Question about Frigidaire FMV156DC Microwave Oven
Door won't shut - Frigidaire FMV156DC Microwave Oven
  • Official Brand Answer
  • 4,342 Answers
Hello - Sounds like the microwave made possibly have a damaged or broken door latch. I suggest contacting a professional to move forward accurately and to assist with the repairs.
Posted on Jan 23, 2013
Won't shut off
You may have a problem with a door switch or door switch mount, or there may be a shorted relay on the control board, which can easily be repaired.
Our help file on door switches is here, and the Advantium 120 service manual is here.
You can order GE parts from the Pros here.
Jun 06, 2013 | GE Advantium 120 Convection/Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
I have a Haier microwave and tonight after heating some food, I went to close the door and upon closing it, the carousel started turning and it won't shut off.
It sounds like one of the door switches has become defective, each must be disconnected on the one side and tested with a digital meter using the ohms scale.
Jun 07, 2012 | Haier Microwave Ovens
Turntable and light won't shut off.
This is usually caused by one or more defective door switches, or possibily the keypad control board.
Apr 16, 2012 | Emerson Microwave Ovens
The common cause is one or more bad door switches, or possibily the keypad control board.
Apr 16, 2012 | Emerson Black Microwave Oven
The turntable and light won't shut off when not in use
The door switch, one or more are a common problem, or the keypad control board, "less likely"
Apr 16, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
Power won't shut off when door closes
One or two micro switches are defective, "door switch"
Apr 02, 2012 | GE Profile Spacemaker Over-the-Range...
The microwave door seems to be loose. The door will remain shut, but the light is on in the microwave and it won't run until I push upwards on the door. How can I tighten the door hinge?
you need a door interlock switch bracket adjustment; or, possibly one of the microswitches replaced on that bracket. it is behind that control panel.
May 16, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Frigidaire FMV156DC Microwave Oven Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
