Question about Kenmore Washing Machines
How to put control shield on washer
11044182401
  • Kenmore Master
  • 17,130 Answers
If this the panel board check this link : Panel board
Posted on Jan 18, 2013
Rattle in rear undercarriage of 2007 dodge caravan
Put a couple of long hose clamps together & put
around exhaust converter heat shield
Other underbody heat shields that rust away,
you remove the bolts & add a large washer
Sep 16, 2012 | 2007 Dodge Grand Caravan SXT Minivan
Does the sound shield on tha maytag bravos washer really help to reduce noise. The person who came to install the washer said i didn't need it and didn't put it on, but now i feel he should have because...
You are really answering your question yourself ;-0)
Have it put on- it's obviously been designed to cut down the noise and the installer was wrong not to fit it.
Cheers,
John C
Mar 09, 2011 | Maytag Bravos MTW6600T Top Load Washer
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
Removing the windshield washer reservoir in a 2002 Chrysler T&C
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Remove the engine fresh air housing inside the engine compartment.
  3. Disconnect the washer hose at the in-line connector forward of the cowl grille so that the in-line connector remains with the washer hose from the fresh air plenum.
  4. Disconnect the washer hose from the hose clip located on the front fender side shield.
  5. Remove the filler tube screw.
  6. Hoist and support vehicle on hoist or jack stands.
  7. Remove the right front wheel and tire assembly.
  8. Disconnect the left right front wheelhouse splash shield and move aside.
  9. Drain washer fluid from the reservoir and into a suitable clean container. This can be done by disconnecting the windshield washer hose from the front (outboard) washer pump and allowing the washer fluid to drain into a container through a temporary jumper hose connected to the front washer pump.
  10. Disconnect the electrical body harness connectors to the washer pump motors and the fluid level sensor. Slide the red lock on the connector to the release position, then, depress the black tab and pull the connector off the pump or sensor.
  11. Remove the two reservoir mounting screws.
  12. Disconnect the reservoir from the body mount by raising the reservoir upward slightly and then down so that the reservoir filler neck and front washer hose pull through the opening in the front fender side shield.
INSTALLATION
  1. Push filler neck and front washer hose through the opening in the front fender side shield. Connect the reservoir to the body mount by lowering the reservoir down.
  2. Install the two reservoir mounting screws. Torque screws to 8.5 - 11.3 Nm (75 - 100 in. lbs.) .
  3. Connect the electrical body harness connectors to the washer pump motors and the fluid level sensor. Slide the red lock on the connector to the closed or locked position.
  4. Assure that washer is properly routed to prevent pinching and possible inoperative washers.
  5. Connect the left right front wheelhouse splash shield and move aside.
  6. Install the right front wheel and tire assembly.
  7. lower vehicle from hoist or jack stands.
  8. Install the filler tube screw. Torque screw to 8.5 - 11.3 Nm (75 - 100 in. lbs.) .
  9. Connect the washer hose to the hose clip located on the front fender side shield.
  10. Connect the washer hose at the in-line connector forward of the cowl grille.
  11. Install the engine fresh air housing inside the engine compartment.
  12. Connect the battery negative cable.
  13. Verify system operation.
Apr 01, 2009 | 2002 Chrysler Town & Country
WASHING MACHINE LEAKING FROM BOTTOM
Check the two lengths of 1/4" plastic tubing, the long one that runs from the filler at the botton left side of the tub, and the short one that runs from the load switch (water level switch) to the shield assembly (formed plastic cover for the controls). When under pressure, the tubing can come loose from the plastic nipple on either side of the shield, leaking water while the tub is filling. If either length of tubing is detached from the nipple, reattach the tubing and use a 1/4" hose clamp to prevent it from detaching again.
Mar 14, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Wiper fluid level sensor replacement
Reservoir —Windshield Wiper
Removal
  1. Remove the RH wheel; refer to Section 204-04 .
  1. Position RH splash shield aside.
    1. Remove six screws.
    1. Remove three pin-type retainers.
  1. NOTE: Windshield washer fluid should be collected in a container after the windshield washer hoses are disconnected.
    Disconnect the electrical connector and washer hoses.
  1. Remove the upper reservoir bolt.
  1. Remove the windshield washer reservoir.
    • Loosen the two lower reservoir bolts.
Jan 15, 2009 | 2000 Mercury Villager
1994 Chevy Silvrado Starter Problem
It’s your solenoid that is getting hot and the engagement washer inside is what is sticking. There is some heat shield material you can get from the auto parts store to shield you solenoid.
Jun 23, 2008 | 2000 Chevrolet Silverado
Washer shield broken
The fastest place to get the part is a local parts place if you dont have anyone near check this site out www.apdepot.com there you can put in your model and brand it wil give you blown up views of your unit and pick the parts you want hey will ship them to your door i have had good luck with them .Hope this helps if so plz rate
Jan 27, 2008 | GE WCVH6260F Front Load Washer
Washing Machines Logo
13 people viewed this question
Sal De
fordexpert
Robert Rankin
