Question about Maxell Electronics - Others
Maxell 2 tb
Will work initially when i try to add or sync it replies (not responding) and freezes up
3 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: syncing with windows media player
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
  • 758 Answers
SOURCE: Sansa e270 synchronizing problem
It might be a device certificate error..what you will need to do is to format the device..Keep in mind that formatting the device will delete all the songs you have in there..to format click menu,settings and then click on format..if that doesnt work you will have to update the firmware on the device...Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
I hope that helps
Thank you
Computerrep
Posted on Aug 20, 2008
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
3 lights red and freezes
Hello Sir
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shad0w
May 20, 2010 | Microsoft Xbox 360 Console
Sony Vegas 8.0 Freezes when "Initializing Audio Engine"
Have you upgraded you Sound Drivers? Tried reinstalling Vegas? or Looked to see if a Patch or Update is available for Vegas?
Apr 04, 2009 | Sony Vegas Movie Studio Platinum 8
Lan
If you are referring to the Ethernet cable, initially, it can then be presumed that your computer then has no LAN port. What would be required is purchase and installation of an add-on networking card. Although it is quite rare for most modern desktops not to have a built-in LAN port. The image below is an example of an add-on PCI LAN card
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Linksys Wireless-G Broadband Router
Olympus Master 2 no longer responds.
some virus programs can cause havoc some softwares. may need to uninstall program and clean the computer
Jul 02, 2008 | Olympus FE-280 Digital Camera
Zen Vision M freezing during music upload.
Try to add your music a bit at a time instead of your whole library at once. That will freeze it. You can also try sync with Window's Media Player, which works a lot better than the Creative software.
Nov 29, 2007 | Creative Labs ZEN Vision:M Digital Media...
Hot sync does not complete!
Something similar happened to me due to incorrect periodic entries in the Datebook, try disabling all elements in the Hot Sync, try it, and if it works, then add them one by one until you find the offending one, then focus on clearing that DB.
(Actually i simply stopped synching Datebook since i didn't wanted to loose all the history of appointments i have).
Nov 04, 2007 | Palm TX Handheld
Electronics - Others Logo
Top Maxell Electronics - Others Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Maxell Electronics - Other Expert? Answer questions, earn points and help others
