I need to replace my keyboard
I removed all the screws on the back but theres 2 more i cant figure out where to remove them
  • 18 Answers
Need more information - please post your machines model # please.
Posted on Jan 18, 2013
4 Suggested Answers
SOURCE: Keyboard replacement
Every notebook keyboard that I have replaced is accessed through the top. There is usually a bezel near the hinge that either pops off or may have some screws accessable from inside the battery or other compartment from the bottom. Once the bezel is removed you will see from 2-5 screws holding the keyboard down. Remove those, and gently lift up the keyboard to check the attaching cables underneath. Look carefully at the connectors, some simply unplug others are a ribbon cable that you lift a part of the connector and then the ribbon will come out. Do not pull the cable out!! You may break it if you pull it.
Good luck. I hope this will help.
Posted on May 07, 2008
SOURCE: cant get the case open to replace the keyboard and DVD drive
You MUST get a service manual... Google this...
exact-name-of-your-laptop service manual pdf download
Eg: Toshiba D6700 v3 service manual pdf download <<---Then enter. Then this will give you step by step how to?
Posted on Mar 06, 2010
  • 162 Answers
SOURCE: I need to remove to top panel (with Keyboard) of
Hi. I think the best thing to do here is to contact Lenovo tech support regarding this matter because you will not find any manuals online on how to disassemble this Y530 but I thing Lenovo tech has a manuals on how to disassemble this machine. I am a Lenovo tech that's why i know this information, try calling them and they would best help you on your problem, also double check if you're still under warranty. If I could just have a copy of that manual then I would gladly send it to you or teach you onthat issue. This there tech support hotline 877-453-6686. Hope This Helps..
Posted on Jun 08, 2010
How to remove keyboard
The upper part of the laptop don't have screws. Just with the help of flat screw driver remove the strip on the upper side of the keyboard. After removing you will see two screws down with the keyboard . Remover the screws and remover the connector of keyboard that connects the keyboard with the mother board.
Put new keyboard and put the keyboard connector back. Screw it back and put the strip back.
Step---1
Step----2
Step---3
Dec 18, 2014 | ASUS F75A-Eh51 Laptop Computer - 3Rd...
What screws do I remove to replace the keyboard on the Toshiba Satellite L505D-S5983?
Hello there
Please follow these easy instructions with picts ok
Lift up the keyboard bezel using a small flat-head screwdriver.
2>
4'Lift up the keyboard and place it on the laptop cover so you can access the keyboard cable connector.
Unlock the connector and pull the cable.
Mar 01, 2011 | Toshiba Satellite L505DS5983 Notebook
How can i open my acer 3935 spilled with ice coffee a little , so i wanna clean it out..i cant remove the keyboard
First of all make sure you disconnect power cord and remove battery. Some screws on the back will be responsible to keep keyboard in place. In HP laptops screws are underneath the battery so you want to look there. Also undo screws form back near LCD at the top and try and take this video may help you http://www.ustream.tv/recorded/4248060. Good luck!
Apr 28, 2010 | Acer 91.63X07.001 Keyboard
How do i remove the hard drive?
Had the same issue, couldn't find a solution on-line, but I figured it out. First remove the battery and the screws underneath it. Then remove all the screws on the bottom of the laptop. Remove the optical device and remove the 2 or 3 screws holding the bezel to the base.
Here's where it gets tricky. There is one more screw under the keyboard, right where the F6 key is. Can't get to it until you remove the keyboard, but there is no obvious way to remove the keyboard.
Pry the case apart a bit and look inside, there are two plastic release cllips that hold the keyboard in. Very carefully retract these clips and remove the keyboard. Then you'll see that last screw. Take it out and you can slide the top bezel out of the way without removing the touchpad cable.
Replace the hard drive and put it all back together.
Hope this helps
Stillwater Computer
Dec 13, 2009 | Sony VAIO VGN-N220E/W Notebook
How to remove Insperon 1725 keyboard
Keyboard Dell? Inspiron? 1525/1526 Service Manual NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer). NOTICE: To help prevent damage to the system board, you must remove the battery from the battery bay before you begin working inside the computer. Removing the Keyboard Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer. Slide the keyboard cable out of the keyboard connector. 1 screws (2) 2 keyboard 3 keyboard tabs (5) 4 keyboard cable 5 keyboard connector latch Replacing the Keyboard Slide the keyboard cable into the keyboard connector. Rotate the keyboard connector latch to secure the cable. Align the tabs along the bottom of the keyboard and slide them under the palm rest. Press on the right edge near the top to snap the keyboard into place. Replace the two screws on the top of the keyboard. Or else if this is not clear you can also visit Support.dell.com Thanks Deepak
Oct 30, 2009 | Dell Inspiron 1526 Laptop
HP Compaq nx9010 CD drive replacement
You are correct.
The screws for the dvd drive is under the keyboard.
there should be 2 tabs one above the f4 and the other above f12 take a regular head screw driver put it where those tabs are and gently pull down towards the touchpad and the keyboard should come up easily.
Now under that keyboard in the center you will see a opening and inside that opening you will see 1 philip head screw remove that by turning counter clockwise.
Right below where you removed that screw you will see another opening which has another philps head screw in it.
Remove that screw counter clockwise and the dvd rom should pull straight out with ease.
To put it back together just reverse the steps.
If you need further assistance do not hesitate to ask.
Dec 03, 2008 | HP Compaq Business Notebook NX9010
Replacing the keyboard on the acer 7720
remove the two silver colored screws underneath the battery.
Remove the upper part of the lightgrey top (the part with the speakers and the on/off button) which is clicked on.
Probably the backside is the best place to start...
Now you can lift the keyboard and remove the cable by first releasing the connector and pull out the flatcable.
Aug 29, 2008 | Acer Aspire 7720 Notebook
Acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
May 07, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
