Question about Ovens
Why would my ground get so hot it would melt plastic
    Scholar:
  • 197 Answers
A very likely solution is that loose connections cause the Lugs (connections) to heat up. It is a good idea for people to ever so often check connections in your Breaker Boxes or even behind an Electric Ranges or any large electrical unit. (knock breaker for safety).
Posted on Jan 18, 2013
I melted a plastic bowl in oven I scraped most of it out while it was hot but now I have thin spots of plastic film, I need to know how to clean without ruining the surface of my oven cavity
Warm the oven to 100c allow to cool for 15 mins with door open then lightly scrub with a ball of aluminium foil this won't scratch ad foil is softer than the oven lining
Jan 06, 2018 | Ovens
The plastic ties were left on the oven rack. One melted . How do I get the plastic off the bottom of a self cleaning oven?
Warm Method Both Good Housekeeping and the website Hunker describe this method for self-cleaning ovens. Hunker warns to NOT use the "cold method" which is reserved for other types of ovens. And the Good Housekeeping site says if the method proves unsatisfactory, that the floor or bottom plate of the oven might have to be replaced.
(That said, I suspect if you pull out oven racks and apply some ice to any plastic on it, the plastic might become brittle enough that tapping it with a spoon and prying at it with something wooden or finger nails might remove a lot of it. No scraping with the spoon!)
Here is the primary process for the oven.
Self-cleaning ovens require heat to remove the melted plastic. This method also works on heating elements with plastic on them. Step 1 Turn the oven on to the lowest heat setting. Only leave the oven on long enough to make the plastic soft and pliable.
Step 2 Scrape the melted plastic with a wooden utensil such as a spatula or spoon. The wood protects the surface inside the self-cleaning oven. When you get all off that you can, the self cleaning feature may burn off the rest. That WILL be smokey and exude an unpleasant smell while it does it. Open windows and keep pets out of the area (and yourself) while it goes through the clean cycle. Do NOT use a screw driver to try and remove the plastic.
Aug 26, 2017 | Ovens
A black plastic meat container melted all over the bottom of the oven ,can I self clean the oven once it cools will it come clean?
not safe, the plastic will most likely release toxic fumes when heated that hot Try warming the oven until the plastic is soft, then scrape it off.
Apr 20, 2016 | Ovens
Melted plastic on heating coil
you can not remove the plastic safely please replace the heating element
Sep 30, 2013 | Frigidaire (FEB30S7D) Oven
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
Inner glass has fallen out
Have an appliance repairman check if the oven is still under warranty and if any recalls on the door are in force.
Dec 17, 2017 | Baumatic B180SS And B60SS (Bundle)...
I inadvertently placed a plastic bag on a hot ceramic hob. It melted and hardened on to the surface. How can I clean it without scratching the surface?
Use a stanley knife blade. or a razor blade. you will not scratch it if you are careful
Please rate my solution.
Thanks.
Aug 12, 2009 | Ovens
Oven door locked, can't get plastic cover of control panel off
you have to first remove the side trim there should be some screws in the side usaly 2 but sometimes 4 ---you could have replaced just the fuse for less than 20 dollers
Aug 09, 2009 | KitchenAid Architect® KEBS277S Electric...
Melted plastic lid in oven - how can I remove it
Any oven cleaner, like easy off will work on this but it may take more than one application. You can actually begin with your hair blow dryer and a putty knife by heating the plastic up enough to scrape most of it off. Then let the oven cleaner do the rest.
May 17, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Gas oven - - melted plastic inside
You can remove the bottom oven panel and look under it. All you have to do is remove the oven racks and locate the screws that hold the bottom panel in place. MOST ovens only have two of them. Once you have the crews removed, the panel slides back a bit, then lifts up. If there are any heavy deposits of melted plastic, remove it like you did before. Any residual material can be taken off with some fine emery paper. Wear a dust mask and vacuum all the dust out of the oven. DO NOT use this method on the oven wall as it may scatch it. This is only for anything that may have dripped below the oven pan. You may have an odor to the oven for a while, but as long as you have nothing else melted inside this should go away. Try running it on a cleaning cycle AFTER you've inspected the oven & cleaned out the remaining plastic. This will burn off anything left behind. I hope this helps you.
Feb 12, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
