Hi I have an LG 37LC55 which works fine with scart no problem but when I am using hdmi after about 5-10mins the screen scrambles and goes green, purple, yellow but sound still works when I switch it off and back on again it happens quicker but if left to cool down happens after 5-10 mins again . Its just strange that it doesn't happen on scart any advice would be appreciated on what it could be and if it's possible to repair at a low cost
circuitworld
  • 335 Answers
SOURCE: green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Posted on Jan 04, 2009
SOURCE: plasma tv picture goes on and off but always has sound
I install a fan in the back, there is a only o9ne 5 v, 3,3 a that you can connect workin fine..
Posted on Apr 14, 2009
circuitworld
  • 335 Answers
SOURCE: A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Posted on Nov 09, 2009
SOURCE: RCA l42wd22yx5 green screen when on HDMI... Still get sound
We had the same problem. What we did was unplug our DVR box from Comcast to reset it and plugged it back in and the picture came back.
Posted on Jan 24, 2010
budmrtn
  • 11361 Answers
SOURCE: Hi, I have a 37lc46 LG LCD which takes ages to
Replacement power supply is used?
You need to verify the DC output voltages of the power supply first and make sure this power supply has no bad caps with leaking/bulging tops. It goes into standby can also be that it detects fault some where in the set.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 07, 2010
Hi I have an LG 37LC55 which works fine with scart no problem but when I am using hdmi after about 5-10mins the screen scrambles and goes green, purple, yellow but sound still works when I switch it off...
my freind i think it is not a problem.maybe it is from the device connected with tv hdmi try another device or go to system setting of the device to change the video format(try 1080i)
Jan 14, 2013 | Televison & Video
Screen is green when watching dvd
have you checked you leads are you using hdmi or scart? if its scart then the wires inside can short together and give a green screen
Hope this helps
John
Mar 24, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a blue square (no image) on the top left hand side of the screen. Problem only with HDMI. Scart works fine
can you eleborate what tv are you using. and it might be a bad hdmi cable or an older one also unplug the hdmi and switch it around. what do you mean with scart works fine?
Mar 16, 2011 | Televison & Video
Hi, I have a 32LG3000 HD tv with software version 3.47.1. I just bought a Humax FoxT2 HD free view box but when connected via hdmi to the LG tv a message briefly comes up on the tv saying invalid format...
I , would try using another ( alternative connection) from your humax , say the scart cable just to see if it , the humax is ok. then if tv has more than 1 hdmi skt try it too, if still not working retry upgrade firmware route
pete
Nov 11, 2010 | LG 32LC7D Television
HI, MY LG 37LC55 HAS THE ON LIGHT FLASHING GREEN. ALSO THERE IS NO PICTURE. CAN ANYONE HELP?
maybe your tv has a defect,go to the LG service center ask a technician to fix your tv
Jun 19, 2010 | LG 42PC5D Television
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Dec 26, 2009 | Proscan PS50700 50" Rear Projection...
LG 42PC56 ps3 best settings?
Your PS3 should detect when you set up a HDMI connection then just follow the onscreen instructions. If it does'nt unplug the HDMI cable and use the scart cable. Then unplug the scart cable and plug in the HDMI cable your PS3 should detect this HDMI cable and it will notify you on screen.
Hope this helps
Terry
Apr 06, 2009 | LG 42PC5D Television
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
