Question about Deadbolt Locks & Locksmithing
Code for sierra tool keyless entry system
Need to know how to set entry code
3 Suggested Answers
SOURCE: Schlage FE365v keyless entry lock.. Lost manual. Forgot 6 digit programming code. Need instructions to restore and set all new codes.
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
Posted on Aug 08, 2010
  • 963 Answers
SOURCE: Was unable to get the '2 beeps' when attempting to
Here's a link to the installation and programming for your lock:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
SEE PAGE 9 (Troubleshooting tips) for your answer about the two beeps.
Here is a link to Customer Support:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Posted on Mar 05, 2011
2003 crown vic keyfob only works with ignition in run position .keyless entry and door locks work fine.even tried new keyfob.no change
The keyless entry system consists of the following components:
  • driver door module (DDM)
  • keyless entry transmitter
  • keyless entry keypad
The driver door module (DDM) receives inputs from the digital transmission range (TR) sensor, ignition switch, brake switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
  • Battery junction box (BJB) fuses:
    • circuit breaker 7 (20A)
  • Central junction box (CJB)
    • 4 (10A)
    • 6 (15A)
    • 8 (25A)
    • 13 (5A)
  • Keyless entry keypad switch
  • Power door lock actuator
  • Luggage compartment release switch
  • Luggage compartment release solenoid
  • Connectors or connections
  • Wiring harness
  • If fuse's good have checked for DTC'S - diagnostic trouble codes .
  • B1526 Keyless Entry Circuit Short to Ground DDM Go To Pinpoint Test E . B1553 Decklid Release Circuit Short to Battery DDM Go To Pinpoint Test B . B1751 Park/Neutral Switch Circuit Short to Battery DDM Go To Pinpoint Test K . B2425 Remote Keyless Entry Out of Synchronization DDM Go To Pinpoint Test L Need a professional grade scan tool to check fro these codes . Not a code reader for OBD2 codes .
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter not programmed.
  • Remote transmitter.
  • DDM.
  • Go To Pinpoint Test F .
Did you program the new key fob ?
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Turn the key from OFF to RUN four times within three seconds, ending in RUN. The locks will then lock and unlock, confirming program mode has been entered.
  1. Press any button on each remote transmitter to be programmed. The doors will lock and unlock to confirm that each remote transmitter has been programmed.
  1. If additonal remote transmitters are to be programmed, repeat Step 3 within 7.5 seconds or steps 2 and 3 if more than 7.5 seconds have elapsed.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
  1. NOTE: Failure to wait at least 20 seconds will cause programming failures. Wait at least 20 seconds after turning the key to OFF or after the last remote transmitter has been programmed to activate a remote transmitter for testing or verification
Feb 19, 2017 | Cars & Trucks
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
Keyless entry does not unlock doors, open trunk, or start vehicle (remote start built onto keyless entry). Battery is new in BOTH remotes and neither one works. Could a fuse in vehicle be bad? Secondly,...
RFA / MOD fuse 10amp . location - insturment panel fuse box. Fuse Block - I/P
Right side of the I/P, behind the access panel
If the fuse is good your best bet would be to take it to a qualified repair shop , that doesn't mean the dealer . Lot of good independant repair shops around , just have to check the yellow pages.
Do you know what DTC'S are ? diagnostic trouble codes ! Not only the ones for the engine management system OBD 2 . There are also DTC'S for the remote keyless entry system , BCM - body control module. You need a factory or professional scan tool to view this codes
DTC B3101
DTC B3102
DTC B3103
DTC B3106
The remote control door lock receiver (RCDLR) communicates with the body control module (BCM) through the keyless entry serial data circuit. When any button on the keyless entry transmitter is pressed, the transmitter sends a signal to the RCDLR. The RCDLR sends a lock, unlock, or panic alarm request to the BCM, depending on which button is pressed on the transmitter. The BCM receives the message and performs the appropriate function. The BCM also uses the keyless entry serial data circuit in order to communicate with the RCDLR when programming transmitters. Do you know what serial data circuits are ?
