Question about Nokia 3310 Cellular Phone
NOT OPENING , WENT ON THEN OFF AGAIN
ONCE I PUT POWER ON IT WILL AUTOMATICAALY WENT OFF.
  • Anonymous Apr 11, 2009
    not opening, went on then off again
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
Sir..
the phone memory should be reinstalled or reprogram to fix the problem
Posted on Feb 03, 2009
I have a power force power mop i used it once and it worked but when i went to use it again it leaked when i inserted the bottle
You may try putting just a dab of Vaseline around the opening of the bottle that goes in the cleaner. Also Teflon tape makes a good seal. Either one should work. Good luck
Sep 11, 2017 | Vacuums
I was driving and then hit the brakes then went to go again I had no power to the wheels. It won't move like it's stuck in nutral
Once you get the vehicle to a safe location, put vehicle in park and turn off the key. Wait about sixty seconds and start vehicle. Try to move vehicle again safely.
Aug 20, 2014 | Cars & Trucks
Our power went out a week ago and since then our Kitchenaid side by side will not despense ice from the door,it makes ice but will not dispense. We cleaned it our thinking ice had melted and then refroze...
The auger motor is frozen. Open the freezer door and remove the 4 screw holding the auger motor. Unplug the harness. Put it on the counter and use a blow dryer to defrost it. Shake out the water thats inside. Do this until u think all the water is out, then put it back in door and plug it in. You should be good from then on. If you loose power again. Remember to remove ice bucket or water will leak into motor again.
Jul 17, 2011 | Refrigerators
A/c and heater fan has gone out. It went out once
change the relay or check the ground it is one or the other gm is notorious for this
Jul 16, 2010 | 2003 Chevrolet Silverado 2500HD
2002 jeep liberty sport just died, worked fine 10 seconds earlier
You can check fuses using a test light or (better) a volt meter. This is done by probing the back opening at each end of each fuse while the negative lead of the meter is connected to a good ground. any fuse that shows power only on one side has failed. Some fuses will only show power with ignition on. Check all grounds as well, sounds like you may have a loose connection somewhere or a bad control module (why clicking was heard)
Jun 28, 2009 | 2003 Jeep Liberty
Screen wont come on
Does it only light up when you adapter is plugged in? If so try taking out the battery and making sure it is in correctly. Press the power button under the screen on the side if the unit and the middle circle in the directional key pad, there should be a menu that comes up.
Jun 17, 2009 | Jazz DV-179 Digital Camera
2003 pontiac montana pulling itself, in park - 3000rpms
check your throtle cables and plate in throtlebody for opening & closing properly,
Feb 07, 2009 | 2003 Pontiac Montana
Setting multi processors AMD Phenom X4 9550 on ECS A 780 GM-A
The Motherboard should automatically detect the type of CPU. Mine did. I started off with a dual core and went to a quad and did nothing. After replacing with the new quad core the CPU was automaticaaly recognized at start up and it required me to do nothing.
Sep 07, 2008 | EliteGroup ECS A780GM-A Motherboard - AMD...
INVICTA BABY LUPAH NOT WORKING
There is no way to answer your question without my being able to see the watch and opening it up. It may or may not need a new movement, just some regular maintenance. You can email me if you want: chiefo@wbcable.net
Mar 27, 2017 | Watches
Not powering on
Where is the Fixya? I have the same problem on a C-7000. Took it out of the purse and it's nada. Didn't drop, didn't get it wet. Working one minute, totally dead the next... Anything?
Dec 07, 2007 | Olympus Camedia C-720 Ultra Zoom Digital...
Nokia 3310 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
