Hi, I want to know if there is a way to watch tv (sound & picture) with a htmi cable or similar even if I do not have a hdmi port. thank you
I have a vga port which is good for the picture only. The sound is not so good with audio line out. Is there some way of improving ?
  • Computers & ... Master
  • 5,347 Answers
You might be better off with external speakers connected to the laptop's audio output. Flat panel TV speakers tend to be weak.
If you want to continue with the HDMI option and your laptop doesn't have an HDMI port, try a USB to HDMI adapter. Look carefully, some models output 720p not 1080p. One possible unit: http://www.walmart.com/ip/Aluratek-AUH200F-Aluratek-USB-to-HDMI-1080p-Adapter/16386417 . However, your video rate may be sluggish due to the limits of the USB port. (If you have a USB 3.0 port on your laptop and find a USB 3.0 adapter, it won't be as bad. USB 2.0 adapters are more common.)
Look at the specs for your laptop or add a comment with the make and model. My mom's HP laptop (purchased in 2009) has an HDMI out; however, the audio driver doesn't go to HDMI out by default.
You may need to adjust the audio output options. (In Windows 7, Start > Control Panel > Hardware and Sound. Then Select Manage Audio Devices under Sound. Check the Playback tab for your audio output options and change the default device if needed.
I hope this helps.
Posted on Jan 18, 2013
coldsilver20
  • 113 Answers
SOURCE: VGA and Audio cables connected to PC but no audio through TV
if your tv has vga input there should be a "line in" input very near it. VGA can only get its audio source through a "line in" connecting to the coaxial audio inputs will apply the music stream to a different video input on your tv. your tv has video 1, video 2, vga, and so on, but the vga cannot show video and then audio from the video/audio coaxial inputs. you will need something like a dual male tipped 3.5mm audio connector.
Good luck and pls rate this post
Posted on Mar 16, 2009
SOURCE: connect my laptop to tv with a sound
Your computer may have come with cables to do just that. If not, you have options:
For video, I would check your TV inputs to see if it has a VGA port, since that would be the easiest. You can also get VGA to RCA or S-Video converters online as well if your TV does not have a VGA port. Almost all TV's these days have RCA inputs.
For audio, you can get a headphone jack (3.5mm) to RCA converter.
If you can't find the converters at your local electronics store, just google VGA to RCA and headphone to RCA.
Once you have the necessary cables connected to your TV, your computer will recognize that it has been connected to an external video source. I'm not sure, but I think it is either key combination Fn+F6 or F7 to perform a monitor switch. You can also right-click on the desktop and select properties (or personalize in vista). Then switch to the settings tab (or Display settings in vista) and click on the alternate display.
Posted on May 03, 2009
cheap to fix
  • 404 Answers
SOURCE: play laptop video on tv
yes vga plays hd video. but an hdmi cable is better. get a VGA to HDMI cable
Posted on Jul 20, 2009
bob_computer
  • 3153 Answers
SOURCE: connecting a laptop to a tv
You have to tell the laptop to use an external display this usually involves pressing the FN + F5 on and acer but does vary from laptop to laptop
the second key usually has two screens printed on it
Posted on Dec 31, 2009
Current009
  • 135 Answers
SOURCE: can I connect my Toshiba NB 205 to my TV to watch
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
Posted on Jun 01, 2010
How to repair HTMI port "no signal" on screen
Just pull out the socket to the port, and fix an other in that place. It will come out easily as you pull out, and can be fixed a new one for just one hard push.
Sep 26, 2016 | RCA Televison & Video
Lg 42" plasma
It may be that your cable box is outputting at a resolution your TV doesn't recognise or doesn't support. Do you have any other connection you can use from your cable box to your TV to check the settings?
Nov 18, 2017 | Televison & Video
No video signal using HDMI cable.
This sounds similar to my Vizio's second HDMI port; they sometimes become finicky after a while. You may have to just adjust and wiggle the end of the cable inserted into the TV; if it works, then make sure you don't even slightly touch it or else it'll lose signal again. If you have any other ports, try them instead; otherwise the problem may eventually get to an unusable point. You will have to have the port repaired or the TV replaced.
Jan 30, 2018 | Toshiba 47ZV650U TV
No sound on TV with hdmi cord
HI Mike,
Sometimes HDMI ports have their sound channel shared with the VGA/RCA port and they need to be switched around in the TV settings.
I dont know what is brand is your TV set so you will have to check yourself in the sound settings and also check for PC settings, see if you can change that around.
You can also just try another HDMI port on your TV that have the sound dedicated to it.
Nov 29, 2011 | Acer Computers & Internet
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Sound but no picture
Your player has several outputs and you might want to start with the basic Video Audo Left Right output first.
Set your with your plazma to see if you can change the input types to accept the video and audio input which will probably be labeled AV 1, AV 2 and so on.
My guess is that you have it set for Component Red Blue Green which his a high def (just before HTMI) and requires a separate audio cable. Your player, depending on the age of the unit, probably will not have Red Blue Green picture output.
Next if you have an HTMI output from your player hook that to your Plazma in the HDMI 1 position and select it on the TV's setting. Audio and Video are both carried in the HDMI cable.
Good luck, my name is Eric Kirkhuff
Feb 23, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
No picture when on TV/Sat mode on receiver
Dear Customer,
Try another tv to this bales,
than try another cables with this your tv ,this way you got problem & find out solution on which you can spend time for ,
than try some channels to sets up your tv configuration,
or must not be imported from another country cause its not similar to your country's signal identification,
THNX
May 18, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
