Question about Saws
Elu bearings How do I change
  • 3 more comments
  • nooboo878
    nooboo878 Jan 17, 2013
    Does anyone know how to change the bearings on my elu sliding mitre saw? Any advice would be greatly appreciated
  • nooboo878
    nooboo878 Jan 19, 2013
    The bearings are at either end of the blade shaft, and I believe there are 2on the armature , I have located them I just can't see a way to remove them any help is appreciated .
  • nooboo878
    nooboo878 Jan 31, 2013
    Hi thank you for your reply, the model is PS174. I also thought about pullers, the problem is the bearings seem to be pressed onto the shafts and into place at the same time, ie the bearing is not exposed . Hope this makes sense.
  • Graham Feb 10, 2013
    When you take the the pully side off the machine the armature will come out as well. You might need to tap the end of the blade shaft to help it along. The rear bearing on the armature should come off with the pullers. suport the housing and you can tap the main shaft out of the housing and you will then find it easy to replace that bearing. the beaaring on the fan end can be removed by removing the fan and pulleyleaving the bearing to be pressed / tapped out of the housing. rebuild the armature/housing cover in the rverse manner remembering to make sure that you put the bearing sleve on the rear bearing if it had one (some old ones didn't) once the housing with the armature in replaced then fit the blade axel support thr left hand side as you tap it in with a soft mallet and make sure it is fully home other wise you will have trouble alinging the belt.. Sometimes when you refit the blade it pulles it throught th e last bit. If you need any more help than you can contact me at oasistools.co.uk
  • nooboo878
    nooboo878 Feb 12, 2013
    Thankyou for your help I will try as you say, if I get stuck I will certainly ask you. Thanks again
    Champion:
  • 304 Answers
Try using a pair of two or three leg pullers. You can also use a split plate and press them off if you have a press. You don't say which model ELU it is.
Posted on Jan 29, 2013
Elu. Why doesn't it start?
Old ELU TGS171 /tgs 172 tgs 173 until A3 type If the 171 or 172 a relais in the switch on the right side or a 60 mf Capacitor is damaged or only a broken powercable , if 173 in the switch on the front a little round bridge rectifier inside the switch can be defect or a powercable or motor cable can be broken .look also on the little metal actuating pin also on the switch that the whole unit is tight so by abbreviate the trigger switch will work . if not the must primary a broken cable or a loose slight contact .
Mar 08, 2016 | Saws
Elu tgs172 motor stopped running and makes whirring noise and will turn very slowly if the saw blade is turned
Sounds like a worn out bearing.
Instead of the shaft turning concentric with the outer bearing, it roles around in the worn bearing like the wheel of a stunt car going around a loop-de-loop --except the relative sizes are closer so it makes a lot of racket.
That Elu is a cool saw concept. They came out in the 1960's before commodity Miter saws hit the market so big. I've used one before.
I suspect the bearings can be pressed out and replaced. Take the saw to a motor repair shop and you might get them replaced for $15 a bearing. There's one bearing at each end of the motor.
Sep 25, 2014 | Saws
Electrial drawing for a flip over saw model COD2000FLS
Check out the links associated with these images. I suspect it is identical to an ELU
Elu tgs172 Google Search
Sep 24, 2014 | Saws
Elu manual
Elu is taken over by Dewalt. I can't find manual online but try to check on Dewalt band saws. ; you can use Dewalt manuals for reference. Are you cutting metal? I use Haltbar 601 series bi metal blade for cutting steels.
Jun 20, 2014 | Saws
My elu flip saw shorts out when I flip it over from a table saw to the chop saw, it works fine as a table saw
There is a bridge rectifier its a little black round piece in the box of the red green switch that must be replaced i see you have got a gray or bleu ELU not a dw 743 i know this problem that is what i know buy a new rectifier or place 4 diodes 1n4007 in a bridge if you know how to do this to make AC to DC its only for the magnet switch and connect the 4 wires to it .
May 28, 2014 | Dewalt Dw743n 240V 250Mm Combination Saw
Replace front bearing in elu saw
Depends on which machine
Mar 19, 2014 | Dewalt Saws
Elu PS174 manual
Manual for elu ps174
Apr 05, 2013 | Saws
Saws Logo
234 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
