Question about Trio 8GB HD 4.3 Touchscreen MP3/Video Player
How can i reload android to my trio tablet
The tablet says that the android process quit working
Will not down load apps. Lost all data, want to reload to orig factory settings
You got one of those no name chinese made tablets, if the reset to factory defaults it is not working there is a slim chance to load a new firmware.
Apr 28, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
How can start tablet when the launcher has stopped?
Unfortunatly, your launcher is corrupt. The only answer I can see will be a complete restore to factory defaults. Your apps should reload once you sign back on to the app store, be sure to use your original signon and password combination. I had to do this once and everything seemed to follow up.
Good Luck.
Dean
Mar 06, 2015 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
My trio stealth is new. When I power it on, goes to a screen "@9dual core" and doesn't go any further. Help!
There's a hard reset process on the G2 7" that I have used successfully on several stuck units. It may also work, I've learned, on other models of Trio tablets and other Android-based brands / models as well. It did on a Zeki 7" 8GB that I owned. But.... TRY AT YOUR OWN RISK. Here it is.
(1) PRESS AND HOLD the power button until the tablet shuts off completely.
(NOTE:
if any type of start-up screen comes on, FORGET it: the Tablet must be COMPLETELY powered off for this to have any chance of working.)
(2) PRESS AND HOLD the volume-down button, while simultaneously PRESSING AND HOLDING the power button
This will (hopefully) bring up the Android figurine, along with some kind of rotating-wheel graphic.
(3) Do nothing else but WAIT, until the screen changes to a text-based menu, with about 6 to 8, or more choices.
(4) Use the volume-up and volume-down buttons to navigate between choices, and select (highlight) the choice offering to reset the tablet (to Factory Settings).
(5) Click and release the power button to start the reset operation. Follow and additional prompts to ensure you are selecting the correct next step.
This RESET process will erase ALL your installed apps, as well as delete all your saved photos, music and other user files and preferences (including wallpaper, time-zones, Wi-Fi settings etc. But when it works it will give you back a working Trio. Use your reset Triot carefully: generally, I'll say the Trio machines are good economical alternatives to the perhaps more robustly engineered (and much more expensive) big brand items.
Regarding restoring personal preferences, and earlier installed apps I have no experience whatsoever. However there may be sufficient arguments to backup your personal data either on your home computer or on online "cloud based" services. Do the research, ok?
Happy New Year, 2015 ... & ....Good Luck!
Dec 28, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
How i unlock my tablet?
There's a hard reset process on the G2 7" that I have used successfully on several stuck units. It may also I've learned work on other models of Trio tablets and other Android-based brands / models as well. It did on a Zeki 7" 8GB that I owned as well. But.... TRY AT YOUR OWN RISK. Here it is.
(NOTE:
Dec 23, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
Get my trio stealth to turn on?
By far the most common fault with Android tablets and in many cases there is no fix which is disgraceful...
Its called a Boot loop caused by too many apps memory consumption, os or bootblock corruption - press the reset button (its a small pin hole usually on the back of the tablet) with a pin
If that doesnt work switch on and press the power and up volume buttons
You will be in recovery mode
Select recover system then reboot
You can also load a new os from an sdcard -cyanogenmod - google it.
If that doesnt work then i am afraid you are in deep - you will have to attach to your pc with usb cable , download and run the android dev kit and use the command line to sideload or repair the tablet. You will probably find you can still browse you files but the OS is hosed - Difficult if not impossible to fix without a factory reflash/reload.
Sep 14, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Why won't my trio stealth g2 tablet won't hard reset?
Does the device have a password lock on it.
If it does try removing this first, then attempt a hard reset.
You can access the engineers menu by holding the volume - button and then pressing the power button whilst turning it on.
Other than that the only other option is to reload the ROM with a flash utility.
But this is not for the faint hearted :-)
Aug 05, 2014 | Mach Speed Trio Stealth G2 Tablet -...
I dont have a hdmi on my mach speed trio steath g2 tablet can i hook up to the to watch nexflix
You should look at a Google Chromecast.
This is an HDMI device, that you can stream from your android to the ChromeCast connected to your TV.
They are actually quite cheap to purchase.
Then you use your tablet to control it.
It should also work with Netflix.
May 13, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Android.process.acore
Go into Settings/Applications/All and find Google Services Framework and clear the cache (if any) and clear data.
Disable DRM Protected Content Storage and Media Storage in your Apps list.
Or if either of those fails, uninstall latest update [until you get to the latest properly working update] or factory reset
Jan 12, 2014 | Mach Speed Trio Stealth G2 9.7 inch Tablet...
Trio 8GB HD 4.3 Touchscreen MP3/Video Player Logo
Top Trio Computers & Internet Experts
David Payne
David Payne
Are you a Trio Computer and Internet Expert? Answer questions, earn points and help others
