Question about Delphi Fuel Pump Ford Bronco 96 95 94 93 92 91 90 Ii 89 E-150 Fg0198
Starter doesn't always work
Every once in awhile when I try to start my van the starter just spins, like the bendix ins't engaging, and I'm worried that I might get stranded if it continues like this and all of a sudden it won't work at all.
    Genius:
  • 1,003 Answers
Your solenoid switch is the culprit
Posted on Jan 22, 2013
Kawasaki starter not engaging
Hi, Ricky the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starter spins but engine does not crank
Starter spins but doesn start the bike Ex 500 com The home of the Kawasaki...
Starter spins but doesn turn the engine
Mar 22, 2017 | kawasaki Motorcycles
The starter motor will not engage
Hi, Paul the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day. Starter spins but doesn turn the engine
Starter spins but won catch
http://www.apriliaforum.com/forums/showthread.php?189764-starter-spins-but-doesnt-engage
Inside look of starter spinning but not engaging
May 15, 2016 | Motorcycles
Starter not working all of the time
Normally when it spins it is the bendix or a problem related to it. Yes replacing or repairing the starter is the thing to do.
Jan 17, 2013 | Worldwide 1990 Ford E150 Econoline Club...
Starter not egaging right?
There are two types of starter, a bendix gear type,and a pre engaged type, neither should rotate with the engine running, with a pre engaged starter the gear is connected to the flywheel but when the engine starts a solinoid pulls the gear out of the flywheel, with a bendix type, the starter motor spins the bendix shaft which in turn winds the gear up and into the flywheel ring gear.
Dec 08, 2012 | Garden
I have 1996 grand caravan 3.8. I replaced the starter and it wont crank over, starter just spins
Do a voltage drop on the solenoid
You either don't have battery voltage or
two bad starters,or some flywheel issue
Nov 21, 2012 | Cars & Trucks
Truck has electrical power but won't turn over. I think I can hear the starter solenoid engaging. Not sure. where do I start trouble shooting?
Safety first!--Make sure you're in park & brake on-- Try shorting across the starter terminals with a screwdriver,if the bendix kicks in & nothing spins,remove the starter & put in bench vice ,(or hold down securely), & jump with cables.--REMEMBER POLARITY--If the starter spins you are in deep *******---something in the motor is probably locked up.(If the starter doesn't spin get a new one.)
Sep 24, 2011 | 2007 Nissan Xterra Off Road
I have 1972 xl 1000 harley starter is just spinning not engaging i have replaced starter the selenoid and the bendix stilll not working
If the starter motor is running, the solenoid is working. Is the "over running" spring, cup, and pin in place? Is the shifter fork for the starter shaft positioned correctly in the collar behind the Bendix.
Disconnect the battery, remove the primary cover, and take the solenoid off but leave the plunger for the solenoid in position. Now, with the solenoid off, pull the plunger back in the direction that the solenoid would pull it. Watch the starter shaft and make sure that it moves forward and engages flywheel. Take the starter off and make sure the small gear on the end of it is in good shape as well. Try that Bendix with your hand, It should turn one way but not the other. Even if it does, that doesn't mean it's good. If it turns in both directions, it is bad.
http://www.bikebandit.com/1972-harley-davidson-xlh/o/m1748#sch195980
Good Luck
Steve
Sep 07, 2011 | 1979 Harley Davidson XLH 1000 Sportster
Turn switch on and all the lights work but the starter wont engage
If the starter wont turn...Id check / replace starter solonoid.
If the starter turns but doesn't engage the flywheel...I'd check / replace the bendix.
If starter checks good and bendix is good...I'd look at the teeth on the flywheel.
Hope this helps...
Jul 23, 2011 | 2005 Jeep Wrangler
75 sportster starter just spins. 1st time it did it I tapped starter with rubber mallet and started. No problems for weekbut now doing same thing, and tapping doesn't help starter just spins...
If the starter spins but the engine does not turn, it's not your starter. It is your starter drive or Bendix on the starter shaft. Disconnect the battery. Take the outer primary cover off. Take the wires off the starter solenoid, remove the pin, cup and spring on the inside of the primary, and remove the solenoid. With this off, you can remove the starter shaft. Clamp the starter shaft in a vise with soft jaws on it. You don't want to scar your starter shaft. You'll see a round thing on the end of the shaft with two flats on it. Use a wrench to take this off. IT HAS LEFT HANDED THREADS. Slide the old Bendix off and put the new one on. Put a drop of Loctite 271 red on the threads and put the nut back on the end and tighten. Put your bake back together in reverse of how you took it apart. When you buy the replacement Bendix, but a good one. Do not buy the Chinese version, they're junk.
Good Luck
Steve
May 28, 2011 | 1979 Harley Davidson XLH 1000 Sportster
Delphi Fuel Pump Ford Bronco 96 95 94 93 92 91 90 Ii 89 E-150 Fg0198 Logo
80 people viewed this question
Top Delphi Car Audio & Video Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
gmduvall
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
