Question about LG LRBC22544 Bottom Freezer Refrigerator
Problem with water flow in LG LRBC22544 Bottom Freezer Refrigerator
Please help with determining my problem. Water had floaters. I replaced both the external and internal water filters and flushed water for a few mins. Now Line to reservoir bottle in refrigerator. leaks and pushes water out into the refrigerator. Are the clips/clamps replaceable? Is the bottle replaceable if that is what is leaking? Unable to use water dispenser...
  • Kim Chan Jul 14, 2007
    The water dispense works. However, the line that flows into the bottle reservoir backs up and spits out the other end, shooting the water into the refrigerator. What can I do about the pressure?
    Novelist:
  • 159 Answers
Sounds like you have excess pressure building up in the water system. Is the water dispensor working? If not it sounds like you have a frozen line somewhere or the valve in the door is not working to allow the water to dispence.
Posted on Jul 13, 2007
Dispenses Small Particles in Water
Click HERE to download the service manual.This will guide you to disassemble the door.
Goodluck,
Please don't forget to rate the solution
Apr 03, 2008 | LG LRSC-26922 Side by Side Refrigerator
I have a porcher sandpiper toilet and there is constantly water running inside the bowl at the back.
A few things to check look in the tank make sure nothing is blocking the flapper at the bottom thats the thing that lets the water drain into the bowl if it is clear check make sure the chain or line that connects the flush handle to the flapper is not kinked causing it to hold the flap up enough to let the water drain. If these are ok sometimes sediments will make the float device, whether its a ball or a canister type to stick reach in and lift the floater if the water stops then adjust the floater some have a screw on the canisters to adjust some an arm some the whole mechanism shaft screws up and down to adjust if its the ball hold the metal arm firm next to the base and bend it slightly down on the other end so the ball goes further into the water so when you release it lifts it up better don't bend to much check and bend more if you need to. If its a ball make sure water is not getting into it by feeling if so replace it. If none of these work you can replace the whole thing for around $20 just turn the water off flush the tank get all the excess water out and go to town its not hard make sure you have pipe tape and if you don't know about the tape ask the hardware dealer to explain how it goes on just a couple wraps. The hardware store can help you pick the one you need tell them what yours looks like and they can help find a replacement.
Sep 15, 2011 | Porcher Home
Hi, We have this caroma The revolutionary 1.6/0.8 gallon dual flush -- and we have a bit of problem with it --- there is continous flow of water in the toilet bowl.The flushing works fine but once the...
Taking the top of the tank off wont hurt anything but the assembly it might A few things to check look in the tank make sure nothing is blocking the flapper at the bottom thats the thing that lets the water drain into the bowl if it is clear check make sure the chain or line that connects the flush handle to the flapper is not kinked causing it to hold the flap up enough to let the water drain. If these are ok sometimes sediments will make the float device the thing that goes up and down when the water goes out or fills, whether its a ball or a canister type it may stick reach in and lift the floater if the water stops then adjust the floater some have a screw on the canisters to adjust some an arm some the whole mechanism shaft screws up and down to adjust if its the ball hold the metal arm firm next to the base and bend it slightly down on the other end so the ball goes further into the water so when you release it lifts it up better don't bend to much check and bend more if you need to. If its a ball make sure water is not getting into it by feeling if so replace it. The canister you want to adjust it so it goes down some so the water will push it up more and try to stop it. If moving it by hand did not fix the problem dont use these methods replace the whole thing for around $20 just turn the water off flush the tank get all the excess water out and go to town its not hard the package should help with directions make sure you have pipe tape and if you don't know about the tape ask the hardware dealer to explain how it goes on just a couple wraps. The hardware store can help you pick the one you need tell them what yours looks like and they can help find a replacement.
Sep 14, 2011 | Home
Toilet won't stop running. Flapper is fine, I raised the floater, every third flush it spills into the overflow. The slightest touch on the topmost piece of the assembly, and it stops.
Raising the floater will raise the water level which means overflow and water will keep running.
You need to lower the float to stop the water at a lower level.
Mar 19, 2011 | Home
Water dispenser nozzle forms black slime once in awhile. I use an external refrigerator filter. Does internal holding tank need to be sanitized once in awhile?
if you don't use water enough and your filter is a good one . algi could form in the water holding tank . i think you should remove the filter and flush system . then add an new filter . should correct the problem . if you flush it good .. mm .
Feb 23, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker not working just changed the filter everything was ok previous to that
Since you didn't provide a model number for your fridge, I can't tell if you have the external water filter set-up or the built-in internal filter. Sooooo, here's a couple of ways to resolve the problem:
You need to connect the filter and run water through it into a bucket, until you flush out any loose carbon, etc. By doing this, you also get out any air from inside the filter and will speed up getting the ice maker making ice again.
You should have a manual water shut off at the back of the fridge where the water line comes from the house water supply. Turn off the water valve and disconnect the filter on the end that goes to the fridge and get a bucket to drain it into. Now turn on the water supply and flush out the filter.
If you have the internal water filter, take it out and check to make sure you removed the small protective cap plug that is installed in the filter. If it's already removed, try using your water dispenser to blend out any air in the system and to clear out any loose carbon bits, etc.
This should be done until you are getting clear water, which usually takes a good 5 minutes and should draw out about a gallon of water.
If you don't have a water dispenser (again, No model number provided, makes it VERY DIFFICULT to zero in on the solution to problems folks!)
You'll just have to wait until your ice maker has called for enough ice cubes to bleed out all the air trapped in the filter, unless you can dunk the new filter into a bowl of cool, clean water in your sink until all the air bubbles stop, then reinstall into the fridge and make sure the ice machine arm is down in the "ON" position.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Jenn-Air Refrigerators
Water taste bad
Hello, does your unit have a water filter? Has this been replaced? If not I would remove the filter - flush the unit by dispensing as much water as you can to get fresh water into the system. Do you use the water much? Once you flush it, I would keep flushing it every time you get a chance for the next few days - without a filter in it and then replace the filter. Do you have well water or municipal water? Check the line in the back of the unit - anything unusual there? Good Luck, I hope some of these suggestions help you! Dr. Know
Nov 14, 2007 | Frigidaire FRS23R4A Side by Side...
Particles floating in whirlpool filtered water.
okay - we have had this same problem for around 6 weeks - We called a service repairman to come out and he said that these "floaties" are harmless bacteria. We should disconnect the filter and flush the system by using 1 gallon of water a day (wasting it) after the chlorine in the water is allowed to build up again then the "floaties"- bacteria- will go away---- gross :-( We will see if it works---
Oct 16, 2007 | Refrigerators
Ice water dispenser
With respect to the little white floaters in the water, it is not bacteria but rather a problem that sometimes occurs with hard (heavily mineralized) water.
Aug 11, 2007 | Kenmore 57029 Side by Side Refrigerator
LG LRBC22544 Bottom Freezer Refrigerator Logo
741 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
