Question about Frigidaire GLER341A Electric Dryer
Wiring diagtam for fridgidire dryer--gallary series
Four wires need plugged in and I don't know where they plug in at.
    Scholar:
  • 197 Answers
I don't see anything to show me what to advise you on. Why are they loose?
Posted on Jan 18, 2013
  • 18 Answers
SOURCE: wires came unplugged from behind control knob
Below is the link to the wiring diagram to your dryer, it should help some. In addition what I can tell you is that most appliance components have initials next to the connections that indicate what color wire is supposed to be connected to them, this is where the diagram should help. In cases of things like switches, buzzers, thermostats, things that only have to do with circuits being open or closed they will not have an initial so therfor it doesn't matter what wire goes to what connection. Post again if you need more help. http://www.appliance-parts-warehouse.com/frigidaire-parts/Frigidaire-Dryer-Parts/Frigidaire-Parts-GLER331AS2/Frigidaire-Parts-50169.cfm
Posted on Jan 22, 2009
canbruce75
  • 1776 Answers
SOURCE: Convert three pin plug to four pin
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Posted on Sep 06, 2009
  • 74 Answers
SOURCE: I need to switch the three prong plug to a four
On this page is a wiring diagram for your dryer model.
http://www.youserguide.com/wiki/Frigidaire_FGR231A
Green is always ground (so can be attached to the dryer frame).
Here is some more info:
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/2008/5/3-prong-dryer-plug.htm
Posted on Dec 06, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Frigidaire Gallary electric dryer with 3
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Dec 19, 2010
heatman101
  • 43501 Answers
SOURCE: four wires fell off my frigidaire dryer and I
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Jul 14, 2011
The battery cables have six wires and I don't no how to install battery. I don't know what wire goes where
first of all there should only be two wires for battery(+) & (-) the six wires if it's a six cyclinder engine, then it sounds like your holding the spark plug wires, which run from your spark plugs to the distributor cap and I have no idea the make or model/year etc so I can't tell you the proper order, if your lucky they'll be numbers on the cap and that will tell you what wire plugs into where there but to which spark plug I'm not sure.
Sep 13, 2011 | Ford F-450 Cars & Trucks
How do i get the front off the dryer? maytag dg313
Check this out:
Don't know what you want to get in there for but the belt goes back like this:
Take a good look at the blower itself while you are in there:
Don't know what your series number is. but this dryer has two diff gas valve assemblys
The older style wire in type coils are more complicated than the newer style.
These coils must be stacked precisely like the old ones. The newer ones require no wiring so they simply plug in and are very easy to replace.
If you have a dead dryer and the door switch is fine look for duct fuses. Depending on your serial number their could be more than one of these. themobilian_2822.jpg
Aug 16, 2011 | Maytag Dryers
Going from a four wire to a three wire dryer plug....need to know the configuration for the wiring
heatman101
Jul 30, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
I have GE Profile Dryer dpsr610eg5wt and it currently has a four wire plug. Can I swith to a 3 wire which is what my old dryer had?
put the RED and BLACK wires from the old plug on terminals L1 & L2 of the dryer terminal strip either color can go on either of the terminals,then the WHITE wire from the old plug to the "N" or NEUTRAL terminal on the dryer(this terminal is usually located between the L1 & L2 terminals
May 13, 2011 | Dryers
I have phase linear uv8, need to know how to get subs 2 work! Amp goes into protect mode when rca's r plugged in, there r 3 sets of preamp out puts 1 front left and front right, 2nd is rear left rear...
try testing the amp without speakers plugged in. Run the sub preamp out to the amp that you will drive the subs with, but don't wire up the subs yet. Test for protect mode kicking in.
Yes - unplug the rca ins from the amp. retest.
No - Problem lies within the sub wiring. What is the load on the amp (measure with an ohm meter)? If it is below 4ohms, chances are the amp can't dip that low. Give it more resistance by wiring it differently (series vs. parallel)
Bruce
May 05, 2011 | Kicker Car Audio & Video
How do i know what wire goes where when I replace my 3 prong plug with a 4 prong plug. Kenmore dryer 80 series
You should not do this. Sorry, but you also need a 4 prong outlet
that has the two hots,one neutral and one ground, so if you don't have
the right outlet with these four wires you can't change the plug.
If you did change this you also need to remove the ground strap
that is connected because it has a three prong plug.
There is a connection board where the wires connect on the dryer,
there should be a black wire,red,white green,connected from dryer,
then the cord gets connected to each corresponding wire.
I am real sorry, but if you do this wrong, you will either destroy the dryer
or electrify the dryer and get killed.
Please call a electrician and have him check your supply line and do this, its not worth getting hurt or wrecking the dryer just to save some money.
Feb 05, 2010 | Dryers
The dryer has a four prong male plug and the outlet is a three prong female - which do I change? the dryer cord is the easiest, but how do I connect the leads?
4 PRONG PLUG WIRING: 2 HOTS(RED&BLACK) 1 NEUTRAL(WHITE) 1 GROUND(GREEN). 3 PRONG PLUG WIRING: 2 HOTS&1 NEUTRAL. YOU MUST USE 2 HOTS & 1 NEUTRAL ON A 3 WIRE PLUG. THE GROUND WIRE(GREEN) WHICH IS HOOKED TO FRAME OF THE DRYER IS NOT USED ON OLDER 3 WIRE PLUGS. IT IS AN ADDITIONAL SAFTEY GROUND ON NEWER MODEL 4 WIRE PLUGS.
Dec 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Wiring 4 wird dryer plug to 3 wire 10/3 for 220 welder
the four wire plug seperates the neutral and ground. the three wire just piggybacks the ground to the neutral. so just get a three wire cord that fits the 220 plug on the generator and install it on your dryer make sure to attach the ground correctly for your three wire setup
May 07, 2008 | Dryers
Frigidaire GLER341A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
