Question about Janome L-344 Mechanical Sewing Machine
I raiser the foot to thread the needle and now it wont drop back down. How can I lease the foot so I can use the machine. The lever does nothing
    Problem Solver:
  • 6 Answers
Needs to be oiled probably, might be gummed up if machine hasn't been cleaned/oiled lately
Posted on Jan 19, 2013
  • 19 Answers
SOURCE: Janome 9000 Needle Keeps Breaking!
hi there check the race for needle piercing mark if it is pierced you will need a new race this piercing although tiny will cause this problem
always use janomes blue tip needle avalon on top backing paper below.
i am sure youre problem is a damaged race
good luck mary h
Posted on Dec 23, 2008
  • 11 Answers
SOURCE: janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Posted on Jun 16, 2009
Zenqi
  • 208 Answers
SOURCE: machine quit like it blew a fuse
The 9000 has a safety fuse which blows to protect the circuit board from overloading. It is a simple 3amp fuse available at Radio Shack or automotive store.
If you are mechanically inclined, give it a try. If you are not, take it to a dealer who knows how to repair it.
Remove the top cover by taking the two large screws and the small one under the handle, LHS.
Remove the left side cover. The hidden screw is a 2.5mm allen accessed through the vent.
Lay the machine on its back and remove the four large phillips screws on the bottom and the small screw for the side, paying extreme caution with respect to the embroidery arm.
CAREFULLY move the base unit to the left and out of the way.
Inside the body of the machine you will see a black box held in place by three or torx/slotted screws. Remove the screws and, as you slowly pull the box out MAKE NOTE OF WHICH WIRES PLUG IN WHERE.
One of the wires will not remove.
On the other side of the box, remove the two screws that hold the cover on.
Inside, remove the two screws that hold the board.
Inside you will find two fuses. One will be blown. Replace with new fuse and reassemble.
When refitting the base unit, make sure that the knee lifter is on the correct side of the lever. Also, orient the base so that the accessory bin fits properly.
After securing the base unit with the four large screws, test the knee lifter to make sure that you got it right.
You will then need to recalibrate your clothsetter if you have one.
Posted on Jul 19, 2009
  • 255 Answers
SOURCE: The top spool of thread jams tight when I pull the
It sounds like the tension setting is too tight. The tension mechanism consists of two metal disks; the thread runs between these disks. When the pressure foot is down, the disks come together, trapping the thread between them. When the pressure foot is up, the disks separate and the thread can flow freely. (BTW, this is why you adjust the tension with the pressure foot down.)
Take a look at your tension setting and try loosening it. That should resolve the problem.
Let me know if this helps, ok?
Robbie
Posted on Jan 27, 2010
wentlanv
  • 710 Answers
SOURCE: I own a Jenome Excel
Hi Sarah,
First, check to be sure you are threading the machine correctly. This accounts for most problems.
Try using new thread and carefully rethread top and bottom . If that doesn't take care of the problem, then check the bobbin case and hook for scratches, burrs, nicks, etc.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 14, 2011
Ishow me how to rewind the bobbin on a touch tronic 2001 singer sewing machine
Presser foot up, takeup lever at the top, thread the machine normally all the way and through the needle, open the needle plate, press the little lever to the right, wind the thread from the needle round the presser foot screw, press on the foot control slowly and wind the bobbin, when you have enough thread on the bobbin close the slide plate the winder will drop down, pull the threads to the back of the machine and start sewing
Oct 30, 2013 | Sewing Machines
How to thread the machine
From the spool pin take the thread to the left and over the top cotton guide, bring the thread towards you and straight down in between the tension discs, make sure the presser foot is up so the discs are open, straight down towards the needle and round the first big cotton guide, straight back up to the take up lever making sure the take up lever is at the top, right to left through the eye of the take up lever, straight down to the needle going through any guides on the way, thread the needle front to back
Oct 02, 2013 | Necchi 4575 Mechanical Sewing Machine
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
How to guide thread on kenmore 158.13201
Most machines are very, very similar, therefore, no matter what brand you own, there's basically the same steps to follow: 1. Place good quality thread on spool pin, back right-hand side of machine and raise presser foot UP. 2.Pull thread taut from spool.Make sure silver take-up lever raised to highest position. 3. Guide thread under first tension disc. 4. Hold thread taut, guiding thread into next tension disc. When you get to the take-up leaver (silver lever on right side of machine that has a hole at the top--hold thread taut guiding it from right to left through hole, bring thread down left side of it, and put thread into tension bracket, hold thread taut! Put thread in back of needle into another small bracket and pull thread towards you. Time to thread needle: put thread front to back into eye of needle. Put thread under presser foot and pull under the center of it a good 6".Lower presser foot on scrap of fabric to test. Turn hand wheel toward you to lower needle into fabric scrap. Use foot (or knee depending on machine) to start machine. Do not pull or push fabric but gently guide it. Jimmy Place fabric scrap under needle. Low
Apr 04, 2012 | Kenmore Sewing Machines
How do I thread this machine
Threading the Machine
Raise the thread take-up lever to the highest point by turning the balance wheel towards you. (Large round wheel on your right of the machine.)
