Question about Hit Thomas and Friends TrackMaster R/C - Percy
Howto put 4 magnets back in percy train - Hit Thomas and Friends TrackMaster R/C - Percy
Just bought the ghostly percy and cant open to put a batty in it help
THE BATTERY SHOULD GO IN THE BOTTOM OF THE TOY.YOU MAY NEED A REAL SMALL SCREWDRIVER TO OPEN IT.
Feb 08, 2011 | Seth Thomas Thomas & Friends Percy Train...
Where does Stanley the train's battery go
There are apparently 2 different models of the Stanley train for the Trackmaster. One comes with a tar car and one is by itself. If you have the one with the tar car, the battery goes in that. If you have the one that comes solo, then you have to flip it over and in the middle of the bottom is a small screw that you have to unscrew and remove the middle wheels to take the top off. Once you have the top off, the battery is located there. I hope this helps.
Jan 22, 2011 | Seth Thomas Thomas & Friends Percy Train...
I through away directions by mistake. How do I put the battery in Percy. Thanks.
My child has a similar train but it is a Thomas instead of a Percy. There is probably a screw on the bottom. My son's train has three screws and the one in the middle (+) is the one that opens the train so I can put a battery in it.
Nov 29, 2010 | Seth Thomas Thomas & Friends Percy Train...
How do I cange Trackmaster Percy's battery
In the early model trains - Just by the middle wheel there are plastic brackets that lock the top in to open squeeze on both sides above the wheels to move the brackets in and pull the top up - This will open the top and then you can replace the battery Note my wife helped me to figure this out as I took all the screws out as well
Apr 24, 2010 | Hit Thomas and Friends TrackMaster R/C -...
Panu lagyan ng background friendster?
This is the instruction on how to place the code above into your frienster.
1. Log into friendster
2. Click on profile
3. Click on edit profile
4. Click on customize
5. Then go scroll down he page to Advanced Customization(customize css)
6. In the box below the Advanced Customization(customize css)
7. Paste the copied code for your background into the box.
8. Then save
9. Then click on (view your profile now) to see your new background.
You can find background codes at http://www.informationzoo.com/Friendster.html
Apr 04, 2010 | Seth Thomas Thomas & Friends Percy Train...
Thomas & Friends, Talking Percy doesn't move.
It has to be on the track to work for some reason. Turn it on, put on the track and press the button on that makes it talk.
I have to say I am pretty mad at fisher price for this one. The box says 3 AAA's included, when you open the box though you find out that they are "just for demonstration". So back to the store for batteries. Get the batteries changed, and then it doesn't work. Back to the store to exchange, and then find out it does work.
Jan 27, 2010 | Hit Thomas and Friends TrackMaster R/C -...
My tire reset
heres what you do dont try to use the reset computer. the computer will reset it self. just make sure that when you put air in your tires the car is level... then using your tire guage bleed out each tire to 25 psi...now....pump your tires back up to 33psi each. i like to put in 33psi becouse when the tires heat up.. hot air expands so it should read 35psi to 36psi and thats ok.the computer will re set on is own after you,ve driven it around for a while.
Aug 31, 2008 | 2002 Chrysler 300M
Hit Thomas and Friends TrackMaster R/C - Percy Logo
44 people viewed this question
Top Hit Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Hit Toy Expert? Answer questions, earn points and help others
