Question about Whirlpool Dryers
Door latch replacement - Whirlpool Dryers
    Scholar:
  • 197 Answers
Disconnect the power cable first! Raise the top of the Dryer, normally they are attached on the rear so as to come up in the front by prying it up. Watch that you don't mangle it. There is two spring connectors that keeps the top down on the front. When you loosen it, raise it enough to give you room to do this. You might have a wire that connects with the on and off that is connected to the door. Disconnect it if you need to, raise the top up far enough to give you room to work. Someone might need to steady it for you. Now you can get to it, I hope.
Posted on Jan 18, 2013
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
The door wont shut properly
see this causes and use the common sense.God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
I need information on how to replace (or service) the door latch mechanism on my merc. I have realigned the door (and realigned the striker rod) and it will still not close. The latching system does not...
Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942) and watershield from front door (20124).
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812). The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed at this time because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) if so equipped. Remove the front door latch from the front door.
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch.
  1. Remove front door latch remote control link, front door latch control cylinder rods and door open warning lamp switches from front door latch where applicable.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Description 1 Front Door Latch Control Cylinder Rod 2 Front Door Latch Remote Control Link 3 Bushing 4 Door Latch Shield 5 Power Door Lock Actuator 6 Front Door Latch Control Cylinder Rod 7 Front Door Latch 8 Latch (1 Req'd) 9 Screws (2 Req'd)
Feb 13, 2011 | 1997 Mercury Cougar XR7
I have a 2006 Saturn Vue. The front passenger
there is a spring inside the door lock that makes it work this spring is most likely broken try spraying lubricant on the lock just in case its binding ,but it seems like you will have to replace the lock mechanism
Feb 07, 2010 | 2006 Saturn Vue
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
The door on the dishwasher squeaks terribly. How can this be corrected?
If your dishwasher door squeaks you have to check the following:
Latch
Springs
Hinges
Door seal
If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 10, 2009 | KitchenAid Dishwashers
Rear passenger door will not open
If the door won't open from either the inside or outside than there is a problem with the latch assembly or alignment. You can use the other rear door to see how the child lock works. Meanwhile, you'll have to remove the door panel on the right rear door from inside the vehicle. Then you can reach inside with a screwdriver and flashlight and work the latch free. Once you get it open you can further diagnose if it is alignment or a faulty latch assembly. It's not going to be easy getting the door panel off from inside or working the latch to release. I hope this helps.
Apr 27, 2009 | 2001 Jeep Grand Cherokee
Dishwasher door leak
Hi
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
A Fixya rating would be appreciated if you have found this solution Helpful.
Thanks
Rylee
Feb 10, 2009 | Maytag 24 in. MDB6100A Built-in Dishwasher
Dryers Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
