Question about Kenmore Washing Machines
How to change a new control shield on a washer
Model# 11044182401
  • Kenmore Master
  • 17,130 Answers
Please clarify in detail
Posted on Jan 18, 2013
On sub zero 690 like to change bulb in lighted electronic control panel
you will have to remove the light shield, remove the plastic trim that says the model number in front of the light shield, then the 2 screws holding the side cover on the left side of the fridge section. Then the cover will need to be pushed towards the rear of the fridge then tipped out at the front. It has springs holding it in the back.That should access the bulb you need to change
Nov 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
Maytag washer top load ser# mvwx600xwo It's making
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWX600XW1/3048/0153200/W1104178/00004?blt=06&prst=&shdMod=
go here and look at parts,the nut number 14 in diagram comes loose and this causes noise from parts not lining up,this is an easy check,pull the washer forwards and then tilt it back against the wall, remove the bottom panel and then remove the shield part number 20 in diagram,check the nut and see if you can push the parts up that are above the nut,i've found this nut loose in a few machines,when you buy the new nut it has blue lock tight on the treads,if it is loose and you have some blue lock tight you can try adding some to the treads or buy a new nut if this is what you find,otherwise without being there i couldn't really help you out but check that nut first.
Apr 07, 2013 | Washing Machines
How to put control shield on washer
If this the panel board check this link : Panel board
Jan 17, 2013 | Kenmore Washing Machines
How do I fix my window washer pump on my 2000 dodge caravan?
One can get a repair kit that includes a new motor pump and wiring clips, or
one can get the original motor that plugs into the windshield wiper fluid reservoir.
Windshield wiper reservoir (gives idea of how to change the windshield wiper fluid pump motor) Removal & Installation To Remove:
  1. Disconnect and isolate the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Remove the right front wheel and splash shield.
  4. Disconnect the electrical connectors from the pumps and detach the rear washer hose.
  5. Place a drain pan under the reservoir if it contains fluid.
  6. Disconnect the front washer hose at the wiper unit in the engine compartment. NOTE: The front hose will be removed with the reservoir.
  7. Let the fluid drain from the reservoir.
  8. Remove the mounting screws and the reservoir.
To Install:
  1. Install the fluid reservoir with the mounting screws.
  2. Connect the front washer hose in the engine compartment.
  3. Connect the electrical connectors and rear washer hose.
  4. Install the splash shield.
  5. Install the right front wheel.
  6. Lower the vehicle.
Aug 27, 2010 | 2000 Dodge Caravan
When i try and turn it on, a code comes up f 01
Model #MHWZ600TW01, this unit would display an F01 error immediately after the start button was pressed. This error is an EEPROM communication failure of the electronic control board and is an internal failure that basically indicates the washer no longer thinks it's a washer. Since the repair requires the board to be replaced, I installed a new control board and now it has started washing again. A word of caution. Whirlpool has been making a lot of changes to the control boards of their front load washers (yes Maytag too) so make sure you are ordering the correct model using the full model number including the last two digits. If you install the wrong board, you may find yourself trying to fix a self induced problem.
Aug 09, 2010 | Maytag EPIC MFW9700S Front Load Washer
The door on my dryer and washer open the wrong way
Are you planning to reverse the door swing direction on your
DUET®dryer? To do so, you will need to purchase a Door
Reversal Kit.
To order, call the dealer from whom you purchased your dryer or
refer to the "Assistance or Service" section of this manual. Ask
for Part Number 8530069 (Shield Blue), 8530070 (Shield
Platinum), 8530071 (Biscuit) or 8530072 (Pewter).
Door Reversal and Stack Combination Kit
® ® DUET dryer and stack your DUET washer and dryer? To do so,
you can purchase a Door Reversal and Stack Combination Kit.
for Part Number 8530073 (Shield Blue), 8530074 (Shield
Platinum), 8530075 (Biscuit) or 8530076 (Pewter).
From the manual, Page 4. Hope this helps
Eric
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0802161.pdf
May 24, 2009 | Whirlpool Dryers
Have to change bearing on front load washer
This link should get you on your way. http://www.applianceblog.com/washers/RearBearingV6.pdf
In addition I should mention that the original bearings are a shielded bearing (Z). Follow the link and use 6306-2RS and 6307-2RS bearings which are sealed. I was able to match up SKF 562737 seal which is now a CR 15939 seal I believe. It is completely rubber coated. Between the sealed bearings and new seal you should be good to go.
Dec 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer shield broken
The fastest place to get the part is a local parts place if you dont have anyone near check this site out www.apdepot.com there you can put in your model and brand it wil give you blown up views of your unit and pick the parts you want hey will ship them to your door i have had good luck with them .Hope this helps if so plz rate
Jan 27, 2008 | GE WCVH6260F Front Load Washer
Change Bearings
I will need the brand of washer as well as the model number.
Jan 15, 2008 | Washing Machines
Water splash sheild ineffective
My machine may be a different model, but seems to have similar problems. I resolved this by: a) making sure the splash shield is fastened correctly at all points round the tub (it worked loose) b) as a temporary fix reversed the foam gasket inside the splashshield until I get a new one
Aug 22, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
15 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
