Question about Whirlpool WTW6200S Top Load Washer
Got it used and it shakes at spin at hi speed an ul come on
Start up fine at hi speed an shakes an ul come on
  • Whirlpool Master
  • 17,130 Answers
This can be due to excess load on the drum. remove the clothes and check once again. check the level of the machine, Also check the filling and draining water level to confirm if there was a overfill.
Posted on Jan 18, 2013
3 Suggested Answers
  • 92 Answers
SOURCE: Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Posted on Feb 06, 2009
GodBlessU
  • 3513 Answers
SOURCE: i have a whirlpool cabrio washer wtw6200swo when
Hi
UL error means unbalanced load. In this case you have to rebalance the load and start it again.
Please check the link for whirlpool cabrio washer fault codes and the resolution that has been given in the chart:-
http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 19, 2011
95'95' mercury cougar xr7 shakes at slow speeds. When I get to highway speeds shaking starts to fade away.
Hi John,
Sometimes this is related to tread ply separation. the key is the frequency or rate of the vibration. Why it steadies at faster speed is anyone's guess. To test you jack up a corner of the car, spin the wheel and observe across the tread while tire is spinning.
Another way to test is to have the tires balanced and have those guys check for trueness.
If you find this condition, there is no cure but new tires.
Dec 27, 2014 | Mercury Cars & Trucks
UL light keeps coming on stops spinning
The uL error code is displayed when the electronic control detects an off balance load. This can be caused by overloading, bad bearings in the tub, something between the tub and basket, or an issue with the electronics.
Feb 03, 2013 | Maytag Bravos MTW6600T Top Load Washer
My Kenmore Elite Oasis top load washer will start when is ready. We press the start button several times and hold it down for minutes at a time then maybe it will start. Plus even the smallest load will be...
If the washer is shaking and actually going out of balance and generating the UL error and the drum is empty the most likely cause of this problem is something under the spin basket.Clothes can end up under the spin basket and cause it to turn crocked and cause the out of balance. First I'd recommend removing the spin basket and check under it for any clothing or other obstruction that might cause the out of balance. Here is a diagram of how to Check.. Click Here
May 22, 2011 | Kenmore Washing Machines
My washer goes into spin cycle byitself and when washing,if u r in spin cycle it sets for 14 mins thats good 4 mins into spin all knob lights start flashing and the screen says uL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
Jan 23, 2011 | Washing Machines
Ul code about 10 to 15 seconds into spin cycle machine is level code comes up even if i run it empty
Hi
Thanks for using FixYa. UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
In the last 10 minute wash cycle the tub shakes while spinning and the code UL appears.
mine does the same thing, looking for a solution. thinking about tearing it down tommorrow. just wanted some ideas where to start before i did
Aug 14, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Oasis he washer,,keeps saying ul .
Uneven Load.
The sensor should be checked for proper operation, and the vibration dampers too.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool WTW6200S Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
