Question about Toshiba C855s5214 15.6 Inch Laptop
My sd port cannot read ma sd card
If i insert de sd card it does not indicate at all
  • Toshiba Master
  • 7,627 Answers
Remove the SD card, reboot insert the card. Is your Card reader enabled in Device Manager? Have you done any updates? install the Card Reader driver. Toshiba Support : http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Posted on Jan 18, 2013
How to calibrate Vtech Storio?
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
Feb 15, 2012 | Vtech V.Reader Interactive Reading System
The sd card is too small. It doesn't fit into my computer, it came with a little yellow thing to attach to it but it doesn't work on my computer. Help.
Hello akamacho,
It is possible that you have a "MicroSD card". Most card readers can not read micro sd cards because it is too small, so you will need an "adapter" to be the same size as a normal SD card and then you can use it on card readers. I am just assuming (because I can not see it) that the yellow thing you have is the adapter. Make sure the micro SD card is inserted into the adapter properly and make sure that your adapter is inserted properly into your card reader.
If it is still not working, tell me the brand and model of your computer or you card reader. Also indicate any markings you can read from your sd card and the little yellow thing.
You can rate my answer if you appreciate it.
Thanks!
-damneddle
Oct 07, 2011 | Cameras
The cable which came with the cvamera does not transfer the pictures from the camera to the computer
Try another usb port as it might be that from that Usb port you are using it is not even reading it, or else if you have an sd card reader , remove the Sd card and insert it into the card reader
Dec 21, 2010 | Fuji FinePix S5000 Digital Camera
Hp Photosmart 8150 can't read sdhc memory card
Unless the SD slot is specifically designated that it can read the new SDHC (Secure Digital High Capacity) memory card it will not read even though it plugs intop the standard SD slot.. I checked and this printer can't read the SDHC card only the standard SD card. You can buy a SDHC USB reader on ebay for a few dollars.
Nov 24, 2010 | HP Photosmart 8150 InkJet Printer
Won't read memory card
This usually indicates that you are trying to use 'newer' SDHC High Capacity cards of 4GB or more. Older and cheaper units like this Vivicam 5024 unfortunately may be limited to 2Gb 'standard' SD cards.
Hope it helps: let me know what cards you are trying to use.
Jan 16, 2010 | Vivitar ViviCam 5024 Digital Camera
Micro sd 2gb card, not read.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health.
Oct 17, 2009 | HP Compaq nx6110 PC Laptop
Where do i insert my SD card to download pictures from my digital camera
U have a computer have a SD ports on the bottom of DVD drive?Buy a USB hub with a
SD card read box.
Aug 16, 2009 | Televison & Video
Micro sd 4gb micro card.
Something is wrong with the card. Maybe it's corrupted.
But what your computer means by I/O Error is Input/Output Device Error, which means the card has issues.
Hope this helps!
Jan 27, 2009 | LG VOYAGER VX10000 Cellular Phone
Follow this link to solve it, http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect , and dont forget to report to me ... good luck
Jan 12, 2009 | Samsung Rugby SGH-a837 Cell Phone
SD card won't format
Did you update the Firmware of the camera? The VPC-C6 can read and write to SDHC memory cards up to 4GB but it would require to have the latest Firmware being installed on the camera. Firmware can be downloaded via http://www.sanyo-dsc.com/english/support/updata/vpc_c6/index.html
Dec 01, 2007 | Sanyo VPC- C6 Digital Camera
Open Questions:
See all Toshiba C855s5214 15.6 Inch Laptop Questions
Toshiba C855s5214 15.6 Inch Laptop Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
