Question about Hoover Washing Machines
Hoover nexus 8 1400 washing machine not spinning
Water is draining from machine but seems to be slow and very quiet. Have checked discharge pipe and it is ok. can't find a way to remove filter to check if there is anything blocking it. Can you help, How do you remove the filter, bottom front left??
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
If u cant unscrew it somethings jammed in it ,force it or pull the pump houseing apart
Posted on Jan 18, 2013
  • 25 Answers
SOURCE: beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Posted on Jul 16, 2009
nikeananth
  • 267 Answers
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
  • 5 Answers
SOURCE: AEG 74630 washing Machine stopped working, will
I have same problem right now. The machine works fine up to the stage where it needs to pump out. the pump was dead. Have replaced the pump, but still not working and it's probably the PCB that needs replacing - expensive but will buy reconditioned for about £50.
Pump available for the machine on Ebay and easy to replace. Take of machine back panel - make sure machine off and unplugged. Pump has 3 screws holding it in - then just replace. Easy. Good luck
Posted on Jan 21, 2010
  • 215 Answers
SOURCE: water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
Posted on Feb 13, 2010
  • 662 Answers
SOURCE: wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
Washes all ok but will not pump out all the water
Check pump and drain hose for obstructions.
Nov 21, 2010 | Washing Machines
We have a Kenmore 3.5 Super Capacity Quiet Tumble Action Wash Easy Access. The spin cycle works however the water won't drain and our laundry is soaked. Help...
It could be either the pump or a clog in the discharge hose. Take a shop vac and attach it to the discharge hose to remove the water from the machine. Remove the pump housing and run a wire down the discharge hose to check for a clog. If there is no obstructions, reattach the pump housing and remove the pump motor. Run a spin cycle and see if the pump motor turns.
Aug 27, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Water not pumping out, still spinning can't find blockage in pump or pipes
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Hoover Washing Machines
Hoover washing machine model HNF71683D not draining water
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
Feb 28, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
I am looking for the instruction manual for the hoover performa eco wb120 washer dryer as i cant seem to spin my washing which is stuck in the machine
My partner fixed this problem by taking the machine back out and found that the connection to the water outlet pipe under the sink had a buung left in so after it was removed my machine drained
Mar 22, 2009 | Hoover Washing Machines
Over flowing on water discharge
This is not a fault with your machine.
The problem lies aquarely with the outlet pipe in the building plumbing. Very often there is a gradual build-up of grease in this pipe somewhere before the pipe gets larger to the main drain.
The first solution is to use a solid or liquid drain cleaner in that pipe - and leave it to work at least overnight.
Then fill a bowl with very hot water and Soda Crystals - basic washing soda.
Flush the pipe with a full bowlfull of this hot water (may need a large mouthed funnel)
Also a hosepipe from the hot tap to a pipe in the outlet will work.
Once clear - you shouldn't have anymore problems.
If you wish, you can wrap a polythene bag around the machine outlet, then force this into the wall drain pipe - to make a better seal. It's not ideal, but may help with pipes that are slow to drain.
Feb 01, 2009 | Kenmore Washing Machines
Water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing machine doesnt seem to be draining or spining properly
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 18, 2008 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
52 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
