Question about Tomtom One Europe v2 GPS Receiver
Tom tom one
My tom tom shows an animation of removing the memory card,if i remove the card, it shows a slide of inserting the memory card and will not stop. When i connect it to the computer, the computer says it cant read drive g when i try to download stuff or delete stuff
  • clyfew gavaza Jul 13, 2007
    i somehow managed to delete everything and then downloaded some application software i think.takes a very long time.
    now it starts up fine and says no maps found.
  • Anonymous Nov 28, 2007
    I have a TomTom ONEand it shows a slide of inserting the memory card into the unit over and over again and will not stop.I cant do anything else with the unit.
When i turn on the tom tom one it comes up as a animation of the memory card coming out with a cross sign
Posted on Nov 17, 2008
  • 705 Answers
This would suggest the card may be faulty. If you have a backup of the info on the card, try formatting the card and restoring the data.
Posted on Jul 13, 2007
  • Inky Fingers
    Inky Fingers Jul 13, 2007
    You will need to install the maps again using the original software supplied with the unit. There should be instructions on doing this in the manuals supplied with your unit. If not check the TomTom website for more help.
4 Suggested Answers
  • 6 Answers
SOURCE: tom tom one not reading card
Try resetting the device: -Charge it until it is full. -remove the SD card -press the reset button (with a pen) for 15 seconds -Hold the on/off button for at least 15 seconds -reinsert the SD card
Posted on Aug 23, 2007
SOURCE: tom tom one switch on
with tomtom turned on, remove SD card and press RESET, turn off tomtom and insert SD card and start tomtom, problem solved :))
Posted on Dec 09, 2007
RAC_ICS
  • 143 Answers
SOURCE: Not recognizing memory card!
I had the same issue after installing updates, I contacted tomtom & they talked me through it.
I think i had to wipe the card & through my tomtom home software they reformated the card & go it sorted.
http://www.tomtom.com/support/index.php?Lid=1
Posted on Dec 15, 2007
Show your memory card location
Remove the back cover by holding the phone firmly then slide in the back cover of the handset. You will now see your MicroSD and SIM card slots. Take your SIM card and slide it into the slot provided with the chip facing down. You will also see a small diagram showing you which way to insert the SIM card. Now slide open your MicroSD memory card slot gate, pop your MicroSD memory card into the slot, then close the MicroSD memory card slot gate by sliding it forward then backwards.
Oct 29, 2011 | LG GD510 Cell Phone
Corrupted tomtom one memory card
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options.
Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work
Sep 13, 2009 | Tomtom ONE GPS Receiver
Won't start, seems to be a problem with the card
If you have an SD card installed then
Remove the SD card from the tomtom
The card may need to be formatted properly first or re-formatted.
Formatting is better done in a card reader.
There are differing views but this method has always worked for me.
Insert the card in the reader,. Using my computer or windows explorer right click on it and select format
Now connect the tomtom to the pc but don't let tomtom home run.
Exit TomTom Home if need be.
You now need to select your tom tom which will also show as a drive and may even show its own special icon.
then just copy ALL the files from the tom tom to your sd card.
Once all the files are on your new card switch off the tom tom and insert the sd card and re-boot the TomTom
It should now work.
If not try the hard re-set in which you would use a paperclip to reset the tomtom. there should be a tiny hole on the underside of the unti.
push the paperclip in there (not too hard) while the unit is switched on
This would cause a reset to factory defaults (you may have to set home location etc)
You may also have to switch off and re-boot again for it to take effect.
Sep 06, 2009 | Tomtom ONE GPS Receiver
Tom tom go 300
The memory card you have inserted is damaged and needs to be replaced
Jun 30, 2009 | Tomtom GO 300 GPS Receiver
I saved the map on to my computer from the tom tom in Tom Tom Home and installed it on to a new SD card and now it working perfectly. I bought a 2mb SD card for £6.70 put it into a card reader and connected to computer and installed map and it gave me the instructions to put into device (Tom Tom) and switch on to connect then off and back into card reader to finish. Then I disconnected device which is important to do by the way put the new Sd card into Tom Tom and it is workink perfectly. I hope this help others who have problems.
May 17, 2009 | Tomtom One Europe v2 GPS Receiver
Just bought yester day turns on show card goin in
The animation is telling you to insert a data card, which should have come with the device. If you have already inserted the data card (make sure there isn't a blank in the slot) then the unit is faulty and needs to be returned.
May 17, 2009 | Tomtom RIDER 2nd Edition GPS
Tom tom one Xl wont load
Hi,maybe that the memory card is knackered! (tomtom ones are poor quality and slow) Have you got a spare card that you use in a camera maybe, if so format it using fat 32 on your computer and then copy and paste all your files one by one onto it. I this works I would recommend a sandisk ultra 2 as a replacement card, worked for me!
Feb 24, 2009 | Tomtom One XL GPS Receiver
Memory card does not work
Is this a new unit? How long have you had it?
I had one for 6 months and had to return it to the store because it stopped locking onto satellites. It sounds like the hardware fault. Did you try the reset button? It returns it to its default factory settings.
Regards,
Spare head 2.
Jan 05, 2008 | Tomtom ONE GPS Receiver
Tom tom one switch on
Dec 06, 2007 | Tomtom One Europe v2 GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
358 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