Raise presser foot with presser foot lifter and pass the thread in the order from
[1] to [8]
[1] Pass the thread through the top cover thread guide.
[2] Draw the thread around the thread guide and down into the tension.
[3] Then down around the check spring holder.
[4] Firmly draw the thread from left to right over the take-up lever and down into the take-up lever eye.
[5][6] Then down through the lower thread guides.
[7] Slide the thread behind the needle bar thread guide on the left.
[8] Thread the needle from front to back.
Sep 06, 2010 | New Home L-372 Mechanical Sewing Machine
I need a threading diagram singer 329k sewing machine
Cotton omn the reel pin, take the thread from the right to the left and through the top cotton guide above the takeup lever, make sure the takeup lever is at the top and make sure the presser foot is up, take the thread down the right hand side, round the tension unit and back up the left hand side to the takeup lever, right to left through the takeup lever and then follow the guides all the way down to the needle and thread front to back, flat side of the needle must face back.
when you put the bobbin in, bobbin in your left hand and the thread must feed from the bottom of the bobbin, drop the bobbin, through the groove and lay the thread to the back.
Feb 12, 2010 | Singer Sewing Machines
I have a Huskystar C10, I continue to get the machine jammed and get a rats nest below. I have also broken two needles. I have adjusted the tension and this continues. Any solutions?
This problem occurs because the machine is not pulling the top thread upward out of the bobbin area and all the threads then jam under the fabric. The problem looks like it's in the bottom of the machine, (and there is a slight chance it is) but 99% of the time it's caused from the top of the machine.
1. Remove the thread completely from the top.
2. Lift the presser foot into the "up"position. (When the foot is up, the top tension discs loosen and your thread can get deep into the unit where it belongs.)
3. Great time for a new needle, flat side to the back and make sure it's up in all the way.
4.When threading the machine I always think of, "Down, Up and Down".
You come from the top, down to the covered spring (called a check spring), then back up to the take up lever (the lever that moves up and down rapidly as the machine sews), then back down to the needle.
5. After the needle is threaded, lower the lever in the back so the foot goes down but don't put it on the thread. Hold the thread in your left hand, directly from the needle eye at this point, pull the thread towards the rear of the machine. You should feel a tightness in the thread, almost fighting you. The needle will bow slightly before the thread comes through the machine. If you have no resistance you've found your problem. (Tension number 4 or 5 should work)
6. Remove the bobbin, check the edges, are they smooth? Does the thread wound on the bobbin look balanced? It has to be for proper delivery. Make sure you are using the proper bobbin. There is a singer bobbin that looks like the one your machine takes but it will not work correctly. If you have different clear plastic bobbins and they are different in height, you machine takes the taller one. Drop in a good bobbin and thread the bobbin tension, make sure to "click" the thread in there good. Pick up the bobbin thread, through the hole of the needle plate by taking a stitch by turning the handwheel and gently pull on the bobbin thread to feel it's tension. It should be a fraction of the top "feel" that the needle thread had, they are never even. You should feel slight resistance from the bobbin thread, not tight. Try a test stitch and see what happens, hopefully your sewing!
Oct 15, 2009 | Husqvarna Sewing Machines
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Jun 09, 2009 | Necchi 3101 Mechanical Sewing Machine
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Dec 10, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Janome L-344 Mechanical Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
