Question about Sylvania 10 SDVD1030 Swivel Widescreen Portable DVD Player w/SD
Sylvania SDVD1030 showing no disk error - Sylvania 10 SDVD1030 Swivel Widescreen Portable DVD Player w/SD
Have Sylvania SDVD1030 won't play USB, 1 comment said format to FAT32, HOW? my cameras ask about formatting a memory card, NEVER had any device ask about formatting a flash drive appreciate any help.
Memory cards should be formatted using a computer. Actually, default format is FAT32 but you might check usng computer, open it as Removable Drive ans check with right button - Properties.
So, if it is in FAT32 why your DVD player won't play it? No idea. If USB is ok, you should return device and get then check it on warranty
May 23, 2015 | Electronics - Others
No disc error on model SDVD1030
The player mechanism may have failed.
Jan 11, 2015 | Sylvania Televison & Video
How do I turn down the volume on DVD portable Sylvania without remote
To turn the volume hold down the play/pause button
To turn the volume down hold down the stop button
Aug 31, 2014 | Sylvania SDVD1030-RED 10-Inch Portable DVD...
Do you need to always have the sylvania sdvd1030 plugged in?
You absolutely need to keep a PORTABLE BATTERY OPERATED dvd player plugged in for it to work. Cell phones are the same way aren't they.
I think your asking a troll question and if not
you have no buisness buying any device besides a tv with rabbit ears.
Jun 14, 2014 | Sylvania SDVD9000 Player
Want to use toshiba 500 GB portable hardrive with sylvania SDVD1030
I think no problem create, because PC sense only 0 and 1 corrector and PC work logically. So you are used any company product no issue. But may be if Hardware software driver not supported then error create. So you try it and connect device.
If Technical Support contact good Hardware Technician.
Feb 06, 2014 | NA SYLVANIA SDVD1030-BLACK
Can't find remote code for directv remote
go to direct tv website and search for the code.
Feb 03, 2013 | Sylvania 10 SDVD1030 Swivel Widescreen...
Cant get past the start window
The main problem is the hard disk switch off the laptop and remove the battery from its compartment then remove the hardisk cover and remove the hard disk from its compartment now replace the cover and insert the battery to its compartment and switch on your laptop and see wether the system show boot error if you can see the boot error and when you connect the hard you doesnt go till there it means you have a problem with the hard disk
Dec 30, 2011 | Sylvania G-Netbook
Cannot load Sylvania CD onto XP windows system
Hi.
You normally do not need a driver for MP3 players with XP. You should just be able to plug it in to the USB port, then wait for it to find the new hardware, then it will show as a new drive in 'My computer'
Mark
Dec 24, 2008 | Computers & Internet
Sylvania 10 SDVD1030 Swivel Widescreen Portable DVD Player w/SD Logo
53 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
