Question about Samsung SGH-U700 Cellular Phone
How to disable side volume key
Side volume key function has either reject or silent settings. While answerting the ring, if my hand or fingers touch side volume key the phone goes on hold mode. How can i completely disable side volume key?
  • Anonymous Mar 20, 2014
    it has a hand and all it does is vibrate cant put volume up . It is in disability mode and i dont want that
  • Anonymous Mar 21, 2014
    How long do i need to hold volume up power and menu buttons before the phone goes into recovery mode?
  • 190 Answers
1. In Idle mode, enter an
area code and phone
Press [ / ] to adjust the
volume.
During a call, the
exposed keys are locked.
Press [Centre] to unlock
the keypad.
To change the sound profile:
1. In Idle mode, press
[Centre] and select
Settings → Phone
profiles.
2. Select the profile you
Posted on May 12, 2010
Why can`t I get my iPhone 5 C to ring. It jusy vibrates
Check above the volume key, there should be a little switch. If it's orange, flick the switch so that it isn't. Other than that, try turning your volume up.
Jul 01, 2014 | Apple iPhone 3G
Got a telstra easy touch dicovery 3. Cant turn silent mode off
Hi Shannon,
TELSTRA EASYTOUCH
DISCOVERY 3
SYMPTOM = No incoming ring or alarm tone
RESOLUTION:
- Check the ring tone and ring volume settings under
Profiles
- Check the handset is not muted (Long press the #
key
Apr 30, 2014 | Cell Phones
Ringtones silent
Make sure that you didn't turn your phone to silent. Hold down the # key and see if it say silent or loud, soft, etc.. Make sure that the volume is turned to maximum, by using the top switch on the left hand side of your closed hand set. Make should that you have a ring tone assigned because if not nothing will work. Follow the below instructions
Menu-Settings-Ring Styles-Detail-Calls (Assign a tune)-click OK
This should get your ring tone back
Feb 26, 2011 | Motorola Mobility RAZR V3
How do I silence the keypad
Press and hold [#] for the silent profile
Jan 19, 2011 | Samsung S8300 Ultra Touch platinium-red...
Would like explanation of function key symbols I want to turn off the finger pad.
function key is Fn key on keyboard.
these keys might be in orange color
with the help of these keys you can control sound volume. you can adjust screen resolution like brightness .you can also turn off/on wireless features.These keys are like shorcuts keys to perform few functions on your laptop.
To turn off your the finger pad
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
Open the Control Panel, and then click Mouse. For information about the Control Panel, see Windows Help and Support Center <findinfo.htm>.
In the Mouse Properties window:
Click the Device Select tab to disable the touch pad and track stick.
Click the Touch Pad tab to adjust touch pad and track stick settings.
Click OK to save the settings and close the window.
May 07, 2010 | Dell Latitude D610 Notebook
My i phone 3gs does not ring, the volume control is on max
On the left hand side of the Iphone you will be having a slider kind of a thing which can be used to toggle from silent to ringing mode. Check if that set to silent mode.
Mar 01, 2010 | Apple iPhone Smartphone
How do I set touchpad settings to inop touchpad when USB wireless mouse is plugged in
Some laptops have a Fn Key sequence to disable the touch pad. Look for the touch pad icon on your function keys (hand touching finger on a square). You can also go to the toucpad app by double clicking on the touch pad icon in the system tray and got to device properties to disable tapping - assuming issue is TPad interfering with typing
Jul 25, 2009 | Toshiba Satellite U305-S5097 Notebook
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Samsung SGH-U700 Cellular Phone Logo
356 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