DTC B3101 Keyless Entry Data Link Circuit Range/Performance
DTC B3102 Keyless Entry Data Link Circuit Low
DTC B3103 Keyless Entry Data Link Circuit High
DTC B3106 Keyless Entry Data Link Parity Error
This is what the factory manual said as to the location of power steering fluid reservoir ! Not much help , you would do better googling it.
The power steering fluid reservoir holds the power steering fluid and may be integral with the power steering pump or remotely located. The following locations are typical locations for the remote reservoir:
• Mounted to the front of the dash panel
• Mounted to the inner fender
• Mounted to a bracket on the engine
Aug 19, 2017 | 2005 Buick LaCrosse
How can i tell if my 1990 gmc 1500 has keyless entry
All pre 1995 GMC vehicles had to have an alarm system to have keyless entry... So, lift the hood and look for a red LED near the right front of the vehicle. If none - you don't have keyless... if yes, the you do.... and an alarm system too.
Dec 31, 2009 | 1990 GMC Sierra
I don't have a manual for my 2004 lincoln Avaitor but would like to know how I can change the code on the drives door key pad
KEYLESS ENTRY SYSTEM With the keyless entry keypad, you can: • lock or unlock the vehicle doors without using the key. Your vehicle has a factory set 5 digit code that operates the keyless entry system. You can also program your own 5 digit personal entry code. The factory-set code is located: • on the owner's wallet card in the glove compartment • or at your dealer. When pressing the controls on the keyless entry keypad, press the middle of the controls to ensure a good activation. This system will disable the power door lock controls. These will not work until the vehicle is disarmed. Programming your own personal entry code To program your own code: 5. Enter factory set code (keypad will illuminate when pressed). 6. Press 1/2 control within five seconds of step 1. 7. Enter your personal 5 digit code. Enter each digit within five seconds of previous one. 8. After the code is entered, the locks will cycle, confirming that the new code has been set. Do not set a code that includes five of the same number or presents them in sequential order. Thieves can easily figure out these types of codes. Your personal code does not replace the permanent code that the dealership gave you. You can use either code to unlock your vehicle. If a second personal code is entered, the module will erase the first personal code in favor of the new code. Locks and Security 149 Locks and Security If you wish to erase your personal code, use the following instructions: 1. Enter factory set code. 2. Press 1/2 control and release. The system will now only respond to the factory set code. Anti-scan feature The anti-scan feature prevents repeated attempts at arriving at a valid key code. The keyless entry pad is disabled for 1 minute after 7 unsuccessful attempts (35 consecutive button presses) at entering a valid key code. The keypad will flash during this 1 minute mode. However, the 7/8 and 9/0 controls will still lock the vehicle. Anti-scan will be turned off after: • one minute of keypad inactivity. • the remote entry transmitter UNLOCK button is pressed. • the ignition is turned to the ON position. Unlocking the doors with the keyless entry system To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will also illuminate. To unlock all doors, enter the factory set code or personal code (driver door unlocks) and press the 3/4 control within five seconds. Locking the doors with the keyless entry system It is not necessary to enter the factory or personal code prior to locking all doors. To lock the doors: • with the driver's door closed, press the 7/8 control and the 9/0 control at the same time.
Dec 17, 2009 | 2004 Lincoln Aviator
How do i reprogram keyless entry codes
door pad keyless codes?
in owner manual, enter permanent code and then press "1" and enter personal code, then press "1" again. Then both codes will work.
If you don't have manual, go to Motorcraft.com and click on technical resources and click on your year owner manual.
Each vehicle equipped with a keyless entry keypad is programmed with a five-digit entry code. This code is provided to the customer through a wallet card in the Owner Literature package. In addition, this code is available through a diagnostic tool and is also printed on the vehicle security module label. When entering codes each digit must be entered within five seconds of the previous button press.
