Question about Garden
My husqvarna 254 run great but she idle too fast ,ill set the low needle and when i set the idle one nothing chang
  • 2,239 Answers
Machines that idle too fast and eill not alter with the idle screw either has the throttle butterfly on the throttle spindle loose and sticking, or the machine is drawing in air through a crank seal or gasket.
Posted on Jan 18, 2013
  • reginald godin Jan 19, 2013
    Thank you for youre help.But ill allready check these thing except the crank seal and i thing now that probleme occur after my spring chain brakebecause she was used or maybe of the realy cold weather in my place.I,ll already ordered one from california usa and that gona take eight to twelve days to come but i realy appreciate you help and thank you from nb canada.Reggie
2 Suggested Answers
  • 11 Answers
SOURCE: Husqvarna 357 XP Hard starting when warm.
I work for warcks county council, the husky 357xp is our main saw. We've experienced the same problem with many of our new 357's. after many hours of trying to solve the problem (including swapping carbs from old broken saws etc) i stumbled upon, by fluke i'm afraid, a problem with the ngk bpmr7a spark plugs. They seem to work fine for a short period of time (even new out of the box) then leak compression from the cylinder. We are running a esser rated bosh spark plug which seems to have eliminated the problem, (can't remember the number, sorry). We have now ordered champion plugs to replace the stock. Probably worth a try. Hope this is of some help.
Kieran Tursner
Posted on Mar 15, 2009
What the proper carb settings for husqvarana 51
The initial fuel mixture settings are 1-1/2 turns from seated on each.
  1. Set at best mixture after running,
  2. Set Idle speed at 2500 rpm
  3. Then for best at full throttle and not exceed 12500 rpm.
  4. If the engine want to go above 12500 rpm enrich the high mixture a little to limit the speed.
Feb 14, 2015 | Husqvarna Chain Saw Handle Models 50 51...
How can i adjusting the throttle on a husqvarna ?
Depending on the model Husqvarna, there is an idle adjustment you can make. However, Federal Government and EPA will not allow you to change the settings on the carburetor's High and Low needle settings. This must be done by a certified Husqvarna dealer.
Aug 09, 2014 | Husqvarna Garden
What is carburetor setting on a2.3 chainsaw
There is no fixed carburetor setting on these engines, just two screws to adjust low-end and high-end operation. Special tool may be required, there are about a half-dozen screw head standards. Check eBay for tool. Get the engine to run and idle fast (idle adjust) so it doesn't stall, adjust low-end screw so that engine doesn't hesitate or sputter when accelerated. Adjust high-end screw to run fast and smooth on full throtle. Readjust idle to normal.
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna 55 chainsaw has a problem running on idle
start by checking all ur fuel lines for holes then proceed to clean or rebuild ur carb the ethonal in fuel is cloging small engine carb jets and making needles stick so then adjust ur carb back to factory settings try with new air filter as well and run 89octane or higher in your two stroke motors u will c a great differance in performance
Dec 13, 2012 | Husqvarna Chain Saw Models 51, 55
I purchased a new carb fro my husky 137. When I started it it ran very fast. It is hard to start but when I get it going it runs very fast and will not idle. I was wondering what the initial carb...
1/12 initial settings, sounds like you are sucking air, check the hose from cylinder to carb which runs fuel pump in carb off vac pulses. some saws have one and some just **** through the intake small hole. good luck
Aug 25, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I need to know the high and low settings on husqvarna35
Turn both jet needles CW to stops (lightly), then turn each screw out CCW 1-1/2 turns. This is a basic setting which should allow the engine to start and run. Start the engine and allow to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, but still allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain stops turning, but the engine will continue to idle. Hope this helps!
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How many turns out is the High and Low screws suppose to be adjusted. Also how many turns out is the larger idle screw suppose to be.
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting which should allow the engine to start and run. Before adjusting anything, check the fuel filter, air filter and muffler for plugging. Start the engine and allow to warm up. Pull the throttle full on and adjust H needle CW until the engine begins to speed up, but still 4-stroking. Correct adjustment is when the engine 4-strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed so that the chain stops turning, but the engine continues to idle. Hope this helps!
Jul 11, 2010 | Husqvarna Chain Saw Handle Models 50 51...
353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Oct 03, 2009 | Husqvarna Garden
Want start
Read the warm start procedure from the operators manual.
1. Pull choke (sets fast idle)
2. Push in choke (fast idle retained)
3. Make sure ignition is on, pull (usually once on my saw)
4. Advance throttle slightly to release fast idle.
I made the mistake ONCE of not setting the fast idle. My shoulder gets sore thinking about it. HTH
Lou
Sep 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a husqvarna 55. I put in a new carb, coil,
Preset both needles about 1-1/2 to 2 turns CCW from CW stop. Set H needle first after warm-up. At high speed, engine should 4-stroke with no load, but smooth out with light load(cutting wood). Set idle speed so that it will keep running, then adjust L needle so that engine tries to follow the throttle, but idles fairly smoothly. Readjust idle speed so that the clutch is not trying to drive the chain.
Aug 02, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
