Question about GE GSL25JFPBS Side by Side Refrigerator
How to level my refrigerator - GE GSL25JFPBS Side by Side Refrigerator
    New Friend:
  • 15 Answers
THERE ARE LEVELERS BEHIND KICKPLATE ON MOST FRIDGES. SCREW IN TO GO UP OR OUT TO GO DOWN
Posted on Jan 18, 2013
Water is now showing up in the gladiator refrigerator
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re tightening the screws.
Jan 19, 2010 | Whirlpool Gladiator Refrigerator
Water leaks inside refrigerator and freezes. It goes inside bottom drawers and lays on shelves.
Hi. Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Dec 29, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Leaking inside refrigerator
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Dec 07, 2009 | Frigidaire FRT21H8 Top Freezer...
Setting the appliance level
Before leveling, unplug the appliance to avoid an electrical shock hazard. Never tip a refrigerator or freezer, it is very heavy and can fall causing damage or injury.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An icemaker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then retightening the screws. Neeed more assiatance, Visit my sites, Thanks, Sea Breeze
Nov 25, 2009 | Whirlpool GC5NHAXSQ
My refrigerator leaks water from the inside bottom, It is a Whirlpool side by side black color model E5DJHEXTB00
Oct 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water running into refrigerator I think on defrosting
Oct 29, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water is leaking from freezer into refrigerator.
Oct 27, 2009 | Whirlpool Refrigerators
Need to level the refrigerator. It is a side by side unit by Whirlpool ED25TQXFW02 Serial:SH4940056 FG1298
Used shims to level. Could not find feet to adjust.
Thank you all for your help.
cmbowser
Jul 29, 2009 | Whirlpool Refrigerators
Leveling refrigerator
you might lower the front ones to get it level thats the only sloution i can come up with
Aug 04, 2008 | Maytag MSD2656G Side by Side Refrigerator
In a Home the recommended level (front higher to back lower) is 1/4" (Right to Left - level)
Never less than in order to allow door to shut own their own, but there is nothing wrong with having a perfect level refrig if everyone closes the doors properly which they won't. A refrigerator requires to be reasonable leveled to avoid compressor fatigue. In a Motorhome people can't always find level ground, so it quite frequent that their refrigerator burns up when running. From that experience I'd say I would level any fridge which is over 1/2 inch off.
Nov 02, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
GE GSL25JFPBS Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
