Question about RC Thomas the Tank Engine
Peg perego thomas the train and track Clarabel that wont move after teens tried to ride on it. The sounds and lights works, no movement on the one front wheel wont spineven when tried by hand.
Yellow light showed when placed on the battery charger.
3 Suggested Answers
imaric
  • 17 Answers
SOURCE: my thomas the train ride on toy wont move unless
A few things can cause this: The battery is weak/bad. The connector at the battery might be worn out and have intermittent contact. Those are fairly easy things to check. Next, the GO button might be worn out internally (high resistance contacts)-believe it or not, the whole motor current goes through that switch. You would need to remove top of the roof to access the button. Or, open the speaker cover, pull out the control board and bypass Go switch wires to check for train proper operation. As you are already there, inspect the control/sound board. The last thing that comes to my mind is the motor itself, it is under the seat. Check contacts to motor, plus you can spray contact cleaner or, if you don't have anything else, alcohol. Avoid using WD40 - it does the job, but collects new dirt very very fast). There is always a chance of pinched/loose wire, or mechanical problem with gear assembly/jamming or so.
Posted on Sep 04, 2012
adamfjeld
  • 1508 Answers
SOURCE: i need to replace the motor in my thomas ride on train but can't figure out how to get it apart - suggestions?
you'll have to pull the rear wheels off then pull the motor off of the axle
Posted on Dec 14, 2012
I have a peg perego Thomas the train ride on and music will come on but it will not move
It's probably the circuit board that you can get here http://www.mypegperegoparts.com/meva0024.html but you can also contact their repair desk 1-801-655-0800
Apr 13, 2017 | Peg Perego Toys
Where can get extra track for Peg Perego Thomas the Tank ride on train
Currently, I can suggest only you contact peg-perego's uk representative Mamas & Papas at the address given on the following webpage
http://global.pegperego.com/toys-site/where-to-buy/
MAMAS & PAPAS LTD.
Colne Bridge Road
HD5 ORH HUDDERSFIELD WEST YORKSHIRE - UNITED KINGDOM
Phone: (44) 1484-438200
Fax : 1484-438210
Email: customer.services@mamasandpapas.com
If they have anything you would like, I believe that delivery can be arranged, and you will not have to go to Huddersfield.
(http://global.pegperego.com site > support tells you how to contact UK rep.)
I suspect that track for the choo-choo model is compatible with what you are looking for (but that doesn't seem to be available at present either. You might try ebay, but be careful to check that you are buying exactly what you need.
21.July.2014
Jul 21, 2014 | RC Thomas the Tank Engine
Thomas train shows as fully charged however when trying to use it, music starts but then a clicking noise and train doesnt move
the music is run by three aaa batteries so that will work no matter what, did you reconnect the battery to the vehicle after charging it
Jun 25, 2010 | Peg Perego IGED1084 Santa Fe Train
Thomas train peg perego instructions
have to hold on the button that has arrow untill it moves
Apr 03, 2010 | Peg Perego Ride On Santa Fe Train
Thomas train charge battery has music and sound effects, but does not move?Does it need a new motor
It might need a new wire connection to the motor.
I would contact
http://www.shopjandl.com/
They help me with my ride on toys.
hope this helps
Jul 15, 2009 | Peg Perego IGED1084 Santa Fe Train
Peg Perego Thomas Train Track Rider
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
May 28, 2009 | Learning Curve Toys Thomas the Tank Engine...
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Mar 12, 2009 | Toys
The red button on the right must be held down for anything to move. It turns the lights on, makes some train noises, then moves forward. If you don't hold the button down, nothing will happen. Note that when the train is underway, the left red button becomes a train whistle. Otherwise, when the train is not running, that left button produces music. Hope this helps.
Dec 16, 2008 | Peg Perego Vespa Scooter
Peg Perego Thomas the Train Ride-on Music button not working
It could be a bad switch or the music board has a bad contact.
Nov 21, 2008 | Peg Perego Vespa Scooter
RC Thomas the Tank Engine Logo
53 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
