Question about Echo Pb-403T Leaf Blowers
Echo pb 403t throttle cable adjustment
Throttle cable adjustment
4 Suggested Answers
  • 430 Answers
SOURCE: ho spark on a pb 403t backpack blower
Be sure you have no spark ( 90% of the units that come into my shop for repair with the complaint of no spark- have a fuel issue). Be sure the spark plug is good.
If no spark then remove the ground wire from the module and check for spark again. You must use the recoil starter- spinning by hand is not sufficient. If still no spark then replace module. If there is spark with the ground wire disconnected then there is a problem with the kill switch or a bad wire.
Posted on Nov 30, 2009
#1 Taper
  • 1040 Answers
Well obviously you need to check the spark plug for fire. Try the old one first, then a new one. If you still don't have fire, then you probably burnt out the coil.
Jim
  • 17 Answers
SOURCE: I have this same blower:
Well for what its worth I have ran them with alot less compression than that...its the air cleaner plugged or exhaust is plugged or the fuel filter is plugged or last of all the high speed jet needs turned (H) screw 1. Take out air cleaner and try it, clean and install. I bet thats it, if not check in tank for fuel filter, clean and install, and then others I mentioned before. Good Luck. 70 lbs compression will run and run correctly, just a bit doggy.
Posted on Nov 26, 2010
How do I remove throttle cable on 2002 dyna super glide
REMOVAL
Loosen the cable adjuster jam nuts, screw the throttle cable adjuster until it is as short as possible, remove the two screws that hold the handlebar housing together to separate the upper and lower housings, unhook the ferrules and cables from the throttle grip and lower housing, remove the air cleaner assembly and disconnect the throttle cables from the carburetor, pull the cable from the housing by placing a drop of oil on the retaining ring that holds the cable in the housing, then firmly pull the bent tubing portion of the cable out of the housing using a rocking motion. The cables can be removed from the carburetor by pulling the outer housing away from plate above the throttle wheel and then with slack in the inner cable twisting the inner cable to allow the swaged end to release from the slot in the throttle wheel and then pull the inner cable out through the mounting plate hole.
If you will reuse the cable wash all components in non-flammable cleaning solvent, carefully blow all parts dry with low pressure compressed air, replace the control cables if frayed, kinked or bent, put one or two drops of oil into the housing of each control cable.
INSTALLATION
Apply a light coating of graphite to the handlebar and to the inside surface of the housings, attach the control cable assemblies to the lower housing, push the silver insert of the throttle cable housing into the hole in front of the tension adjuster screw, push the gold insert of the idle cable housing into the hole at the rear of the tension adjuster screw, install the adjusting screw, spring and friction pad in the lower housing if they were removed, position the throttle grip on the handlebar, place the lower housing on/over the throttle grip, position the ferrules and retaining rings over the cable balls and seat them in the throttle notches, fasten the upper housing to the lower housing using two screws tightened to 35-45 in-lbs (4.0-5.1 Nm), CHECK the throttle cable routing, on FXD, FXDL and FXDX models, the throttle cables are routed between the headlamp bracket and the front fork upper bracket and then under right side of tank to carburetor. On FXDXT models the throttle cables are routed through a wire form that is mounted on the upper fork bracket. On FXDWG models, the throttle cables are routed behind the front fork upper bracket, then under the right side of the fuel tank to the carburetor, install the throttle cables on the carburetor and adjust them at the handlebars and re-install the air cleaner. The throttle cables must be clear of steering stops and not be so tight that the idle speed will be changed when turned from steering stop to steering stop.
