Question about Kenwood Ar-404 Stereo Audio Receiver - 100w X 2 Channels
Kenwood ar-404 fuse replacement
Need a replacement fuse. Fuse says something like e6.3 a / 125 v on it
  • St8 Baller Jan 20, 2013
    on one end, it has a "T" with a bar over it in an upsidedown triangle and on the other side is has "237", U subscript L in a circle, and SA in a circle. the circles are below the 237.
    New Friend:
Try radio shack
Posted on Jan 20, 2013
I have a Kenwood KDC-MP2032 installed in a boat. I changed the battery in the boat and now I can't get the tuner to power on. If I need to replace a fuse, where are they and what size fuse do I...
Try to check first the fuse on the fuse box of your boat if it is still good then the fuse of your stereo is located at the back of the stereo itself. Detached the stereo from its housing or holder you will see the fuse at the back of it.
Jun 28, 2011 | Kenwood KDC-MP2032 CD Player
Remote code for kenwood audio reciever ar-404
GO to KEnwood's site. See if they have a free download for the users manual. THat will have the codes. Sadly there is not an industry standard for remote codes so the same device may have different cods on different remotes.;
Jun 12, 2010 | Kenwood Audio Players & Recorders
How to change the fuse on a kdc-mp2035
Hi.
You need to pull the unit out from the dash. At the back side of the stereo you will find a 10-amp fuse inserted into the chassis of your Kenwood.
See the red 10 amps fuse on picture below:
Mar 15, 2010 | Kenwood KDC-MP235 CD Player
My kenwood is only playing sound from the front 2 speakers the center and surround is not working. is there a fuse inside i can change? what do i need to do?
Not a fuse. Go through all the setups and speaker definitions or maybe just find that pesky "stereo" mode switch and reset it to something that allows all the channels to operate.
Jan 22, 2010 | Kenwood KRF-V5100D
Microwave Blowing Fuse. Fixed. After Day, Fuse Blows Again.
Hello there:
If you have all ready changed out the fuse and it has happned again i would first check to see that the fuse is the right one for the machine (i am sure that you did this but please recheck ) next i would look at the controle board as the next culprit it maay be failing expecially if there were any pops ar sparks that was noticed before the initial failure.
Also check to see if all of the wires by the board a re not loose or looked burned ar if there is any grease or anything like this around the area
And finally check to see if the plate is turning ok and not sticking cause this would cause the microwave to overload and it wil make every fuse you put in there fail after just a couple of uses ok
SO please try all of these things that i have explained to you
I hope this is very helpful for you.
Best regards Michael
Dec 12, 2009 | GE JE2160 Microwave Oven
Hook up for an AR 404 receiver
Copper is positive, aluminum is negative. OR One of the wires should have a white (or black) stripe on the insulation...this is negative wire. OR If using 18 gauge extention cord wire, the positive wire will have small grooves running the entire lenght (very difficult to identify, unless you have good eyesight) Hope this helps.
Jun 11, 2009 | Kenwood AR-304
Aftermarket Stereo connection
hi there
if you matched all the wires from the harness to the kenwood deck and its not working don't worry you just missed the last step........(all wires attached that a colour coded connected)
simply turn your car on.........now on the front of the kenwood deck there is a SOURCE button with all units it could be a (S, SRC, Power) hold the source button down till your kenwood unit powers up ..........if your unit still doesn't work check the fuse on back of kenwood unit should be a 10a fuse (blue) if the fuse is fine put the unit back in dash..........now check the fuse panel on driver side dash with the door open you will see this panel pull it off (some describe the fuse panel as looking like an air vent but its not its a handle to open) now on the panel that you just pulled off there is a fuse diagram on the inside look at it find radio fuse it will be a (blue fuse) located in the top row of fuses check it if blown replace and unit should work.............if this doesn't solve the issue than its a (sneaky) fuse not to many people know about if you pop the hood of your car there is a black plastic panel located just below the battery pins and just above the driver head light (usually black box with yellow writing on it......in this there are mini fuses check all of them do not touch the black relays in there just the small tiny fuses the fuse you will look at should be yellow 20a (this fuse is closest to engine and comes after the abs relay if you look inside the lid you took off it will have fuse locations cant remember which one it is for sure but check them..........now see if your kenwood unit powers up if not the last option is to ground to the black wire from back of kenwood unit to metal frame.............this last part is also done if your unit does power on but your car lights don't work if this happens ground the kenwood unit to the frame of car and open up fuse panel on driver side dash replace the blown fuse for lights or radio (make sure the kenwood unit is grounded to the frame before replacing the fuse in dash panel............if this doesnt help you than i would assume the kenwood deck needs to be repaired by kenwood.......
good luck
hope i was able to help and sorry this list is so long
Feb 26, 2009 | Car Audio & Video
Kenwood AR 404 burning w/ open flame.
You are literally playing with fire. Obviously the unit is in dire need of service! Please, take unit in for check out by a pro/tech
Apr 27, 2008 | Audio Players & Recorders
Kenwood Ar-404 Stereo Audio Receiver - 100w X 2 Channels Logo
75 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
