Question about Garden
Battery keeps going flat sabre b/s 1438gsmodel
Battery has to be recharged ever so often 14 hp motor must'nt have alternator that I can see
  • Garden Master
  • 14,384 Answers
Check your terminal where your positive cable goes,replace it.
Posted on Jan 18, 2013
My battery keeps going flat
You need to get the alternator checked as it keeps the battery charged. If you have a multimeter, then connect it to the battery with the engine running. It should show around 13 to 14 volts. If it shows 12 or so, then the alternator is not working.
Jun 21, 2016 | 2007 Land Rover Range Rover Sport...
2000 MONTE CARLO BLINKERS DO NT WORK,AC/AND HEAT DO NT WORK,AND RADIO IS SAYING LOCKED UP
Does the vehicle start?
If not, then check battery voltage. If below 12.5 volts, then recharge the battery and retest system charging voltage (should be around 14 volts)
If battery is fine and vehicle starts, then check fuse box and wiring loom connectors.
Nov 13, 2012 | Chevrolet Cars & Trucks
The battery in my 1991 Audi 80 keeps dying, it's
renew the alternator ,its a bosch unit as original and the diode rectifier pack has a faulty diode ,change and get a bosch replacement unit and not a made in china cheapo their just juk and not worth the effort
Oct 15, 2012 | Cars & Trucks
Hi im having problems with my altinator the light is on in the dash and my battery is going flat in one day. The altinator is charging at 8 and a half the car is an eb ford falcon station wagon 92 model...
Hi Jenny,
Your alternator should be recharging at 13.5 - 14 volts DC. I would say that is what makes your battery flat if you are only recharging 8.5 volts. Replacing the alternator would be indicated. Since that model car was only produced in Australia and New Zealand I dont know the availability of parts in your area. I did locate one on Ebay.AU for AU$188.00 with the shipping and could be posted to you. You may check your local auto garage as to the possibility of rebuilding the one you have......Mike
Jul 11, 2011 | 2005 Ford Futura
The battery keeps running died
bad battery or your alternator isn't supplying the recharge necessary to keep it charged, with the motor off you should have a reading of 12-12.5 volts at the battery , once started it should read between 13.5 and 14 volts if its not, Its the alternator
May 17, 2011 | Buick Roadmaster Cars & Trucks
We have a new battery and alternator, but it still will not hold a charge.
You might have a defective alternator.Take a multimeter and check the voltage at alternator it should have 14-14.6 with engine running.If it does'nt take alternator back its defective
May 17, 2011 | 1997 Chevrolet Suburban
Will start for a couple of seconds then die. this is with a jump with out jump car will not start
Sounds like bad battery or alternator. Recharge battery and try again. Test battery and alternator
Dec 05, 2009 | 1986 Nissan 300ZX
Will replacing the alternator belt on 2000 hyundai recharge the battery that has almost gone dead in 24 hrs of non use? Is this belt replacement expensive and or covered under hpp 4b?
not its not coverd under hpp, but if the belt is slipping it wont charge very well, also an alternator was never intended to recharge a flat battery only to keep it toped up,,, if its tottle flat it would be best to recharge it with a mains charger first as the alternator will never fully charge it from flat,, unless you drive around the world first??? it would take years to do it,,,if ever,,,charge the battery first with a mains charger
Nov 12, 2009 | 2000 Hyundai Accent
Keeps getting flat battery when parked overnight
could be the battery is not great and needs replacing,or else the alternator is gone and not recharging the battery properly,also make sure no lights are left on anywhere to drain the batt,,,if the alternator is good it should show 14 or more volts when tested with a multimeter any less it should be replaced,,,
Oct 11, 2009 | 1993 Audi 100
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
