Question about LG Washing Machines
Error code de on aLG WM-1285FHD
Error code comes on startup it shows de
  • 679 Answers
If you push in on the door does the error code go away? If so, then it may just need an adjustment. This is a door error code. Probably a losse or faulty door switch. If you are a do it yourself person you can try shimming out the door switch from the inside. You will need to take the top off of the machine to see if you have enougfh room to get your hand down to the switch where it is held on by 2 screws. If there is not enough room then you will have to also remove the door gasket, front control panel and then the front panel to get to it. It may be possible to put a few flat washers between the door switch and the front panel and then put the screws back in to pull the whole door switch assembly back a little bit (therby causing the door to shut tighter). If this does not stop the DE error then the door switch is bad and will need replaced. Your model number does not appear to be a US model, so I do not know the correct phone number for you to order the part if you need one. You will have to call LG customer service (for the country where this model was sold) to get the correct phone number if you need to purchase a part.
Thanks for using FixYa.
Posted on Jan 25, 2009
Wm 1285fhd
Just because the door "appears" to be fine does not mean that the sensor mechanism or latch is working properly.
here's the part you need LG 6601ER1004C Door Lock Switch Assembly AppliancePartsPros com
Aug 08, 2014 | Washing Machines
What is the error D3
I think that should be a "DE" error code. On LG machines the DE error code is for a "Door Open Error".
Check the condition of the door lock, door hook and switch as this will give the error code above, the switch can be checked with a multimeter for condition. You might need to replace the door hook or the internally mounted switch.
May 25, 2014 | LG WM-2077C Front Load Washer
De error code
DE is a drain error
Check to be sure the drain filter is clear.
Nov 30, 2012 | LG WM-2277HW Front Load Washer
De error on my lg washing machine, machine is working fine, now i have a door error which means the door is not closed but it is closed i know there is a way to override the problem
LG WFT70A37ECT Top load washing machine, showing DE error... even door is close still showing this error. that is the solution... really appriciate... thanx
Jun 27, 2010 | LG WM-1480FHD Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
LG WM-1285FHD Leaking from Dispenser Drawer area
There is a problem with the dispenser assembly where the drawer enters.  You will have to have it checked by a qualified LG technician to see what the problem is.
Apr 27, 2008 | LG WD-1280FHD Front Load Washer
LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
Apr 09, 2008 | LG WD-1280FHD Front Load Washer
DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Oct 23, 2007 | LG WM-2032H Front Load Washer
Washing Machines Logo
219 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
