Question about Homelite Yard Broom 2 Leaf Blowers
My yard broom 2 starts but doesnt keep running
I replaced the fuel lines fuel filter primer bulb and spark plug. starts but only idles for a few seconds then stalls.
  • 4 Answers
Carburator needs cleaning out
Posted on Jan 18, 2013
  • 1 more comment
  • adam lamore Jan 18, 2013
    should i just spray carb claener on it or do you think it has to soak
    also after i prime it a few times and it fails to stay running some fuel leaks into the airbox any thoughts on that
  • Jemayne Sol
    Jemayne Sol Jan 18, 2013
    soak it
  • 564 Answers
SOURCE: My homelite will no longer stay running.
i would start at the muffler & pull it off ,,ck out the exhaust port where u just took the muffler off,,see if it is loaded up with carbon,,need to clean it out,,i find then in the trash,,& take them apart,,and most of the time its just that,,because u are using a gas & oil mix,,try it ,, hoped it helped,,
Posted on Apr 15, 2010
  • 246 Answers
SOURCE: I have a Homelite Yard Broom gas blower that won't prime/stalls.
Hello sodevine69:
>>From your Description it Sounds like the Fuel Filter in the Tank Requires Changing, the Carburetor Metering Jet is Stuck, the Carburetor Filter/Screen is Restricted and Requires Cleaning/Replacing or the Carburetor Requires Cleaning.
>>The Following is a Basic Instruction File I made for Replacing the Fuel Lines and the Filter on Chain Saws and Trimmers. Any Input is Appreciated.
>>The Fuel Line is Pushed and Pulled (I Use Long Needle Nose Pliers) Through the Small Hole Until the Hose is Out the Fill Hole about a 1/2".
>>You can Also Use a Coat Hanger with a Small J at the End to Hook the Filter in the Tank and Pull the Filter and Hose (if Detached from the Carburetor) Out the Tank Fill Hole Enough to Replace the Filter.
>>Then Attach the Filter and Pull the Hose Back Until the Filter Lays at the Bottom of the Tank Just Below the Fill Hole (or so it is in the Bottom of the Tank and will Rest in the Fuel Mix when Turned at Common Angles the Unit May be Turned to During Operation.
>>**Hint: Use Plenty of Spray Lubrication at the Small Hole as you are Feeding in the Hose. It Slides Easier.**
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace are the Needle Valve and Metering Pump Diaphram.
>>The Metering Pump Diaphram is Under the Carburetor Plate with 4 Small Screws in it.
>>The Dowl on the Diaphram should Just Touch the Metering Jet Actuator Arm.
>>The Actuator Arm is Adjusted by Carefully Bending the Actuator Arm Up or Down to get the Correct Clearance.
>>If you Order a Kit, then Replace All the Old Components with the New Ones in the Kit even if the Old Parts Look Good.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine.
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
panilling9
  • 284 Answers
SOURCE: spark plug
take your old one with you to walmart or an automotive store or hardware store
Posted on Jul 07, 2009
  • 279 Answers
SOURCE: homelite 2 yard broom 170
You have found the HI and LOW settings. The idle wouls be set by starting and warming the unit up. After warm up, take your screwdriver and turn the LOW screw OUT until the engine starts to lose RPM's. Turn the screw IN until it starts to lose RPM's. Once you have those two points, back the screw about halfway between. You can do the same for the HI setting if you need to. Good luck...Lee
Posted on Aug 28, 2009
bbreton
  • 437 Answers
SOURCE: PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
Posted on Nov 11, 2009
When I pump the primer bulb, why doesn't it fill with fuel and stays collapsed?
new carbies start around $25.00 us on e-bay so get a new carby
take it to a mower shop for a service
rebuild the carby using a new carby kit
Nov 28, 2015 | Husqvarna 125 Bvx Leaf Blower Lawn Yard...
Will not start
More information would be nice. How old is the cultivator? How long has it been since it last ran?
Possible causes for the primer bulb not to fill: 1. the bulb has a small hole in it (need to replace the primer bulb, usually a pretty easy job, just remove a couple of screws, remove the old bulb and install the new one). 2. One of the fuel lines may have a break or hole in it. If the cultivator is old enough a fuel line may have dry rotted and came apart.
A couple of things to try: Put fresh fuel in the tank then remove the air filter and put a few drops of fuel in the carburator then try to start the unit. If it starts an runs for a few seconds and dies the problem is the carb. is not getting fuel to the engine. If it still will not start check the spark plug. Is it fouled? Worn out or broken? If in doubt replace the plug.
May 20, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Poulan
take the muffler off and run it after seeing that it runs strong open the muffler and clean the screen inside (it's made to open)
Jul 03, 2012 | Garden
Will not start
After 3 years, the fuel lines may start to decay and the fuel filter in the tank is likely to be plugged. Check the air cleaner and muffler for plugging also. Remove the spark plug and check for spark which should be blue and snappy. If nothing, try a new plug gapped at 0.020". A properly running two-stroke plug should have a light to medium tan color on the interior insulator. A black insulator indicates an overly rich fuel mix or jet setting. A white insulator is either new or running too lean which will damage the piston and cylinder if allowed to continue to run. If you get spark, pour a little mixed fuel into the plug hole and try to start the engine. If you get a few pops, then concentrate on the carburetor and fuel feed. Does the primer bulb bring in fresh fuel when pumped? If not, is the bulb itself damaged or hardened? The primer is supposed to pull fuel through the filter, into the carburetor filling all spaces inside, then out to the primer pump and the excess returned to the tank through another line. Hope some of this helps!
Jun 23, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My homelite chain saw will only run after I prime the fuel once gas runs out engine stops running but reprime fuel the saw will run until fuel runs out any suggestions
Did you replace the fuel lines? If the filtered hose feeds the primer that is exactly what happens. Your fuel system should be similar to this.
Fuel Line Replacement
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH Lou
Nov 30, 2009 | Homelite Garden
HTH
Good Day.
Nov 11, 2009 | Homelite 'Yard Broom' Leaf Blower
Leaf blower will crank only when spark plug is dipped in gas and re-inserted
fuel system needs to be cleaned, carburetor diaphragms and gaskets replaced, check fuel lines, filters, primer bulbs
Nov 07, 2009 | Homelite 'Yard Broom' Leaf Blower
Won't start
drain fuel tank. keep depressing the primer bulb until it is clear. drain tank again. remove carb cover and disconnect lines one at a time. keep depressing primer bulb to get rid of excess gas. remove spark plug an turn engine in a position that the spark plug inlet is facing the floor, pull starter rope a few times to get rid of gas in the engine chamber.
Oct 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Willnot start
Check and,or; replace your fuel filter
May 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite Yard Broom 2 Leaf Blowers Logo
142 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
