Question about Kenwood KNB-17AM, TK-280, TK-290, TK-380, TK-390, TK-480, TK-481, 7.2v 1800mAh NiMH Battery 2-Way Radio
TK 380 not transmiting
Radio will not transmit. When pushing ptt button radio makes a honking sound no red trans led?
  • mastertech00 May 11, 2010
    While pushing the ptt, does the display "UNLOCK" ??
  • Anonymous Mar 26, 2014
    they are charged, used them twice then they stopped working, the led light on one turns red when ptt is depressed, the other radio led turns green but can not hear any transmission between them, they are on the same channel, volume is up, am I missing something?
Its most likely was programmed with a rx but no tx. Meaning it can recieve but not transmit, you can fix this with the programing software.
Posted on May 30, 2009
Cannot transmit, getting a constant tone while holding talk button and transmit light not coming on, any help?
Check the headset jack. There may be something inside causing a short. also, the CLS has an audio tone out button. Be certain you are not pressing it as you push the PTT button. The PTT is odd on this radio, it is the top BIG rubber button on top FRONT. Many customers get this confused with the tone transmit button.
Nov 13, 2015 | Motorola CLS1110 Professional 2-Way Radio...
I have this Kenwood TK-2107 .... when the ptt button is depressed the transmit led lights up but it does not transmit. Why is that, any good tips?
The output transistor could be bad. the Xmit relay could have burned contacts or is not operating at all.
Oct 28, 2014 | Kenwood Tk 2107
Will not Transmit.Display Indicates "release mic button" and radio buzzes
The PTT button is probably stuck and your radio is already transmitting.
PTT = Push To Talk
Sep 09, 2014 | Boating
Can't transmit signal. Only get a 2 second beep when I push the transmit button
You have a poorly charged or bad battery. It takes more power to transmit than to receive. Usually the first thing you lose with a low, bad or poorly charged battery is transmit.
Try a known good battery in the radio. This should solve the problem. If not, check your battery contacts, as you may have one which is bad or not making good contact.
Clean your contacts with a pencil eraser to assure good connection with the charger.
Best regards.
Mar 18, 2014 | Kenwood Radio TK 260 360 270 370 2100 3100...
Vertex 2200 transmits but makes no sound
You mean NO Audio Transmit?
If there is No Audio at PTT Bad MIc Cord.
Change the Mic cord.
Dec 01, 2013 | Vertex Cd Vx-2200 Vx-2100 Series...
Tk 2200 ptt button not working. when the button is pushed, the light come on momentarily then goes off
Hi Benjamin,
Kenwood TK-2200. The light comes on when you press PTT button, indicates you are transmitting.
The light goes out when you release the PTT button, if itgoes out during transmission, but your message gets through to your contact, then I don't see the problem.
If the light goes out during a transmission and you are still able to communicate, Don't worry, be happy, it's just a minor glitch with the light, no the radio.
As you haven't given me the details that I have guessed for you, I hope I have been helpful.
Nov 01, 2011 | Kenwood TK2100-TK2200-TK3100-TK3200-TK3101...
Makes loud tone when pushing ptt button
The ptt switch or circuit is not disconnecting the audio circuit. Open the unit up and check the wiring, interconnect plugs for something shorted not canceling the receiver audio.
May 10, 2010 | Radio Communications
If it's a distinct "tone" like 1000Hz, it's probably mis-programmed. Check You may find a manual there.
Mar 20, 2010 | Kenwood Radio Communications
By keeping the PTT button pushed, if you get a rapid beep and the red led is blinking, sounds like a bad battery. Batt voltage is a nominal 7.5v. anything lower than 6.25v and the low battery beep starts. A rapid beep, and no red led blinking, an error in the transmit freq.
Mar 01, 2008 | Kenwood Radio TK 260 360 270 370 2100 3100...
Kenwood KNB-17AM, TK-280, TK-290, TK-380, TK-390, TK-480, TK-481, 7.2v 1800mAh NiMH Battery 2-Way Radio Logo
391 people viewed this question
Top Kenwood Radio Communications Experts
michael galang
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
