Question about Maytag Dryers
Oil leaking on top part of dryer
Oil is leaking from top part of dryer not on bottom
    Scholar:
  • 197 Answers
Oil ? I've never heard of any oil associated with a dryer.
Posted on Jan 18, 2013
I have iol leak in the rear of chev vetec 350
didnt specify vehicle --generic answer --start with older vehicles leaking from top check valve cover --towards bottom rear oil seal -oil filter ,housing-- bottom oil pan //newer only difference would be oil pressure sensor and oil cooler lines
Sep 22, 2016 | Chevrolet Cars & Trucks
Oil leak
If the hose comes out the top of the transmission, this is the transmission vent line.
Make sure the line doesn't "dip" anywhere alone it's run, causing a low area where residual oil would "pool", then blow out under pressure.
Also, make sure transmission fluid isn't over-filled.
Mar 20, 2014 | Harley Davidson XL Sportster 883 Hugger...
Smoke coming from hood of my 2001 mercury cougar only when i come to a stop
You have an oil leak, have the engine pressure washed top and bottom and drive it, then inspect the engine top and bottom for an oil leak.
Oct 01, 2012 | 2001 Mercury Cougar
Have oil leak not heavy, but it leaks any answer were it could be coming from..
Valve Covers, Head Gaskets, Oil Pan Seal and a number of other spots. You'll need to clean the motor with Gunk Engine cleaner and then look for the largest build ups of oil and crud to get a better idea where it is.
Feb 15, 2011 | 1997 Mercury Villager
The seal on the oil filter housing is leaking
YOU NEED TO REPLACE OIL FILTER SEAL IF YOU OIL FILTER ON TOP OF ENGINE.IF OIL FILTER ON BOTTOM ENGINE LEAKING YOU HAVE TO REPLACE OIL FILTER WITH NEW OIL SEAL.
Feb 12, 2011 | 1996 Volkswagen Jetta
Possible oil leak from head gasket or crack in
if oil is leaking from the the top to bottom, check the gasket below the cover that has the daewoo name and sign on on top of the engine block. it could be cracked. replace with new one without any gasket sealant just replace the original and done
Oct 06, 2009 | 2000 Daewoo Lanos
Engine leaking oil towards the back
the best way to attack an oil leak like this is to have the engine steam cleaned of all oil top and bottom and then drive it for about 20 miles and look up top and bottom of engine for the source of the leak, your leak could be the valve cover, the pan gasket or the crankshaft rear main seal or a combination of all three, reember the oil runs back and down, so where the oil drips on the ground is not always where the oil is leaking from
Apr 01, 2009 | 2000 Volkswagen Beetle
How to replace dryer belt
Remove the filter from the top>
Remove the 2 phillips screws from the top (filter housing)
Use a putty knife to pop the top by compressing the clips
on either side of the top between the front and top.
NOTE: Once the top is up remove the screws inside
to get the front off and LIFT the front up
before pulling towards you so the bottom clips
won't break.Get the lid switch disconnected and set the front aside.
Oil the rollers and idler, vacuum out the lint.
The new belt goes rib side down on the tub. The idler mounts like the one pictured
on bottom right of these dryer belt routing pics:
Dec 16, 2008 | Roper REX4634KQ Electric Dryer
Oil Leak
The oil leak at bottom of radiator could be oil cooler and/or supply hose. Try check closely for wettest area .
The other leak could be thermostat cover, it only uses a sealing ring and is prone to leaking after time.
Jun 25, 2008 | 1997 Saab 9000
Oil leak
A small amount is not serious. There is no good way of adding oil to the transmission unless you want to take the top off the transmission.
Jan 21, 2007 | Whirlpool LTG5243D Top Load Stacked Washer...
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
