Question about GE JTP45 Electric Double Oven
Oven light bulb filiment keeps braking after aworking a few times
I replaced the oven lightwith a 40W Appliance Bulb. A few days later, the bulb was bad again. The filiments were open.
2 Suggested Answers
oldTech2332
  • 2341 Answers
SOURCE: Hi, I have a GE
What is the model number for your oven reply with it and i will give you the GE part number for that light bulb
Posted on Sep 17, 2011
Bottom oven lights keep burning out.
The oven bulb is different from an appliance bulb. The glass and base are specific for the high temperature application that is seen in a oven
The link from sears shows a sample of an oven bulb and the price represents the special characteristics.
I have seen where some bulbs are rated at 130 volts?
Range Oven Light Bulb Part Number 316538901 SAME DAY SHIP GUARANTEE from...
This link from Amazon relays some of the one star reviews of the appliance light used in the oven application. All ovens are maybe not equal where the heat may be more significant in one make over another.
Amazon com Customer Reviews GE Appliance 21188 40 Watt 415 Lumen A15 Light...
Another set of reviews that again show problems in some applications for bulb life.
40 Watt Incandescent A15 Clear Appliance Light Bulb 416768 The Home Depot
Not many reviews on this bulb. The 130 volt rating is an indicator of longer life? Of the choices I wood choose the following.
Sorry I couldn't help you more. Disappointing that no bulb stands out as the very best.
Bulbrite B40A15C 130V 40 Watt Incandescent A15 Appliance Bulb Clear Amazon...
Jan 09, 2016 | Ovens
Oven light switch
replace the bulb with an appliance bulb found at any store that sells bulbs
Nov 18, 2013 | KitchenAid KEBC107 Electric Single Oven
JJW9527BAQ change light bulb
40w appliance light bulb.
Jan 12, 2012 | Jenn-Air Ovens
How to change oven light
Which model Whirlpool range do you have? For most Whirlpool ranges that I have used , the oven light is covered by a screw-on glass cover. When the oven is cool, unplug the range, open the door and turn the cover counter-clockwise (to the left). Then remove the 40W bulb (again counter-clockwise rotation). Replace the bulb with another 40W appliance bulb. Then replace the cover by turning it clockwise until it is tight. Do not over-tighten either the bulb or the cover. Then plug in the power cord for the range. (Unplugging the unit makes sure that you will not get shocked if anything goes wrong. Sometimes the bulb may break in the socket - in that case, use pliers to unscrew the base of the bulb before replacing it with a new bulb.)
Whirlpool has the manuals for most of their appliances on their support site: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
I hope this helps.
Jan 11, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Hi, I have a GE Profile oven that needs a light bulb replacement. It is NOT a standard 40W appliance bulb as stated. What bulb is it?
Sep 17, 2011 | GE Profile JTP18 Electric Single Oven
BULB REPLACEMENT
that is just an 40w appliance bulb theres probably 10 diifferent manufactures that make this bulb and want allot for them u can find one at a local lighting store, or local appliance store,, this is a common bulb, to get to it u must remove the glass cover that covers the bulb. it should screw on to the receptacle.. hope this helps
Feb 05, 2010 | Jenn-Air JJW8230D Electric Double Oven
Replace oven light bulb? magic chef wall oven
for model 9815xub, the oven light consists of a light bulb cover(clear plastic, sometimes called lens) the light bulb receptacle( pressure mounted against the back wall of the oven ) and the light bulb, standard appliance bulb that screws into the receptacle, the same as the lens, it also screws into the receptacle, twist counter clockwise to remove both the lens and the bulb. as a reference try the following site:
www.partselect.com/ and type your model number in the window, then click on the oven cavity breakdown to view thwe assembly.
Jan 31, 2010 | Whirlpool RBS275PD Electric Single Oven
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 | Ovens
Need part number for oven bulb
looked up the bulb part is no longer available, but it looked like a regular appliance light bulb, remove the old one no diffrent then any appliance bulb you can buy in the supermarket if need be
Feb 19, 2008 | Ovens
GE JTP45 Electric Double Oven Logo
22 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