Throttle Cable Adjustment
To adjust the throttle cables turn the cable adjusters and jamnuts as short as they will go so that both cables will have zero adjustment at the start of the adjustment procedure. THEN with the front wheel pointing straight ahead turn the throttle grip wide open and hold it there, turn the throttle cable adjuster to lengthen the sleeve until the throttle cam just touches the cam stop. THEN tighten the adjuster jamnut and release the throttle. THEN turn the front wheel full right and turn the idle cable adjuster to lengthen the sleeve until the cable housing just touches the spring in the cable support sleeve. THEN recheck the adjustment by working the throttle grip to be sure the cable returns to idle position when released. If the cable does not return to idle, turn idle adjuster to shorten the sleeve until the correct adjustment is reached and then tighten the jamnut. The throttle control must operate freely without binding.
Oct 02, 2014 | 2006 Harley Davidson FXDI Dyna Super Glide
How to ajust trottle linkage on transmission
Throttle valve cable adjustment:Place throttle body in idle position. Press cable lock button to release cable. Pull cable conduit toward rear of vehicle until wiper is completely retracted into end of conduit fitting. Release cable lock button. Raise vehicle for access to trans throttle valve lever. Rotate throttle valve lever toward front of vehicle until ratcheting sound (from cable) stops. CAUTION " Do not rotate throttle valve beyond the idle stop. The lever, valve and manual lever shaft will be damaged if rotated too far." Check cable adjustment. Throttle valve lever should begin to move at same time lever on MPI throttle body moves off idle position. Lower vehicle. 1991/1992 Rear Wheel Drive Truck There is also an adjustment procedure for front and rear band adjustments at engine if you need them.
Jul 27, 2014 | 1992 Dodge Dakota
Adjust throttle cable or kick down cable
Its non adjustable you have to replace the cable if it is worn; the only cable which can be tension adjusted on the throttle assembly, is the accelerator cable idle screw; this is the screw at the bottom of the assembly in the very front. it requires a star bit to adjust it...
May 19, 2013 | 1994 Oldsmobile Cutlass Ciera
1980 ss 440 injector adjustment
On your throttle cable, where it goes into the metal housing, there isn't an adjustment, follow the cable down to the end of the cable. there should be a cylindrical barrel type connector there with a screw in it. your throttle cable runs through that. loosen the screw and adjust your throttle cable accordingly. "Note-there should be at least a 1/4 inch of play on the thumb throttle on the handlebars"......good luck bro
Oct 30, 2012 | Yamaha Motorcycles
Replace throttle cable
There are two cables leading to the throttle. Both have two pieces.
Cable 1 goes from the throttle about 12" long and connects to an adjustment piece joining it to cable2 which goes to the throttle body.
Cable 3 also goes from the throttle and is about 12" long and connects to and adjustment piece joining it to cable 4 which goes to the spring on the throttle body.
To change any of them you must loosen the adjustment piece until the ends can be removed from it.
Then to change cables 1 and 3 you have to remove the throttle cover on the grip. you will be able to see how they are removed. Then reverse these steps to install the new cable.
To change cables 2 and 4 in no more difficult but more time consuming as you will have to route these longer cables from the adjuster to where they connect to the throttle body.
When cables have been install and all parts reassembled you can carefully adjust the tension on the cables until the throttle responds the way you like it.
Hope this helps
Sep 19, 2011 | Harley Davidson XLH Sportster 883 Hugger...
I changed my grips and in doing so my throttle cables have moved. the idle is loose though the throttle is not bad. was wondering how to adjust cables.
There should be an adjuster in each cable just below the throttle assembly. Push the adjuster cover up to get to the adjusters. Loosen each adjuster lock nut. Adjust the throttle cable first. Adjust it until it has just a bit of freeplay in the cable. As you attempt to twist the throttle, you should feel a little freeplay before you feel the throttle start to open. Then adjust the idle cable the same way. When finished, lock the lock nuts so the adjustment doesn't change. Now, twist the throttle wide open and release it. The throttle should snap closed. If it doesn't, you may have to loosen the two bolts that hold the two switch housings together and slide the assembly down towards the end of the handlebar about a quarter of an inch. Try the throttle assembly again at half throttle. It should snap shut. If not, continue until you find out why. If the throttle does not work correctly, loss of control of the machine could result and the rider could be injured or killed. Make sure the throttle works properly.
