Question about Briggs & Stratton Garden
How do I set the timing for a Briggs and Stratton 375 lawn mower
  • 54 Answers
There is no spark timing setting it is controled by the flywheel and points. what actually is your problem, then I can work out whats wrong.
Posted on Jan 18, 2013
  • 166 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Posted on Jun 16, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
mikehowy
  • 177 Answers
SOURCE: I would like a user manual for a Champion R484TR lawn mower.
google
Posted on Jun 07, 2010
I have a sovereign 375, the cable which goes from the Handle to the engine has broken, is there another model/type of mower that will fit? Thank you
Contact this company https://www .briggs and stratton.com/ they sell all parts for beiggs and stratton. Give them the model # of the mower and they will be able to sell you the right cable
Sep 23, 2015 | Briggs & Stratton Garden
Www managemyhome com
Do you have spark?
Do you have fuel delivery to carb?
If you have spark and fuel delivery then check your flywheel key. This key times your engine. If it's an OHV then your lash might not be set right.
Jul 16, 2014 | Briggs & Stratton Briggs Stratton...
What is torque setting for honda izy blade
just tighten it as tight as you can lawn mower rotation will tighten it more
Jul 07, 2014 | Briggs & Stratton Briggs Stratton...
Can I use sae 20W-50 oil in my briggs and stratton 375 sprint mower
No, it should take a straight sae 30 grade oil.
Jan 10, 2013 | Garden
Briggs statton 375 starts runs very high revs how can i slow it down
remove the top cover from the engine and see if theres a nest stopping the governor from moving
Aug 20, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Timing is off nedd to know what depth to set magneto at briggs and stratton 600 series lawn mower 190cc
the timing is fixed by way of woodruff key in the crank which locates into a chanel in the flywheel and is not adjustable. If you mean the air gap between the ignition unit and flywheel then set it to aprox .002-.005 inch
Aug 23, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Gap setting for briggs-stratton 6.5 lawn mower
I believe it is 0.040 on a regular spark plug gapper
Nov 07, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
The engine on my Sprint 375 floods when trying to start
Check the float in the carb. bowl for gumming and clean your carb.. If you haven't done so already. Or you can try running a fuel treatment through your fuel. That may help you with your flooding issues. Good luck.
May 04, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
135 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
