Question about Compaq TFT5015 15" LCD Monitor
How to stretch screen compaq tft5015
Seem to have reset the monitor settings and now have black lines on either side of screen
  • 79 Answers
Right click the desktop - select graphic properties - you should have the option to stretch to fit or something like that. This could also be that your resolution doesnt match your monitor. usual wide screen monitor defaults are 1280/1024 or 1400/1068.. have a mess around and alter these - see which one fits.
Posted on Jan 25, 2009
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Blank screen when the cpu is on
Try connecting a different monitor to your computer to determine if the video card or monitor is faulty.
If the monitor is faulty then you could have a faulty inverter board or a CCFL lamp that provides the back light.
Replacement inverter board and CCFL lamps for LCD monitors are available from this WEB site.
www.lcdparts.net
Jul 14, 2011 | Compaq TFT5015 15" LCD Monitor
3 inches of black on both sides of my monitor
I have seen this when using HDMI cables from the computer side.. The TV has a resolution that is not always full screen with TV shows. There is a setting that allows you to "zoom". My TV has 4 settings: normal, stretch and crop, stretch left and right, stretch and pinch (shrug).
Jul 07, 2009 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
Monitor: Compaq TFT5015 Displays vertical lines
Check that the signal cable from the computer is firmly connected and that there are no bent pins in either end. If the trouble continues, the problem is in the monitor itself. Given the low replacement cost, it's uneconomical to try repairing these.
Apr 13, 2009 | Compaq TFT5015 15" LCD Monitor
No backlight
You may have a bad regulator or a bad mercury bulb. Testing either requires a professional with the right equipment. This area contains high frequency current. The mercury bulb is extremely delicate and has to be disposed of properly. I would suggest taking this to a pro.
Mar 24, 2009 | Compaq TFT5015 15" LCD Monitor
Speakers compaq tft5015
There are no speakers in my Compaq TFT5015 model No PE1212
Are there really any in yours??
Nov 14, 2008 | Compaq TFT5015 15" LCD Monitor
Acer LCD AL1716W Monitor shows lines
use 1440 x 990 resolution, the ratio of the monitor is 16:10
Dec 27, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Sleep mode
There is an On Display Menu (ODM). You can access it by pushing the button located on the monitor. Use +- buttons to navigate in the menu. Here you can switch off the sleep mode or change the sleep settings. I have a simular problem... I try to turn off the power save function but it seems like it dosen´t want to understand this...
Oct 08, 2007 | Compaq TFT5015 15" LCD Monitor
Compaq TFT5015 15" LCD Monitor Logo
144 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