Programming/Erasing Personal Code
A unique personal five-digit code can be programmed by following these steps:
  1. Enter the factory set five-digit code (the keypad will illuminate when pressed).
  1. Press 1/2 within five seconds of Step 1.
  1. Enter the unique five-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it will simply overwrite the previous personal code. To erase a personal code, carry out the following procedure:
  1. Enter factory set five-digit code.
  1. Press 7/8 and 9/0 at the same time within five seconds of Step 2.
Anti-Scan Feature
To provide added security, the keyless entry pad is disabled for one minute after 35 button presses without a valid entry code being entered. The keypad will flash during this one-minute mode with all functionality disabled except for 7/8 and 9/0 still being allowed to lock the vehicle.
Anti-Scan will be turned off after any of the following events:
  • the keyless entry remote transmitter UNLOCK button is pressed
Unlocking the Doors with the Keyless Entry Keypad System
To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will illuminate.
To unlock all doors, enter either the factory set code or the personal code (driver door unlocks) and press the 3/4 control within five seconds.
Locking the Doors with the Keyless Entry Keypad System
It is not necessary to enter the factory set or personal code prior to locking all doors. To lock all doors, press the 7/8 and 9/0 controls at the same time.
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Dec 01, 2009 | 2004 Ford F350
How to reprogram code for keyless entry
A set of my keys and remote were stolen and
I need to disconnect my keyless entry but I don't know where it is located
Oct 02, 2009 | Kwikset Powerbolt/Electronic Deadbolt-...
Program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION: The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable. SERVICE INFORMATION: The keyless adapter cable can be used on the following vehicles:
  • 2001 - 2004 MY Elantra
  • 2001 - 2004 MY Santa Fe
  • 2002 - 2004 MY Sonata
  • 2001 - 2004 MY XG300/350 0390020a.gif
NOTE
  • The 2003 - 2004 MY Tiburon does not need the Keyless Adapter Cable to add keyless entry remotes to the factory security system. Instead, the Hi-Scan Pro connects to the vehicle using only the DLC cable. See page BE-60 in the 2004 MY Tiburon Shop Manual for the latest instructions.
  • The most current Keyless Adapter Cable Instructions are available in the following shop manuals:
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
  1. Connect the keyless adapter cable to the Hi-Scan Pro DLC cable. 0390020b.gif
  2. Plug the keyless adapter into the vehicle's 10-pin multi-purpose connector located behind the driver's side lower instrument panel (next to the DLC). NOTE Sample vehicle shown is the Santa Fe.
  3. Turn the Hi-Scan Pro ON
    and press ENTER
    . NOTE "Release date 29. Sep. 2003" OR LATER
    must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
  4. Select option "HYUNDAI VEHICLE DIAGNOSIS"
    and press ENTER
  5. Select vehicle model and press ENTER
  6. Select option "TRANSMITTER CODE SAVING"
    and press ENTER
  7. Ensure that the key has been removed from the ignition cylinder before proceeding. 0390020h.gif
  8. Follow the steps noted on the Hi-Scan Pro screen to program the remote(s). NOTE The factory security system can only be programmed to accept two remote transmitters and MUST be programmed for both remote transmitters at the same time.
  9. Press ESC
    on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
  10. Turn the Hi-Scan Pro OFF
    and disconnect the adapter cable from the multi-purpose connector.
May 22, 2009 | Hyundai Motor 2003 XG350
I can't find the keyless entry code for my 2004 ford freestar
The code is on the fuse box under the dash near the hood release. On my van there are two bar codes on a sticker attached to the fuse box. Under the first bar code, on the right side is the 5 digit code (bring your glasses the numbers are really small). After you get this code, just search the internet and there are plenty of forums on programing the keyless remote and also adding your own unique number to the key pad entry.
Good Luck
Mar 08, 2009 | 2004 Ford Freestar
Keyless entry
I believe dealer has to re-program the new code.
Aug 29, 2008 | 2001 Ford Explorer Sport Trac
Locks & Locksmithing Logo
50 people viewed this question
Top Deadbolt Locks & Locksmithing Experts
jdthefixer
Mark Wolfe
Are you a Deadbolt Lock and Locksmithing Expert? Answer questions, earn points and help others
