Question about Rainbow E series Canister Wet/Dry Vacuum
Removing top cover - Rainbow E series Canister Wet/Dry Vacuum
  • Rainbow Master
  • 18,424 Answers
Click this link to download the manual and watch videos how to use your rainbow E
http://rainbowsystem.com/support/videos/
Posted on Jan 18, 2013
How do I remove the bottom cover on powermate #26412690 to replace belt?
Squeeze in on each side of the cover with the headlight lense to remove it. There are two screws under the cover you will need to remove. Then flip the power nozzle over and insert a screwdriver between the base and top cover on the left and right sides to release the catch to remove the top cover to get to the belt.
Feb 10, 2018 | Kenmore Vacuums
Howto change a belt
Remove the top or bottom cover of the power nozzle/base of the vacuum. The screws will be on either the top or bottom of the base. Remove these screws to gain access to the brushroll. Remove the brushroll and attach your belt then putting the belt around the brushroll and using the brushroll to stretch the belt into place. Replace the top and bottom cover.
Jan 10, 2012 | Vacuums
How do I pop the top off to replace level adjustment lever.
Turn the machine over (with the handle released). Remove the 4 screws (2 on each end of the cover over the brush). Remove the cover. There are 2 screws, deep in the machine (behind drive train wheels) remove the screws. With the machine in the same position, note 2 plastic clips located on either side of the top cover. Release the clips using a slotted screw drive.
Nov 28, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
How do I change belt in power head? Is there a
There could be 2 different ways to access the belt on the kenmore line of powerheads...
1) turn the powerhead over so that the bottom is facing up. IF there are screws on the bottom, remove them. There should be 2 either at the back where the rear wheels are, or one under the elbow, and one midway at the front under the lifter wheels. remove the screws, and there should be two tabs on the sides to remove the top cover. OR 2 tabs at the back of the unit near the screws to remove the top cover.
2) and this is the more common powerhead...
remove the light cover for the powerhead by pressing at the two sides and pulling the cover up. sometimes a screwdriver to pry open a little will help.
Remove the light bulb.
Remove the two screws.
Turn the head over and pry at both sides to pull the top cover off.
Good luck with either one.
Nov 18, 2010 | Kenmore Vacuums
How do i change the belt on the eureka 4703D
Changing the belt is quite easy on this unit.
First, you will need a phillips screwdriver looks like the X. there should be 2 screws on the top cover, and then MAYBE one more there by the hose where it attaches to the base at the back. The top cover comes off and you have full access to the belt underneath.
Also, side note, once you have the cover off there you should see a black and yellow sticker near where the belt rides, and it will go into more details to changing the belt.
Nov 03, 2010 | Eureka Power Plus 4703D Bagless Upright...
I have a Hoover Model #U6430-900, Self-propelled Ultra Wind Tunnel Upright- I am sure the actuator arm- for the self propelled function- has broken. My question is how do I remove the plastic cover on top...
Hi There,
Here's a step by step guide that will explain in detail how to remove the top cover on your Hoover. The repair was written for a different problem then one you're experiencing, but you can follow along step by step to see how you can remove the top cover.
If you haven't already purchased the actuator arm, here's a link for you to the part on Amazon
Hoover Windtunnel Self-Propelled Windtunnel Actuator Arm
Here's the repair guide:
Step 1. Make sure that the vacuum is unplugged. Turn the machine upside down so that the brushes are facing upwards. I find the easiest way to do this is to put the brushes on top of a counter top or work bench with the handle of the vacuum resting on the floor. Remove the four screws that hold the bottom plate in place. Remove the bottom plate, both belts and then the roller brush from the machine:
Step 2. There are 3 screws that hold the top brush cover in place that need to be removed. On the right side the screw is down below the transmission to the right. There's also a screw in the agitator tray, in the middle that needs to be removed. NOTE: This small screw in the agitator tray is only present on some models, you's may or may not have this little screw, but all models will have all other screws circled. I have circled both screws that need to be removed:
The screws on the left side that need to be removed are also circled. One screw holds the upper brush cover on, and the other two screws secure the hose in place. Remove all three screws as well as the transparent hose cover:
Step 3. After all of these screws have been removed, there are two clips that are the last things holding the top brush cover onto the vacuum. Use a flat head screwdriver to push these clips off on both the left and right sides. The right side clip is near the pulley that the flat belt2_bing.gif rides on, and the left side clip is next to the internal hose.
Step 4. Once both of these clips have been pushed so the unhook from the lower agitator housing, remove the top cover.
Once you have removed the top cover, here's a link to a guide that will show you how to replace the actuator arm itself:
http://vacfactsblog.com/2009/12/how-to-change-actuator-on-hoover-self-propel-vacuum-cleaner-step-by-step/
I hope that this information helped you fix your vacuum cleaner. If you have any follow up questions, or need clarification on something, please feel free to use the comment box here on the Fixya repair page, and I'll be happy to answer any of your questions.
If this was helpful, please be so kind and rate the repair, or leave feedback. This is greatly appreciated by the Fixya community if an answer was helpful.
Thanks again,
Chris Jones
GoVacuum.com
Jun 14, 2010 | Hoover Ultra U6430-900 WindTunnel Bagged...
How do i change the belt on my Vax V-015 06w46
Remove the two screws from the top cover, remove top to expose belt & replace. Replace top cover.
Jun 20, 2009 | VAX Appliances 2000 Canister Vacuum
How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Jan 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Changing belt on hoover runabout
Found this info on the web...haven't tried it yet
Sep 07, 2007 | Vacuums
U6446-900
from the underside: 1. remove 4 screws holding agitator cover in place 2. remove 2 screws (black screws) holding hose retainer in place, pull hose out through top 3. remove three screws, 2 long, 1 short holding top cover: short screw is at center of inside of brush housing, long screws are inboard of wheel axles, and slightly forward (all of these screws are aluminum colored) 4. from inside surface of each side, at approx the center, locate and push down on ledge inside right and left inside with a screwdriver to slightly displace the plastic ledge that holds the cover on; this ledge-lock-detent can be released with your fingers. You'll have to support the drive mechanism to allow the top housing to drop free. 5. remove housing, turn vacuum over, then go find the torx driver you need to disconnect the cable. Good Luck MB http://in4m8ion.com
Aug 19, 2007 | Hoover U6630-900 WindTunnel Bagless...
Rainbow E series Canister Wet/Dry Vacuum Logo
23 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
