Question about Canon iRC2380i
E000001-0003 Says to shut down and re-try but still same code comes up. Thanks in advance for any help!
2002 Chevy Tahoe. Around 3 years ago the 1st
If a vehicle shuts off while driving down the road. then restarts after about 10 minutes, its a bad crank sensor or the wiring to the sensor. A check engine light may not turn on. If the light is on. You can take it to any auto parts store to have the code read by a scanner for free. Auto-zone, Advanced ETC. Its worth a try! But first check the fuel pump relay, It may be getting hot and shutting down pump. Try swapping a relay of the same type, if it is ok, thats the problem. Hope this helps!
Sep 20, 2014 | 2002 Chevrolet Tahoe
I was driving my kia sedona and suddenly shut down in the middle of the street. I tried to started again and engine cranked, but did not start. By the way, the engine light check came on. Next day it...
Hi there!
It could be your Crank Position Sensor , Or Cam Position Senor. Because these two parts when they fail, The car shuts down suddenly or doesn't start at all or It start sometimes and sometimes not. And i would advice you to take the car to an auto part store like Advance or auto zone and ask then to scan the check engine light to see whats the code that was stored in the computer then bring it to see what is it exactly, and they do this service for free. Good luck Bro
Feb 01, 2011 | 2003 Kia Sedona
Hi, I have a Goodman furnace model GKS91155DXAD. The blower stays on. After turning power off for a few minutes then back on, the draft blower comes on for a few seconds then goes out but the blower...
I would check hot surface ignitor or spark ignitor to make sure they are working. If not then replace them and try again.If ignitor does not come on control board will shut down, try to restart usually try 4-5 times then lock. out. Generally for a preset time then try again. If it has tried to start to many times and failed it will lockout until power is shut off and it can reset. Hope this helps you. Thanks
Nov 17, 2010 | Heating & Cooling
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Systems shut down
Sounds like a software error, Try using system restore to set back the pc to an earlier time. Also try starting up in safe mode and uninstall any software that you may have installed.
Sep 28, 2009 | Acer Aspire One Netbook 8.9" Notebook
Have a 1995 MX-5 that the check lights comes on after warm up. Then after shut down next start up is does not come on until warm up. Any suggestions?? Thanks,
go to advanced or auto zone and have them pull the code. it will show up if your light is on or not because the computer stores the codes. (this is assuming that your car is obd 2 if not you will have to jump the curcuts your self or take it to a shop to get the codes read. then you will be able to solve the problem.
Jun 20, 2009 | 1995 Mazda MX-5
Ford 2003 Expedition starts then shuts down
The only idea I hbave is for you to buy a OBD II sensor code reader. Know half the time the codes are generic, BUT also if you go buy a Advance auto they will read the code for you for free. And that code is the correct answer to your problem. Just make sure if your truck loses the code when you cut it off, that you don't cut it off when you get to advance auto.
brian_brackett2004@yahoo.com
Jan 26, 2009 | 2000 Ford Expedition
Mouse works, click on icon, nothing happens
its seems your os is havening problem try to restore to earlier date or repair it.
Dec 17, 2008 | Acer Aspire 5315 Notebook
My PC won't shut down, standby or hibernate
Try the following
Control Panel -> System -> Advance Tab -> Settings under Startup and Recovery. Unselect Automatically Restart. Click Ok twice. Try to shutdown your pc and look for any error code.
Let me know if any error is displayed
Nov 24, 2008 | Microsoft Windows XP Home Edition
Canon iRC2380i Logo
27 people viewed this question
old marine
old marine
