Question about Yamaha Audio Players & Recorders
No front display on my yamaha RX V473 only red light
    Genius:
  • Yamaha Master
  • 1,054 Answers
Does the power relay click when you press the power button? It may be the main transformer has gone bad.
Posted on Jan 18, 2013
nuwan chinth
  • 111 Answers
SOURCE: yamaha receiver rx-v661 display light is out
lamps are burnt out or missing power to backlight system.
please check all the fuses.
nuwan.
Posted on Jan 13, 2009
aparsons89
  • 40 Answers
SOURCE: problem with yamaha rx-c2092
Hi, try to unplug this unit from the wall for a minute or so, It may just need reset. If it still does this I would say that you have a loose wire inside where the power supply is. I would not recommend working on this unless you are computer savvy.
Posted on May 13, 2009
tvservice306
  • 458 Answers
SOURCE: Yamaha RX-V660 Display Light Out
if you not tech ..suggest send to service
this problem is display negative voltage missing......or display driver ic bad.....
Posted on Nov 11, 2009
SOURCE: Yamaha Rx-V870
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Posted on Feb 03, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX-V663 display is not working
If you have your receiver hooked up to a TV or Monitor, press "Menu" then toggle to section "5" "option menu" and check your "Dimmer" setting "0" is highest. Then check "FL Scroll" and the choice is "Cont". This info is on page 96 in your manual, if you don't still have a copy, here's the link
http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V663_U-1.pdf
Hope this helps. If you still have a problem, post a comment and I will help you further.
Posted on Dec 26, 2009
I have yamaha amplifier model RX-V473 no power standby. When I push on the power bitton the power led is blinking rappedly and the off.can you help me
Try pressing and holding the "tone control" and "info" buttons, then press power. This will clear the protection lock that the unit is most likely in. If it shuts back off after this, then you have a problem that will need to get looked at by a pro.
Oct 21, 2015 | Yamaha Audio Players & Recorders
My yamaha rx-v473 wont turn on
disconnect all wires from behind unit, speakers, input, and then try to power it up ,
if problem persist then try to tighten screws on back panel of the unit,
may sound silly but if amp board does not have good ground connection it can do that , go in protect mode .
happened to me ...
Jan 26, 2013 | Yamaha RX-V473 A/V Receiver Black
Yamaha rx v473 system cuts off periodically - check speaker wires message comes on
You have a short in a speaker or speaker wire, or you are over-driving a speaker.
Jan 14, 2013 | Yamaha Audio Players & Recorders
Yamaha rx v473 cuts off
disconnect all speakers, turn it on. If it stays on, connect one pair of speakers at a time and when it shuts off, that speaker is the problem. There may be a short in the wire or the speaker may be bad. If you get that far, try connecting the bad speaker with another speakers wires.
Jan 14, 2013 | Yamaha RX-V473 A/V Receiver Black
Optical input shutdown receivers
If they shutdown it is because they are getting to hot, Keep the vollume down to a cival leval,
Nov 28, 2012 | Yamaha Rx-v473 5.1-channel 3d Network Home...
My Rx-V473 won't turn on
It couldn't start after an update. I found how to fix it on the product page : http://download.yamaha.com/search/detail/?language=en&site=europe.yamaha.com&asset_id=58063&category_id=16446&product_id=1643029&1375038490
Receiver doesn't power up after the update.
Error message appeared when confirming the firmware version.
Recovery method using USB method:
1. Unplug the AC power cable from wall outlet.
2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel.
3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again.
" USB UPDATE " will appear on the front display. Then, release the INFO key.
4. The update will start automatically.
5. When " UPDATE SUCCESS " appears on the display, firmware update is completed.
Power off the receiver and remove the USB thumb drive.
6. Confirm updated firmware version.
Oct 18, 2012 | Yamaha RX-V473 A/V Receiver Black
Yamaha RX V 657 - No Sound Output, and No input detection
Bad DSP chip. The only other possibility is if you have the "Direct" on. On the front of the receiver it's a small button. Also make sure your "Speaker Select" A/B is "on" You will see it on the display, it's also a small button on the front of the receiver. If all this is correct and you still have no audio, it's a bad DSP chip. Not worth repair, it's 400-500 repair. Not very common in a Yamaha RX-V series, but I have seen it. I'm a Yamaha Dealer. If you need further help, post a comment and I will be glad to help you further.
Aug 23, 2009 | Yamaha RX-V663 Receiver
Display is permanently "off" on the Yamaha RX-V620
Sounds like the LED that lights up the display has burnt out. An easy fix, if you're not afraid to take the front panel apart and resolder a new one.
Feb 05, 2008 | Yamaha RX-V620 Receiver
907 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
