Question about IBM ThinkPad T30 2366 Notebook
My computer says it is charging but as soon as i hit the power button it stops charging and does nothing even happens
The green light turns on when I plug it into the A/C power slot and I let it charge. After awhile I open it up and I hit the power button but nothing happens and the green light goes away. The only way to get it to say it is charging is to pull out the battery and put it back in. Then the whole process starts over again.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 101 Answers
Have you tried running the computer with just the AC plugged in and not with the battery? If not try that. It could be the battery is going out. I had a similar issue once. If that doesn't work it might be the power supply / powercord or it could be the motherboard.
Posted on Jan 17, 2013
SOURCE: I TURNED MY COMPUTER OFF AND IT WONT TURN BACK ON
sometimes you have to remove the memory, unplugged and without the battery in remove it then hold the power button for 10 seconds to clear any power in the pc.
Posted on Nov 01, 2007
skotkolr
  • 558 Answers
SOURCE: IBM ThinkPad T30 starts up, then turns off
Motherboard is damaged I recommend ebay for a board of that type, there is no simple fix I own three T20s and when one did the same thing I just replaced the motherboard that solved the problem. the lcd screen and inverter were fine.
based on the non powering issue now I would say the MB is shot, replacement will give you a few more year use however for a reasonable price.
Posted on Apr 30, 2008
benwabnick
  • 2404 Answers
SOURCE: IBM Thinkpad T40 will not power on from full battery
Bad battery, needs to be replaced.
Posted on Jan 30, 2009
  • 4 Answers
SOURCE: green battery charging light flashing and computer won't start
Have you tried removing the battery and replacing it again?
Posted on Mar 02, 2009
SOURCE: my lenovo T400 will not start up
I got the same problem. Have u resolved the it? If so, please send a message to: tjsteen@broadpark.no
Posted on Oct 22, 2010
Intel D946GZIS machine will not start after being reassembled. The green light on the Motherboard is on but after hitting the power button nothing happens
It is more than likely the power supply that is faulty. Newer PSU's have a 5volt supply missing, this means that some older boards will not run with the new PSU's. Try and find an exact match for your older supply but with a better power rating, if that is what is required.
Jun 24, 2012 | Intel D946GZIS Motherboard
Tried unpluging and nothing tried al buttons nothing the computer was at a shop to BE FIXED AT SHOP OK CAME HOME STUCK IN POWER SAVE MODE BUTTON ORANGE ON MONITOR HIT GOES GREEN SAYS PAWER SAVE MODE HIT...
Press and hold the power button for 5 seconds this will turn the system completely off wait 5 seconds then turn it back on as soon as it boots up go into power options in the control panel and click the option from power saver mode to do nothing as there is a fault with some computers that it gets stuck in power saver mode
Jun 27, 2011 | Computers & Internet
My Acer Aspire 6530-5753 laptop stopped charging the battery even though the power supply light was on--it's an aftermarket charger from Radio Shjack. The battery ran dead and it wouldn't run on...
This is not the motherboard. The batteries in laptops have electronic sensors in them. When they reach the end of life, they stop the computer from turning on. Once that happens it wont power on with the battery in or out. Batteries are not that expensive. Only about 25 dollars.
Mar 27, 2017 | Acer (ACERMOTHERBOARD)
I cant turn on my HP520 notebook pc. when i press the power button, it blinks once, and the charging light blinks for 9times(orange light, the 8th times was green light) i tried to remove the battery and...
Alright, not sure if this will help, by my understanding is that you are saying that when you power the computer using the power supply adapter, nothing comes on? Then when you have your battery installed on, then there are lights blinking from your battery charger LED amount of times. In this case there are no promblem with your laptop and it is your power supply adapter that is damaged and will need to be replaced. It is not charging the battery. The battery is still good, but does not have enought charge to power up your system. You can find a charger on ebay for a good reasonable price compare to getting it from Hp. I hope this can help you.
Jan 13, 2011 | Computers & Internet
My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Nov 27, 2009 | Acer Aspire 4520-5582 Notebook
My laptop wont turn on
when you hit the on button the green light go off after a while, i suggest you bring it to technician your laptop is shutting down as it about to open, its either the sensor is not working and making it to overheat or the power switch is loose, hope this help
Sep 17, 2009 | Acer Extensa 5630-6806 Notebook
Dell Inspiron 530 I turns on and nothing happens
1.) If when hitting the power button, ABSOLUTELY nothing happens, no fans come on, nothing- You need a new power supply most likely. I see this all the time in my shop. Here's the bad news- Dell likes to use their own special power supplies, so a normal one may not even fit in the case. If that is the case, then I'm sorry to say Dell likes to charge over $100 easily for a new one.
2.) Fans come on, lights come on, but no screen. This can mean any number of things. Bad VGA cable (or DVI), bad RAM, bad mobo, even a bad PCI card. time to start troubleshooting. Change what parts you can, remove any PCI cards that are not needed, remove one RAM card then the other, etc....
Apr 29, 2009 | Dell Inspiron 530 Desktop Computer
I have a gateway ma7 laptop and press power and get nothing
When the computer is off, unplug the power cord from the laptop and then plug it back in. See if the charge light (lightning bolt symbol next to the led) comes on or turns green/blue. If it doesn't your power supply may not be working, even if the light on the supply is on. Second is the battery may be damaged. Remove the battery and see if you can power on at all.
If it boots with only the cord, the battery is bad/shorted forcing shutdown.
Apr 11, 2009 | Gateway MT3705 Notebook
LED Power light turns on, but nothing happens
If you've only had it 6 months then I would suggest you contact the manufacturer for a warranty replacement. Their warranty period is 1 year so see what they can do.
Mar 15, 2008 | Disney Pix Max Digital Camera
IBM ThinkPad T30 2366 Notebook Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
