Question about Scotsman CU1526
Scotsman cu1526 ice machine is not making ice and display code flashing #2
Sea Breeze
  • 4654 Answers
SOURCE: My binsensor lingh is on but my bin is not full so my ice machine
I see you already said you bin sensor light was on. The drop door has a metal tab that waves over a sensor as it opens, if that part when it closes does not tell the board that door is shut the the board thinks the bin is full. I know you already know that but until I can talk to Scotsman on the phone or review their service manual for your model. One good thing about Scotsman is they are very helpful to their customers. Unless the machine is obsolete.
Posted on Apr 23, 2009
  • 102 Answers
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
  • 129 Answers
SOURCE: Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
Posted on Feb 25, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
I need the model number and if you pull front panel off to see if controller is flashing any codes then i can help
Feb 25, 2014 | Kitchen Appliances - Others
I have a Scotsman SCN60 nugget icemaker and when I add cleaning solution to reservoir it just stays there
Hi, Are you using Scotsman ice machine cleaner? and are you using the right amount?
1. Open the door and turn the ice machine control knob to off.
2. Scoop out all the ice, discard it.
3. Pour 4 ounces of Scotsman ice machine cleaner into the ice machine reservoir.
4. Turn the ice machine control to on.
5. Allow the machine to operate for about 2 to 3 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin liner.
Now a dirty evaporator plate will not stop it from making ice it will cause it to hang up on the plate during harvest cycle if machine is not making ice good then there is something else wrong but when you clean the machine also make sure you clean the condenser coil and fan if this is dirty this will cause it to slow down on production of ice.
Dec 19, 2013 | Scotsman DCE33PA1BC 15in Built-in...
My scotsman ice machine makes thin ice cubes
rotated the ice bridge adjustment screw clockwise about a 1/8 turn in between freeze cycles. thich direction makes the ice thicker.
Mar 27, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ICE MACHINE SHOWS NUMBER 6 IN DISPLAY
does it look like "6" or "b" , the "b" just indicates the ice bin is full. If the unit is not making ice, check the curtain on the outlet of the ice making coil to see that it is not stuck open. There is no listed "6" error code in the service manual.
Oct 09, 2012 | Scotsman Prodigy Air Cooled Cuber C0530SA...
How to unlock a scotsman ice machine code L board lock
Turn off machine. turn back on. what other code is it giving something is locking the board out.
Oct 02, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Mv450 scotsman high pressure
Check to make sure the condenser coil is clean, fan motor is running during freeze cycle. High Ambient temp, Ventilation, The higher the temperature entering the condenser coil the higher the head pressure. Fan motor failure, pressure switch failure. The cut out pressure varies 400, 450 or 500 PSIG. Water supply failure. not enough water running over the evaporator plate will cause high presser.
Jul 30, 2012 | Scotsman Cooled Modular Contour Cuber Air...
I own the Scotsman Prodigy CU1526SA model. My machine is not making ice, the machine's Code Display shows code 3, which according to the manual, code 3 is for "slow water fill". But the...
chech water inlet valve to make sure there is no trash blocking it. if it is cleare then i would check the water supply to the machine and make sure the supply line is not kinked.
May 16, 2011 | Scotsman Ice Machine - 290lb...
Jun 28, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman CU1526 Logo
160 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