If you move the throttle switch housing down on the handlebar, check the rear brake light. If it is on continously, you must move the front brake master cylinder down against the switch housing. Loosen the bolts and slide it down towards the switch housing as far as it will go.
Good Luck
Steve
Nov 27, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Too much slack in the throttle on my 2005 softail duece (fuel injected)
Ok, I'm not very familiar with fuel injected models because I don't work on them but they should have a throttle cable like anything else. In the cable somewhere (usually close to the throttle grip) it has an adjuster. There should be two cables, a throttle cable and an idle cable. The throttle cable is the cable towards the front of the bike at the throttle mechanism as it pulls the throttle open. Loosen the lock nut and adjust the cable to take most but not all the slack out of the cable. You must have a bit of slack in each cable for the throttle to work freely. Do the same with the idle cable nearest the rear of the bike.
Once finished, with the engine off, twist the throttle grip to the wide open throttle position and release it. It should snap shut. If it doesn't it's not adjusted correctly. Readjust the throttle cable and idle cable until the throttle operates properly. You must get this right.
Failure to properly adjust the throttle cables could result in the loss of control of the bike resulting in serious injury or death. If you are not sure of how to do this, find someone who knows how to do it. You don't want your throttle sticking on you.
Good Luck
Steve
Sep 15, 2010 | 2005 Harley Davidson FXD - FXDI Dyna Super...
How do you adjust the throttle & idle cables on a 2009 sportser
Each cable has an adjuster near the throttle grip. They may be covered by a rubber boot. Slide the boot up so you have access to the adjusters. Loosen the lock nut on each cable. Now, adjust the throttle cable first. You want a little freeplay in the throttle grip when you start to turn it. Once you get it adjusted to that point, lock the lock nut. Then adjust the idle cable until it stops and back off just a bit. Lock the lock nut.
Now, with the engine OFF, twist the throttle to the wide open position and let go of it. It should 'snap" back to the closed position. If not, you may have the throttle cables adjusted too tightly. Back both of them off just a bit and retry. You want the throttle to "snap" shut on your bike. If not, it could cause you serious injury or death. If you're not certain of what you're doing, find someone that is experienced at doing this. You don't want your throttle sticking on your bike. This could be dangerous.
Good Luck
Steve
Aug 09, 2010 | Harley Davidson XL 1200 C Sportster Custom...
I have some play in my throttle control how do I ajust it or should I take it in.
You want some play in your throttle control. If you adjust the cables until you have no play, your throttle will quit automatically returning to the closed position. Not a safe thing since most people today are accustomed to the throttle doing that.
Now, you don't want too much play either. less than a 1/8 of a turn. Take the play out by adjusting the throttle cable first and the by adjusting the idle cable. The throttle cable is the front most cable where it enters the throttle twist grip.
Important, once you adjust the throttle cable, you must insure that it operates correctly. Twist the throttle to the wide open position, with the engine OFF of course, and release it. It must automatically return to the fully closed position. Failure to insure the proper operation of the throttle can lead to serious injury or death.
Good Luck
Steve
Aug 05, 2010 | 2002 Harley Davidson FLHR - FLHRCI Road...
Revs badley between gears
is there 2 cables at the throttle grip if so one being accel the other decel these need to be adjusted properly to eliminate your problem on my kawi- looseing bothlock nuts and screw both throttle cable adjusting nuts in fully to give throttle grip lots of play with throttle grip closed turn out the decel cable adjusting nut until the cable just becomes tight. tigten lock nuy. turn accel cable adjuster nut until throttle grip freeplay is approx 2-3mm tighten lock nut hope this helps
May 30, 2009 | 1992 kawasaki Zephyr 750
Echo Pb-403T Leaf Blowers Logo
91 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
