Question about Frigidaire Stove/Oven/Range Cooktop - 318079348
To set the clock on a Frigidaire Ellite stove
To set the digital clock
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
Where are the fuses on a fridgidare range,glass top,everything works except thesettings for my stove doesnt light up
Thank you for your post, friend!
Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
Mar 10, 2015 | Frigidaire Stove/Oven/Range Black Glass...
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Burners work on top of stove, but oven and clock not working
Make sure the clock is not set to "auto" function or on "timer" mode. The oven will not start until the correct time has come up. If the clock is not working , this is likely to be the problem. See if there is a manual operation control or switch. You may have to get a new clock or arrange for the clock to be bypassed so the oven can work without it. Most electronic clocks can stop an oven from working if they fail.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
Digital clock needed to be reset ,,did that..then it went out ..now al li hear is a constant low pitch buz from the clock area of the stove.
power off to the stove at the electrical switchboard.
wait a minute then power on again, set clock again, any better?
if not, call the repair man.
Oct 21, 2013 | Whirlpool Cooktops
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Whirlpool Cooktop will not reset
Well the solution was to unplug the 220Volt connection for one minute--plug it back in--reset the clock, hit start and bingo it worked. I found on the back of the stove the technicians schematic, and error codes in a plastic envelope that described the procedure for finding--isolating--and solving the issue by the use of the error codes, which were not avaialable online anywhere but in the diagram and description for a technician's use.
I saved myself $109 dollars by avoiding the call out, but still my breakfast was four hours late!
Dec 27, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Magic chef range
f1 is the code for a failed clock most of the times you must replace the clock most of them have a five year warrenty check your owners manuel for warrenty info
Mar 12, 2008 | Cooktops
Frigidaire Stove/Oven/Range Cooktop - 318079348 Logo
23 people viewed this question
Top Frigidaire Cooktops Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
