Question about LG 47LG70 42 in. LCD TV
Key lock flashes constantly. How do I stop it?
WDT790SAYMO dishwasher will not start. Appears locked. Help
Control Lock On
Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Jul 31, 2017 | Televison & Video
Clicking sound until key is inserted
Tri and cycle the key 2 times in the driver door lock Make sure you have good batery voltage at least 10 volts
Jan 16, 2013 | 1999 Lexus RX 300
Audi key remote is constantly flashing
u need to re-set it coz it could have lost the code in it
Oct 23, 2012 | 2006 Audi Q7
Installed ignition on 2003 sunfire, how do i reset security system
did you reuse the same pass lock sensor and key lock tumbler? if so the security system shouldn't have to be reset. if you replaced either lock cylinder or pass lock sensor then you have to turn the key to the start position and then to the run position and leave the key on for about ten minutes and wait for the security light to stop flashing. once the light stops flashing do the same process again. it may take up to three times to get the key code encrypted into the BCM. on the third time after the light stops flashing the car should start, if not then you may have another problem.
May 23, 2012 | 2003 Pontiac Sunfire
Key fob / immobilizer not unlocking door
sounds like the security part of the system went bad
take the key fob to the dealer and have it reflashed
if that fails replace the security computer or you can disconnect it from the car you won't have the system but the hazards won't come on unless you turn them on
Feb 25, 2010 | 1997 Volkswagen Golf
Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Aug 05, 2009 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Car wont start, will not reset, security light always on
try locking and unlocking the drivers door with the key. [sometimes if you reach to un lock door through window it it sets off security]
May 15, 2009 | 2003 Oldsmobile Alero
VW Passat failing to start/security alarm issues are they linked?
Usually on the passat, if the immobiliser is on, there is a yellow key symbol flashing on the clocks as you try and start it. Do the doors unlock with the remote key? If no flashing light and the key fob working, i would be looking at possibly starter relay. This is either located under the fuse box or under a plastic cover near the windscreen under the bonnet. (hood)
Jan 21, 2009 | 1999 Volkswagen Passat
LG 47LG70 42 in. LCD TV Logo
26 people viewed this question
Computer Repairing
Computer Repairing
