Question about Electronics - Others
Please insert a disk into Drive E
I recently bought a 4Gb USB stick and initially it seemed to work fine. However, one day when I plugged it into my laptop, when I tried to access it, it came up saying following errors,
Errors :
1)I cannot format the pendrive.
2)when i double click on the removable disk,it says
           Please insert a disk into Drive E : ''
3)i used a pendrive format utility but the problem persists again.
4)i tried to format it using gnome also,but of no use.
The light on the USB stick is on, and I can see it in my computer, but I can not access it as it gives me the same error message. I have tried to google this and I have played around with the drivers in device manager, but to no avail. I am using XP Pro (SP3) and usually have no problems with USB devices.
please help me..without going to service centres.
USB DEVICE NAME : Transcend JF V 10 ( 4 GB )
  • Ananth Kumar Feb 03, 2009
    Thank u
    Dr_Joseph
    i never remove the pendrive  directly.
    i use safely remove the hardware only.
    but it is not in the warrenty.
    but i need to get rid of this........................problem
Transcend provides a online recovery tool.just download that and format your pendrive with it.....that will solve your problem 100%.....
Posted on Dec 31, 2009
  • 86 Answers
Probably you removed the pen without properly stopping the device.
usb pens are sensitive about this. you must use an icon that is on traybar to stop usb storage devices before removing them.
now it is probably in read only mode or damaged.
if it is still inside warranty try to replace it.
Posted on Jan 26, 2009
My pen drive is not working properly
Posted on Feb 03, 2010
2 Suggested Answers
  • 79 Answers
SOURCE: transcend JF V30/4GB pendrive not detected??
1. try transcend drivers http://driverscollection.com/?file_cid=39278936334676929bc3679940f
2. Please find the utility which will help you to recover the trancsend Flash USB drives, if gone bad.
Find the utility @ http://www.esnips.com/web/USBfiles/
All you need is the Valid Serial No of the USB flash drive.
Refer the Link to find where the Serial No could be for your drive.
http://www.transcendusa.com/Support/GetSerialNo.asp?FldNo=3&LangNo=0&PType
3.contact them for support :support email id: techsupport@transcendusa.com
Posted on Aug 07, 2009
When i attach my 4gb kingston usb then the usb do not work and a message appears that ,please insert a disk into drive G PLEASE SOLVE MY THIS PROBLEMM I AM VERY THANKFUL TO YOU
  1. Download and install the HP Drive Key Boot Utility
  2. Open the desktop icon and select the correct flash drive under device
  3. Select the file system you want to format to (FAT, FAT32, NTFS)
  4. Tick Quick Format
  5. Click start
  6. Officially this software (HP Drive Key Boot Utility) is meant for HP disks, but unofficially it seems to work fine at formatting most flash media, even digital camera cards.
Aug 24, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Dec 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
I had the same issue with my 4GB Sony Memory Card when I put it in my memory card slot on my computer. I have a Toshiba laptop, so what I did that fixed the problem is I went to Toshibas Support Webpage in the downloads section and under the CATEGORY: Driver Card Reader and re-downloaded: Ricoh Card Reader for Windows 7 (32/64)(v3.54.02; 09-04-2009; 4.94M) and once I did that it read my memory card and didn't give me any more issues and it opened all my pictures. Of course if you don't have a Toshiba then you would go to your manufacturers web site and see if they have the same thing, because that is what fixed my issue and it didn't take long at all.
Jun 02, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
SanDisk Cruzer Titanium 4gb NOT WORKING !!!
bad news bro, the disk isnt initialized. your data is long gone only a data lab may get them back
Mar 10, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
I recently bought a 4Gb USB stick and initially it seemed to work fine. However, one day when I plugged it into my laptop, when I tried to access it, it came up saying following errors, Errors : 1)I cannot...
You do not need any drivers in windows for these drives if you are using XP/Vista. These are generic volumes. Try deleting any mention of the driver in device manager and let windows install it automatically. This sounds a lot more that your pen drive is dead. Time for a new one. Can you borrow a friends and plug it in to test the USB port is ok?
Jan 25, 2009 | Computers & Internet
USB FLASH DRIVE
Try Formatting the flash-drive, Quick format will do (fat 32)
if it still not detecting, might as well send it back to store where u bought it, They will replace it if it's still under warranty.
Apr 28, 2008 | Computers & Internet
USB problem
It seems the DVD player is not recognizing 4GB flash disk. I have checked and I can't see that there is a firmware update for this model though I can see one for the DMR 50. Try contacting Jamo support
If you have another usb lead or a lead that can collect two usb sockets to the flash disk you may find this works as there is more 5 volts power available from two sockets.
We depend on you rating solutions - I hope this is useful.
Mar 24, 2008 | Jamo DMR 60 DVD Player/Receiver
Unable to access files on SONY memory stick
Hello. Windows will automatically give it the next drive letter available whenever you install it on a computer. That being said, it sounds like the stick itself is bad. It won't work on any computer so that rules out a computer issue. Since you cannot access it once it recognizes the drive, the media has become corrupted or gone bad. Try right clicking on the drive and formatting it but if that doesn't work, I'm afraid its toast.
Jul 02, 2007 | AOpen AX4B Pro-533 (91.88M10.102)...
Electronics - Others Logo
3,681 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
