processor is gone (located on the display board) so you have to bring your unit into a authorized shop for repairs. Secondly, it might be just matter of some blown fuses which are located inside the unit on the transformer board. If after replacing (if they're blown) the unit still won't work or keeps blowing the new fuses, follow the first advice, meaning you have to bring the receiver to a service. To access the fuses, you have to remove the top cover.I wish you luck
Kostiko
Sep 12, 2011 | Harman Kardon HK 3380 Receiver
Brakes pulsate when you put them on. When I take off from a complete stop it feels like the brakes are not releasing immediately.
Pulsating brakes are often caused by warped brake rotors. In order to check for a brake that isn't releasing I would suggest lifting one wheel at a time, applying the brakes and immediately checking if that wheel turns freely. Repeat on all 4 wheels. If you find one that isn't turning freely you'll have to address the problem with that brake.
Jun 18, 2011 | Chevrolet Blazer Cars & Trucks
Amrex Ms322 Low-volt Ac Muscle Stimulator Logo
37 people viewed this question
Top Amrex Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Amrex Health and Beauty Expert? Answer questions, earn points and help others
