Question about Ariston Technologies Washing Machines
Al1080 reset ariston - Ariston Technologies Washing Machines
  • Ariston Tech... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Posted on Jan 18, 2013
How do I reset washing machine Ariston AR7F105 , error code F-01.
F01 - Main modul, triac on board damaged or components feedback fault
  • Short circuit motor triac on electronic module
  • Check wiring
  • Check electronic controller
Dado
Feb 28, 2015 | Ariston Technologies Washing Machines
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
  • The water inlet hose is not connected to the tap.
  • The hose is bent.
  • The water tap is not turned on.
  • There is a water shortage.
  • The water pressure is insufficient.
  • The START/RESET button has not been pressed.
Dado
May 29, 2014 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Jun 28, 2009 | Ariston Technologies Ovens
Stars cycle thin stops lights reg and eco start blinking
Clean out the filter really well, then replace it. This should reset the dishwasher. If it does it again when you try to run the dishwasher. Take the filter out and re-seat it. Some times it's not sitting exactly right. Good luck and I hope that helps.
Mar 04, 2008 | Ariston Technologies LI640S Dishwasher
Control panel
generaly the only way to reset is by turning off the power to the oven at switch board for at least 30s. if this does not work check the back of the digital panal for any burn marks as it may have shorted when it fell back, also check any wiring connectors have not come off
Feb 18, 2008 | Ariston Technologies Ariston FO98P...
Washing Machines Logo
145 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
