Question about GE 46GW945 46" Rear Projection Television
Also had a power surge,...
And now my 46gw945 has a black bow in the top of the screen, and the colors are all screwy can anybody tell whats wrong???
  • 398 Answers
The GE (actually RCA) 46GW945 uses the PTK195 chassis. There is a separate power supply for the convergence circuits in those sets. The earlier versions used a switching transistor but most sets use the STK730-010 power IC. I have seen many of those IC's stop working after a power surge, resulting in very curved sides with screwy colors. You can remove the back and you will see the 2 main boards at the bottom of the set. The convergence power supply board is mounted above the board on the right (when viewed from the back) and has a pretty large black IC mounted on a little heat sink, labeled STK730-010. Replace that IC and the colors should return to normal. If you do not have experience replacing IC's and working on TV's then allow a qualified tech to handle it for you.
Posted on Jul 13, 2007
SOURCE:
My tv has alot of different colors on the screen when your watching it and the top of the screen is bowed in and you can see a black space between the picture and the top of the tv what is wrong with it?
This is a problem with the convergence circuit. It is relatively easy to fix. It is caused by either poor solder connections or defective convergence ICs. Please update this with the model number of the set so I can provide the probable parts and costs.
Thanks,
Dan
Mar 27, 2011 | RCA Televison & Video
The picture seems to be sliding down the screen of my Samsung HCN553W, I can still watch it except for the top 4-5 inches in the top left corner, it's black. Does anybody have any idea what it could be?
Ur tv it beginning to create and will develope a simtom call "Convergence alignment"These problems will delope in to the picture will have shades of colors like red or blue shadows,the picture bows in coners and colors will misaligns,the picture look like u watching a 3D movies,and the tv sometimes,just die and making chirpings sound.This problems very common in DLP tvs,it will develope just sonner or later that all.The covergence problems,the only way to fix are to take the tv aparts take out the Pc board call The Convergence board.Change the 2 STK convergence ICS,and some or all it supporting resitors and pico fuses.
May 06, 2010 | Samsung HCN553W 55" Rear Projection...
I have a magnavox 52 inch tv the picture got a mirred look to it then went black but can still hear te sound can you tell me what's wrong
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 17, 2009 | Philips Magnavox 51MP392H Rear Projection...
RCA REAR PROJ. SCREEN BOWS AT TOP AND COLORS DOUBLED
Hi, thank you for visit fix ya.
Resolder all connections around fly back ( check for open pico fuse).
if still problem, replace convergence board.
Thank you
Jul 27, 2009 | RCA HD52W58 52" TV
TV Turning on and off, left side of picture is not lining up, bowed in center
Most likely you had a power surge issue that caused the tubes in your crt projection to malfunction. I would recommend having a service call done to find out the issue
Apr 22, 2008 | RCA P61960 61" Rear Projection Television
Zenith IQ6097DT 60 inch big screen
Convergence circuit repair plus fuse in the power supply,
usually 300.-400.00.....................if you are mechanically
able and can solder well,it is possible to DIY...................T.
Mar 31, 2008 | Zenith IQB50M90W 50" Rear Projection...
Color problems
actually when JVC tv's turn green the light engine is going bad. I repair lots and lots of these. The engine can be rebuild for about $500 installed. IT is a known problem for us tv techs. I have 1 engine left if you know a tech who can install it. These sell for $300. This fixes the problem which is the green chip color breaking down and smearing. All whites look green. The best way to tell is to turn the color all the way down and see if you still see green tint. It works best on a black and whit picture if poss. but any will do. Usally it shows more in one section on the picture but is green all over. my number is 270-996-7629 if you have any questions.
Mar 01, 2008 | JVC HD-61Z886 61" Rear Projection HDTV
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
GE 46GW945 Projection has color alignment problems after power outage
Try unplugging for 12 to 24 hours. if that doesnt help replace the convergence IC's
Sep 08, 2006 | GE 46GW945 46" Rear Projection Television
GE 46GW945
Your problem is a bad main filter, a regulator IC ,and or a combination of a convergence problem along with a vertical IC going bad. This set is not something you should mess with unless your a trained tech. Please seek a pro to assist you with this repair. good Luck
Jul 28, 2006 | GE 46GW945 46" Rear Projection Television
Televison & Video Logo
116 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
