Question about Amana Refrigerators
Instruction manual needed.
I have just bought a amana sde by side fridfe freezer. it is white withblack handles and lighting display fascia. the model no. in fridge reads srde528sb w.cant find any other numbers.serial no. sn 9603237958. i dont know how old this model is as bought second hand. can anyone help?
You might find it at kitchenmanuals.online That is the web address and they have manuals for many different models of the Amana side-by-side refrigerator.
Posted on Jan 25, 2009
What are the dimensions of model ABB1927DES ?
It needs a 30" opening that is 67" High and 33" deep with the handle.
Here is a link to all the specs and more information
http://www.ajmadison.com/cgi-bin/ajmadison/ABB1927DES.html
Here is a link to the manual to help with installation.
ABB1927DES AMANA AMANA REFRIGERATOR Manual
Feb 18, 2015 | Amana ABB1927DE Bottom Freezer...
How do I reverse the door handle on my refrigerator? Model # ARB2217CSR - Stainless steel bottom refrigerator
Hi, the easiest thing to do is follow the instructions on page 5 of the manual, here is a link if you don't have it
http://shop.amana.com/assets/pdfs/literature/12642722.PDF
Hope that helps
Aug 10, 2010 | Amana ARB2217CSR Bottom Freezer...
17 yr old Amana frig freezer isnt cold enough lite display nowork
No it's not worth it! Sounds like its low on freon and they don't make R12 anymore, junk it
Jul 06, 2009 | Amana ASD2625KE Side by Side Refrigerator
Amana SR520SSide by side fridge freezer: How do I take off the dm
CLICK HERE for a PDF version of your use and care manual.
CLICK HERE for Installation Manual.
Page 3 of the installation Manual has the instructions on removing the doors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 25, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Feb 12, 2009 | Amana AFD2535DES French Door Refrigerator
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Refrigerators Logo
179 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
